wvracer821's WJ build - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > wvracer821's WJ build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Win a free set of 35" or 37" tires from Zone Off
Unread 05-15-2013, 01:20 PM   #91
WJChris
Four Badges
WJChris's Avatar
I would suggest NOT putting it on the pass side. It creates a more dangerous blind spot.'
I know some who can get by with only 2 side mirrors, but why have it in the way when its just as easy to have it on the drivers side. The weight is non issue when the latch is locked.
WJChris is offline   Reply With Quote Quick reply to this message
Unread 05-16-2013, 07:14 AM   #92
adavis39
looking good man.....where did u get the latch from? it looks pretty beefy and I need to upgrade the one on my carrier since I broke it
and Im finally getting your old steering set up on......its only been 4 months hahaha
2002 WJ Limited [B]4.7[/B]: 6" Clayton REALLY long arms....yep, they are longer than yours [B]SOLD : ([/B]
1998 Platinum [B]5.9[/B] DD
2007 WK Overland [B]5.7[/B] wifes DD
TNJEEPS.COM
BUILD: [B][url]http://www.jeepforum.com/forum/f197/utwj-build-other-crap-1399123/[/url][/B]
[B]"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"[/B]
adavis39 is offline   Reply With Quote Quick reply to this message
Unread 05-16-2013, 09:29 AM   #93
wvracer821
Latch came from reid supply.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread: [url]http://www.jeepforum.com/forum/f197/wvracer821s-wj-build-1436556/[/url]
[url]http://www.pirate4x4.com/tech/[/url]
wvracer821 is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 08:57 PM   #94
wvracer821
finished the carrier today. i was rushed to get it done because i leave for South Dakota in the morning. im happy with the final product. no for the pics!
Junk: 2000 WJ, 4.0L
Unread 05-25-2013, 09:11 PM   #95
dillonjm
30mm@70/sec
dillonjm's Avatar
I like it man, looks good!
03 Rubicon (Weekend Toy) Build thread
11 Ram 2500 - H&S tuned 6.7 Cummins (DD/Tow Rig)
05 Liberty Limited (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 11:09 PM   #96
99WJ539918
That looks real good. I understand the desire to put the tire on the driver's side, but I'm sure you'll get used to it on the passenger side. Very nice build, too.
99WJ539918 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2013, 06:50 AM   #97
wvracer821
Thanks guys. I dont really look out the back window anyway. Thats what mirrors are for
Junk: 2000 WJ, 4.0L
Unread 06-19-2013, 09:23 AM   #98
Jeepforthewin
2010 JK Wrangler
How is that light bar holding up for you so far? Im thinking about ordering one.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 04:47 PM   #99
dillonjm
30mm@70/sec
dillonjm's Avatar
If it makes you feel better, mines on the driver side and my rear view is worthless too. I don't think you would have gained or lost anything by putting it over there..
Still think it looks good.
Unread 06-19-2013, 06:21 PM   #100
wvracer821
the light bar is holding up great. i cant wait to get home and start wheeling again.
Junk: 2000 WJ, 4.0L
Unread 07-07-2013, 06:10 PM   #101
wvracer821
A little update here. the jeep has been heating up on these hot summer days and im not sure why. i tossed a new thermostat in there and it didn't help a bit. i ditched the spal fan and put the stock one back in. the radiator is less than 6 months old and is not leaking. im not really sure what im going to do. im thinking maybe its running on the rich side causing it to heat up. im averaging about 11-12 mpg under normal driving. there isn't any CEL and the fan is running as it should. ive never had this problem and im at a brick wall with it. on a better note i plan on picking up a new 2013 ram 2500 as a DD in august so the jeep will become a project for me to play with on my days off.
Junk: 2000 WJ, 4.0L
Unread 07-08-2013, 08:27 PM   #102
WJChris
Four Badges
WJChris's Avatar
Rich will run cooler, lean is hotter. Make sure all the air is purged out of the cooling system.
Unread 07-08-2013, 09:25 PM   #103
wvracer821
i checked for air a couple times and nothing that i can see is out of normal. not really sure what is going on.
Junk: 2000 WJ, 4.0L
Unread 07-09-2013, 05:56 AM   #104
dillonjm
30mm@70/sec
dillonjm's Avatar
Cracked exhaust manifold? O2 sensor issues?
I'm not sure how common it is on the WJs but the Wrangler side's 4.0s are notorious for cracking exhaust manifolds which causes fuel mixture problems.
That said, it would be a kinda obscure reason you were getting warm.
Unread 07-09-2013, 03:59 PM   #105
wvracer821
im not sure whats going on. there is no CEL so i would assume the mixtures are close to being alright. i may try to put a water pump on it to see if maybe the blades are chewed up. it does great if it stays about 70* out. ill look into it more when i get some time off. luckily its only a 10min drive to work so it cant heat up too much.
Junk: 2000 WJ, 4.0L
