Yes, it snows in Texas - Page 6 - JeepForum.com
post #76 of 90 Old 09-30-2010, 12:26 PM
1stblack97ZJ
Here in NC it is 78* and sunny! Awesome weather.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #77 of 90 Old 09-30-2010, 12:57 PM Thread Starter
SnowLeopard
Originally Posted by comptiger5000 View Post
I know. I'm fully expecting the cold. I just have to get the t-case linkage on the Jeep fixed, as I blew it up last weekend, so I'm stuck in 2wd. Hopefully that will be done this weekend or next, then I can get the tow hooks mounted.
I just hope someone didn't botch your rad support mounting like they did on mine. It was ghetto. The cross support from the fender on the passenger side to the rad support was zip-tied instead of bolted... And the bolt on that side holding the support to the frame was the wrong coarseness so it'd been forced in, then there was like 1/2" of bare metal under the bolt head as it wasn't intended for this use, so it wasn't even tight, and trying to back it out ended up with it snapping off. So it had to be drilled out, which killed several drill bits, darn grade 8 stuff, I'm thinking, and a new nut was placed over the nut welded into the frame, which we'd drilled the bolt out of, and everything was securely torqued down. What a pain the the tail. I never understand the 'let's just use whatever we have lying around even if it's not right' mentality. I do it right and know I won't have to worry about it later down the road.
SnowLeopard is offline
post #78 of 90 Old 09-30-2010, 01:07 PM
squashman702
1994 ZJ
You shouldn't have had to touch the cross supports to install the hooks. I've installed a pair and removed three different sets from other Jeeps and have yet to touch one.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #79 of 90 Old 09-30-2010, 01:09 PM Thread Starter
SnowLeopard
No, but I had to touch that one because it was zip-tied instead of bolted. Which turns out was part of why it made a clunking sound when making tight turns. The frame would tweak just enough without that support that two frame points would rub in one corner, just enough to drive me crazy trying to track down the source of the noise. It's nothing, but I thought it was something. The cross support being securely bolted made it go away. Go figure.
post #80 of 90 Old 09-30-2010, 01:14 PM
biggoofy
not on the coast lol 3 feet of water haha
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #81 of 90 Old 09-30-2010, 02:10 PM
comptiger5000
I'm gathering yours was in a front end accident at some point Snowleopard? I know mine hasn't had any body work in there.
comptiger5000 is offline
post #82 of 90 Old 09-30-2010, 02:58 PM Thread Starter
SnowLeopard
There was nothing in the Carfax report, and it looked mint when I bought it. There was no unibody damage at all. It just seemed like some redneck backyard mechanic worked on it once upon a time. But yeah, if they were in an accident and it was minor enough, they might've fixed it themselves and never reported it. There's really no telling with a 13+ year old vehicle. At least I've worked out all the kinks now...for now.
post #83 of 90 Old 09-30-2010, 03:52 PM
squashman702
1994 ZJ
Could've been a radiator replacement out of the bottom at some point. Doesn't make much sense but one could do it that way.
Think Twice Garage
post #84 of 90 Old 09-30-2010, 06:15 PM
1stblack97ZJ
Bummer
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #85 of 90 Old 12-02-2010, 10:41 AM Thread Starter
SnowLeopard
If it doesn't snow here soon, I'm going to go stir crazy. I want to see the epic snows of last winter repeat themselves. So very much fun were they.
post #86 of 90 Old 12-17-2010, 08:40 PM Thread Starter
SnowLeopard
Well, we got some snow last night and throughout the day. It melted more than it stuck after the temp warmed up this morning, but I got pics when I went out to clear off the Jeep so I could head to work.
Two before I cleared it off;
And now cleared off;
I know it's not really exciting, but most of the stuff was melted from the streets and only remaining on grass and houses along with trees by the time I got off work this evening. It was also dark. I drove around a bit, but there was nothing worthy of wheelin' so I just came home.
post #87 of 90 Old 12-17-2010, 08:43 PM
bumzo1
2005 WK
Where are you located? in DFW we haven't gotten a flurry of snow
'05 WK 3.7L | OME MD lift | 255/75/17 BFG M/Ts | 20" LED Light Bar
Khaki WK Club Member #1
bumzo1 is offline
post #88 of 90 Old 12-17-2010, 08:45 PM
vanillathrilla
We got about 4-5 inches here on Thursday but the roads are already cleared today. Sucks! I wasted most of the day Thursday working when everyone else called in. I could have been out playing in the TJ!
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #89 of 90 Old 12-17-2010, 08:47 PM
bumzo1
2005 WK
That's the problem with jeeps, you can't call in and say you're stuck
bumzo1 is offline
post #90 of 90 Old 12-17-2010, 09:01 PM Thread Starter
SnowLeopard
I live in the northwest Panhandle. We tend to get a lot more snow up here than you all do.
You're telling me. My boss called to make sure I was going to be able to get out okay today to get to work. I was like...I'm the one that hauled everyone, EVERYONE, around to and from work and to run errands and such last winter when the big snows hit. Me and my Jeep with bald Michelin MTS 235's did it. Her FWD Pontiac Torrent, unable to get 2 feet. The others' 2wd Tahoe, 2wd Dakota, Pontiac van thingmabopper...no go. But sure, 5 inches of wet snow is going to stop me Jeep now with new 30.5" AT's. I didn't even need 4wd for goodness sake. Obviously. So yeah, no calling in saying you can't get to work. Btw, she's got a Cadillac SRX with AWD now. So she's lovin' that and thinking she's got it made. LOL I will say that it has impressive ground clearance for a crossover, but the fact is that it's still a CUV and yet it gets perhaps 22-23mpg at best. I'm not sure what the point of the trade-off is. For that it cost, I'd have bought a Limited WKII. She liked how it looked though, and that was her only deciding factor in buying it...
Central Texas - Around Austin BigOrange90YJ Wrangler General Discussion 7 09-23-2009 11:22 PM
Mechanic in Houston, Texas caflisch ZJ Grand Cherokee Forum 2 04-22-2007 04:28 PM
Texas A&M Jeep XtremeJeep ZJ Grand Cherokee Forum 13 09-12-2006 09:41 AM
Texas ZJ1,Airmanwoody---- michiganmaveric ZJ Grand Cherokee Forum 5 11-21-2005 05:08 AM
Question for TEXAS ZJ1 or WVD nashmd454 ZJ Grand Cherokee Forum 17 02-11-2005 09:23 AM
