wvracer821's WJ build - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > wvracer821's WJ build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE Shipping Sale!FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-06-2013, 08:23 PM   #76
Justin_WJ
Could be a sticking caliper.
2000 WJ Limited, 4inch RC X, 242 T-case swap, 33x12.50 STT's, 15x8 D window wheels with 3.75 BS, JKS ADJ. Tracbar, T-case armor, Custom front winch bumper, Smittybilt XRC 8, 4.56's Extended Rola Rack w/Harbor Freight 6" lights, and always muddy :)
Justin_WJ is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 08:30 PM   #77
wvracer821
wvracer821's Avatar
both are newer and one wheel doesn't seem hotter than the other after a long drive so idk. im going to check into it more after my finals this weekend
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread: [url]http://www.jeepforum.com/forum/f197/wvracer821s-wj-build-1436556/[/url]
[url]http://www.pirate4x4.com/tech/[/url]
wvracer821 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 08:49 PM   #78
Justin_WJ
It may not be sticking, one set of pads could have grease on them, one set could be worn differently, could be getting more pressure in one of the calipers,one of the rotors may be worn differently, could be lots of things.
Unread 05-06-2013, 08:58 PM   #79
wvracer821
wvracer821's Avatar
Yeah i did notice when i put the brakes on hard it tracks straight as an arrow.
Junk: 2000 WJ, 4.0L
Unread 05-07-2013, 07:08 PM   #80
kc2mrg
Well then I wouldn't think it would be brakes I mean the only thing that happened is your axle moved slightly over to the right side of the jeep when the spacers were taken out but that's it I mean I put my 2.5" in and the alignment never changed except caster and never had any pulling issues
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 04:50 PM   #81
Justin_WJ
I say just go get a professional alignment done
Unread 05-08-2013, 08:15 PM   #82
wvracer821
wvracer821's Avatar
it drove fine the last 3 times ive aligned it on my own. never had any odd tire wear either. i think its my wheel bearing its starting to make a bit of a noise when taking sharp left turns at speed. i just dont have the time this week to mess with it. with finals and then having to work on top of it i probably wont get to it until Sunday if im lucky
Junk: 2000 WJ, 4.0L
Unread 05-11-2013, 01:38 PM   #83
wvracer821
wvracer821's Avatar
Switched out my tool box in the jeep. Made an upgrade to a snapon one I've had for a while. Just have to get the tire carrier done so i have room to mount my CO2bottle in the trunk
Junk: 2000 WJ, 4.0L
Unread 05-13-2013, 05:28 AM   #84
wvracer821
wvracer821's Avatar
More tire carrier build pics!!! hopefully i can get some more done on it this week. I'm headed tonight to look at a truck for a DD. 2009 Dodge 2500 cummins 6 speed. deleted and has a smoking problem! a guy at work is trading it in for a new one so i offered to pay what the dealer would give him on trade.
anyway back in the real world.....
+20HP
and one of the truck
Junk: 2000 WJ, 4.0L
Unread 05-13-2013, 05:07 PM   #85
silentbob21
Tire carrier looks great. That's same way I would have built latch. I just wish there was a way to make the bumper cuts look better, but oh well. How much you have invested in the carrier so far or what you think total cost will end up being.
Aaron
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 05:19 PM   #86
wvracer821
wvracer821's Avatar
Latch was 60 carrier kit from a to z was 90$ i got the steel for 60$ but i got an entire truck load of 12' sticks so here plenty to make sliders with. Oh and a lighted plate frame from genright 50$. I think that's it
Junk: 2000 WJ, 4.0L
Unread 05-15-2013, 07:09 AM   #87
wvracer821
wvracer821's Avatar
more carrier pics. i got everything all tacked up. i plan on burning it all in this weekend before graduation. im going to move the tire 2" closer to the jeep. i still want to leave some room to grow into bigger tires. but over all i feel like it came together well.
Junk: 2000 WJ, 4.0L
Unread 05-15-2013, 07:27 AM   #88
rickcricket
Surprised you didn't put it on the other side. Seems like the line of side isn't too bad though.
Looks bad@ss!
rickcricket is offline   Reply With Quote Quick reply to this message
Unread 05-15-2013, 07:54 AM   #89
wvracer821
wvracer821's Avatar
I was concerned with the weight and the leverage so i put it as close to the hinge an i could
Junk: 2000 WJ, 4.0L
Unread 05-15-2013, 10:53 AM   #90
rickcricket
Makes sense I guess. I say that but when mine is built I will probably do what you did.
