you know you drive a grand when.... - Page 30 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > you know you drive a grand when....
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 04-03-2010, 12:16 PM   #436
JesseOR
......When you have a can of Seafoam in the cupholder. Lol
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline   Reply With Quote
Unread 04-03-2010, 01:46 PM   #437
Walt
2008 WK
....when you show the entries in this thread to a non-Jeep, non-GC owner, and they say, "Huh? I don't get it." And, they are serious........
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline   Reply With Quote
Unread 04-03-2010, 04:49 PM   #438
reconvet88
haha my wife does though fake little "i dont get it but ill pretend i do" laugh.
but every now and then theres a "THATS SO YOU!!"
reconvet88 is offline   Reply With Quote
Unread 04-03-2010, 04:58 PM   #439
Walt
2008 WK
It's probably adaptive evolution: Where the Jeepers all adapt to the idiosyncracies of their machines. Also, a bit of self-preservation.
OK. Return to your regularly-scheduled broadcast.
Unread 04-03-2010, 10:14 PM   #440
SteveA1992
2003 WJ
when you stomp on it at 35 mph and it goes into first for about 1/10 of a second
when you can tell at what point after starting it you will hear your vaccum lines
when reading on jeepforum makes you want more and more to have 4.10's (i just can't get over how slow it is off the line)
when you win off the line because it doesnt have enough power to spin the tires
when you look at the evic and it says avg mpg is 12.7
when the gas tank runs down to empty and you hope that after you calculate your mileage that there are still two or three gallons left in the tank
when you correct someone when they say is your jeep all wheel drive
when you wish you had the 4.7 ho
03 WJ-Basically stock besides sound system.
SteveA1992 is offline   Reply With Quote
Unread 04-03-2010, 10:51 PM   #441
reconvet88
when your filling up at the gas station bragging to yourself but also complaining at the same time that your gas tanks 23 gallons. then later you think "wtf good is 23 gallons when i get 15mpg and 250 miles on a tank?"
Unread 04-04-2010, 07:08 PM   #442
EisBlade
I, Soldier.
EisBlade's Avatar
...something breaks you can either A) immediately recognize which part broke and how long it takes to repair or B) know which website you can post to get some help regarding it, and quickly. JeepForum
JT
LIFTs, TIREs, SPRINGs & GEARs:
WJ Spring Rate Chart. /// .Tire Size vs Lift. /// .Tire Size vs Gear Ratio. /// .WJ Noob Lift Chart
Driveshaft Angles & Pics of Rear Diff Pumpkins:
Correct Pinion Angles. /// .Correct Driveline Geometry 101. /// .Rear Differential Covers; What They Look Like
Death Wobble (DW): IRO 'Death Wobble Checklist'. /// .More DW Notes (from JK forum)
WJ Emergency Brake Reset Procedure: Click For PDF
WJ Headers: Doug Thorley Header pics for 4.0L 99-01 WJ's ($499)
Click here to view my sexy Jeep girl, and then watch her slay you.
Raunchy Racine
DISCLAIMER: Not responsible for men of weak character.
EisBlade is offline   Reply With Quote
Unread 04-04-2010, 09:24 PM   #443
cttandy
Still trying to figure out why you guys complain about your fuel mileage. I am on my third grand now, and I am averaging 16 city/22 HWY, just like both my 4.0L's did.
My current Grand is a 98 5.9 Limited, and even checking my mileage tonight I averaged we got 22.5 MPG.
You know your driving a Grand when you can turn around in a tighter circle then your go-kart will turn!
You know your driving a 5.9 Limited, when a friend is following you and keeps asking you to slow down because their car can't keep up.
SOLD - 1998 Jeep Grand Cherokee 5.9 Limited - stock 120,000 miles, NP242 conversion,1999 Jeep Grand Cherokee 4.0L Limited 4x4- Stock, 1999 Jeep Cherokee 4.0L 4x2 - Stock, 1987 Jeep Cherokee 4.0L 4x4 - Stock, 1987 Jeep Grand Wagoneer 4x4 - From from stock, far to much to list here
cttandy is offline   Reply With Quote
Unread 04-04-2010, 10:37 PM   #444
kromberg
lift it and put bigger tires on and you will find out how quickly it drops
1993 ZJ 4.0L I6, White Jeep member #1993 Check out my build thread:http://www.jeepforum.com/forum/f22/krombergs-zj-build-thread-977508
kromberg is offline   Reply With Quote
Unread 04-05-2010, 08:17 AM   #445
PTCHBLKZJ
You know you drive Grand when your trans starts leaking fluid so bad that your buddy brings a B-Hobby race car trailer and some how it magically fits on there
2005 TJ Rubicon 33's Rough Country 4 inch lift smittybuilt XRC10 winch MBRP exhaust
PTCHBLKZJ is offline   Reply With Quote
Unread 04-05-2010, 09:17 AM   #446
cttandy
My daily is a chevy sitting on 35's. I know all about lifted trucks. I still don't see why everyone complains. If you lift a truck it is a given that mileage will be effected. This is the only website I ever see people complaining about it.
Given my driving style, and truck setup, my chevy got better mileage with the taller tires. My last jeep I lifted wasn't effected at all as I did a lift and gear change at the same time, seemed to balance itself out. The speedo was even right!
Unread 04-05-2010, 09:32 AM   #447
MoonyJohn
Jackstand Crawler
MoonyJohn's Avatar
I actually still get the same mileage as I did when I was stock on 235/75R15. I got 15.5 then, now I get about 15-15.5 lol, but im much much slower on the freeway.
ZJ - Sold
WJ- Sold
JK - :)
Oregonian Native
MoonyJohn is offline   Reply With Quote
Unread 04-05-2010, 09:55 AM   #448
1997ddzj
.....When you tend to drive left of center to make your steering wheel sit closer to 12 o'clock
.....When you pass another GC and give your passenger a run down of the options it had
.....When you get back in your GC from driving another car, and swerve all over the road due to your steering rack, and you get a violent reminder of how bad your brakes really are
.....When you use any excuse you can to drive over/through gigantic snow banks....."But honey, i wanted to get you home in time for your show......honey......honey?
1997ddzj is offline   Reply With Quote
Unread 04-05-2010, 11:43 AM   #449
Rwebber77
2005 WK
Originally Posted by Sporer65 View Post
When you have to give specific instructions to anyone who drives your Grand on what to do, what not to do, what to ignore, and what they need to look out for.
Hit the nail right on the head...
Jeeps are so temperamental but I would never get rid of her
5.7 Hemi, OME HD, 1.25" spacers, 265/70/17 Revo 2's, Volant CAI, Gibson Catback, SCT engine management, Superchips piggy back with trans app, 3/4" front shackles
Rwebber77 is offline   Reply With Quote
Unread 04-05-2010, 02:26 PM   #450
comptiger5000
...When you get in any other car and can't drive straight because the play in the steering wheel is missing
comptiger5000 is offline   Reply With Quote
