wvracer821's WJ build - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > wvracer821's WJ build
Unread 01-05-2014, 01:07 PM   #121
wvracer821
wvracer821's Avatar
Just ordered all the hardware from ruff stuff to build my 3 link front
last night i managed to get the front 6.5" coils and shocks installed. ill do the rears when i get some more time off from work. i took it for a quick spin down the road with just the front set up and the OME HDs in the rear i expected short arms with 6.5" of lift to be much worse on the road then it was. then again it might help that the Cs on my front end were cut and turned by skain8 to correct castor. over all im happy with the ride of the IRO coils and the Procomp 9000 shocks.
Thanks again Kolak for the hook up.
the OME HD coils and the Matching Bilstein 5100s will be up for sale when i get the rears pulled.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread: http://www.jeepforum.com/forum/f197/...build-1436556/
http://www.pirate4x4.com/tech/
wvracer821 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2014, 11:24 AM   #122
wvracer821
wvracer821's Avatar
i got the 6.5 coils put together so i could start measuring for the arms.
im also selling my OME coils here on the forum.
http://www.jeepforum.com/forum/f127/.../#post19373825
now for some giant coil, short arm, and tiny tire pics
Junk: 2000 WJ, 4.0L
Unread 02-08-2014, 03:50 PM   #123
wvracer821
wvracer821's Avatar
i used the jeep quite a bit on my last set of days off. we got about a foot of snow and my 8k lb. truck is helpless.
i even got the chance to get a few buddies together and do some night time snow wheeling to a spot we like to go.
Junk: 2000 WJ, 4.0L
Unread 02-10-2014, 03:34 PM   #124
wvracer821
wvracer821's Avatar
the parts are starting to pile up!
Junk: 2000 WJ, 4.0L
Unread 03-30-2014, 11:45 AM   #125
wvracer821
wvracer821's Avatar
well. its been a while since i have really done anything to the jeep. I've been working like crazy and have been out of town for quite a while. I did manage to stumble across a killer deal on a set of axles. Thursday I'll be picking up a Dana 60 front and a Ford 10.25 rear from a 95 F-350. The deal was too good to pass up and I've been in search for a front end for a while anyway. They are loaded from hub to hub with brakes and everything and came right out of a truck that the guy drove to his house before tearing it down. The plan is a lunchbox locker front, welded rear, and either 5.13s or 5.38s. at this point this is cheaper than finishing the 9 and a whole lot stronger. plus i can bolt on Hummer wheels and tires no problem which saves a ton of $$$. ill update this with pics at the end of the week when i have the axles in hand. on that note ill have a bunch of ford 9" stuff up for sale if anyone is interested
Junk: 2000 WJ, 4.0L
Unread 04-07-2014, 01:57 PM   #126
wvracer821
wvracer821's Avatar
here are some pics of the goods. also the start of a well trim to the rear wheel wells. plans are to move the tank back as far as possible to make room for the sterling. possibly moving the upper spring perches depending on the placement of the 37s when its all in place
Junk: 2000 WJ, 4.0L
Unread 04-25-2014, 06:24 PM   #127
fosterjd79
What are your plans to bring the steering geometry back to normal?
fosterjd79 is offline   Reply With Quote Quick reply to this message
Unread 04-28-2014, 01:12 PM   #128
wvracer821
wvracer821's Avatar
i just plan on making my own track bar and drag link so they stay as parallel as possible. most likely running the tie rod on top of the fords factory steering arms and using ruffstuff's y link kit with GM 1ton TREs
http://www.ruffstuffspecialties.com/catalog/YLINK.html
Junk: 2000 WJ, 4.0L
Unread 04-28-2014, 02:38 PM   #129
wvracer821
wvracer821's Avatar
I got some days off finally and the weather has been nice so I got some work done on the jeep.
I've been in North Dakota doing a lot of this
But I finally got around to finishing the rear trim on the passenger side. It started to rain about 10 seconds after I started painting but I didn't let it stop me
I also continued on my cross member + link mounts for my long arms that are in the making.
I got a new battery for my trusty steed so I can enjoy some of this warm weather.
Then on Sunday after some light wheeling Saturday night I got to load up the Tow pig. I had to pull a friends JK home and he let me use the trailer to pick up another truck that a family friend was giving away. specs on the truck are 1995 GMC 3500 6.5L Turbo Diesel 4x4, 5 speed, power everything. I'm not sure what to do with the truck, I guess Ill see what happens when its up and running. It needs a little work to be road worthy.
Junk: 2000 WJ, 4.0L
Unread 04-28-2014, 09:09 PM   #130
wvracer821
wvracer821's Avatar
I have had some trouble with getting mud and water into my factory intake because the "snorkel" that goes from the box to the grill has been missing for years now. I have been looking around for intake ideas and I came up with this from a wrangler intake that I saw, When I started doing research on it I found that Sprectre sells a CAI kit that runs into the Cowl for the TJ. All the parts are Spectre universal pieces. I had to use a piece of foam behind the mounting plate because the firewall is not exactly flat. Everything worked out great and I only had to trim a half inch off of the 90* tube. my only complaint is that it is a little loud and it does have the Ricer WOOOOSHHHH sound to it but at least it will stay dry.
Spectre Part Numbers for the peices
9833 - Inline Airbox with Cartridge Filter - 4" Diameter Housing - 3" Inlet/Outlet
94990 - 3" Elbow 90° Air Intake Tube with 6" Leg Ext.
8148 - 3" Plastic Intake Tube/Duct Mounting Plate
8771 - Air Cleaner Tube Coupler/Reducer 3" with 2.5" Insert - Black
8751 - Air Cleaner Tube Coupler/Reducer 3"-2.5" - Black
8791 - 3" Air Intake 90° Elbow Tube Coupler with 2.5" Insert - Black EPDM
Junk: 2000 WJ, 4.0L
Unread 05-18-2014, 05:37 PM   #131
huffy089
Hey how did you make the custom tow points?
huffy089 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2014, 08:46 AM   #132
wvracer821
wvracer821's Avatar
I bought it from a member on the forum. his dad owned a fab shop. Its basically 2 pieces of angle and a piece of 2x2x1/4 with some pre cut tabs welded in
Junk: 2000 WJ, 4.0L
Unread 06-09-2014, 09:20 PM   #133
wvracer821
wvracer821's Avatar
No jeep updates but i did pick up a new DD/Tow pig
2014 Ram 3500 Mega cab
Junk: 2000 WJ, 4.0L
Unread 06-10-2014, 05:32 PM   #134
fosterjd79
Nice!
Unread 06-10-2014, 10:12 PM   #135
jeepin_jason
Awesome!
jeepin_jason is offline   Reply With Quote Quick reply to this message
