yoshi's wj build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > yoshi's wj build
All Bilstein shocks & struts - Lowest Prices Ever and TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!
Unread 07-20-2014, 07:59 PM   #1
yohshua
yoshi's wj build
so I figured i would give this a try and show off my build/fix up to my 2000 wj laredo 4.0 l6
i got her just at the right time back when winter first hit
back then i didnt get much done with the cold was waiting for it to get warmer out
once the weather got warmer first this to do was see why my heat sucks all winter when i went to change my t stat and housing this is what i found,
now the new and old
now this this out the way and all the fluids changed i could move on to the rest of the truck
yohshua is offline   Reply With Quote Quick reply to this message
Unread 07-20-2014, 08:14 PM   #2
yohshua
back when i bought the jeep i had 3 things wrong the driver side fog light didnt come on, the idle was jumpy and the lift gate did not want to unlock
so it was time to take things apart and see what was going on first the fog light should just be a bulb change well this is what i found
this is what the outside looked like
and the bulb
i ended up ordering a new housing and bulb and now all works glad non of the wiring got messed up
now to the idle problem after taking apart the tb looks like all she needed was a good clean up
here's the tb and iac before and after
iac
lucky me but everything turned out to be easy fixes the last one on the list was the rear gate lucky for me as well it was just that the motor cover poped off and all i needed to do was put the gears back in and glue it closed and all work just fine after it
Unread 07-21-2014, 04:55 PM   #3
yohshua
so today it was time to change the old headlight assembly that was cracked in some spots and to my surprise i found some odd things
found this just sitting under the driver side headlight support
and it looks like the owner before me figured a smart way to keep the turn signal bulb from falling out
after getting the new support in i was able to put some new headlights as well the old ones were hazing
Unread 07-24-2014, 09:56 PM   #4
yohshua
had some spare time time to finally get the roof rack to look better it was really showing some wear.
truck looks odd without the rails
got all the parts painted looks so much better now almost looks new again
hopefully next will be my 2inch lift with coils and my bull bar
Unread 11-11-2014, 01:08 PM   #5
yohshua
reserved
Unread 11-11-2014, 01:09 PM   #6
yohshua
reserved 1
Unread 11-11-2014, 10:50 PM   #7
MoonyJohn
Blow on my Avatar
MoonyJohn's Avatar
Looking good! Saving another WJ from dying
MoonyJohn is offline   Reply With Quote Quick reply to this message
