Worst injury while working on on your rig - Page 2 - JeepForum.com
post #16 of 25 Old 03-29-2013, 10:47 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Pulling the rear driveshaft and laying directly underneath it, lost my grip and got cold-cocked by the shaft. Loosened 2 teeth, 1 of them abscessed a couple months later and needed a root canal.
That root canal failed back in October of last year, so now I have one less front tooth
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #17 of 25 Old 03-30-2013, 01:46 AM
206wj
Installing clayton 4.5" springs. Have jeep on jack stands with thick blocks of wood under them to get the extra height. Right side goes fine, Move on to the left; I get the spring out, and start putting the new one in when....
.... Snap! Bang! The wood snapped in half and the jeep falls. Wouldn't have been bad, but my thumb was inside the coil...
After jacking the car up with my left hand to get out, a phone call, fun ambulance ride, and 2 surgery's my thumb got put back on!!!
Factory 242HD, 4.5 Lift with LAs, 285/70/17s, OME SS, Arb Front bumper with WARN 9.5xp with MasterPull synthetic line, Piaa 550 Driving lights, JCR sliders, Custom rear bumper with tire carrier, and piaa 510 backup light, ARB, 4.56 Gears, Viair 200psi OBA kit with dual tanks, LED rock lights,
206wj is offline
post #18 of 25 Old 03-30-2013, 09:21 AM
imaguy3
Nothing too bad, was just breaking loose the nut on the tie-rod end that connects the draglink to the pitman arm. When it broke loose I ended up punching the frame with my hand. Somehow my pinky nail got caught and folded up. It doesn't look that bad in this pic. (I took this immediately before it started to bleed and hurt). But once it came time to pull the skin off the nail to cut the nail away it started to look pretty gross, I ended up having to cut off the front half of the nail.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #19 of 25 Old 03-30-2013, 09:32 AM
AnotherRedZj
I've done that! That looks like it was taken at the, still laughing at yourself for being a dumb ***, phase of the injury!
I know it well
AnotherRedZj is offline
post #20 of 25 Old 03-30-2013, 10:41 AM
imaguy3
I know it well
yeah, it was the crawl out from under the car, look at my hand and go "what the hell is that b/c it doesn't hurt"...
Then open a beer and use it as "ice" b/c the throbbing was so bad...
imaguy3 is offline
post #21 of 25 Old 03-30-2013, 11:01 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
another thread illustrating the dangers of using wood or cinderblocks and brick as jack stands. never, ever use blocks or wood for extra height.
ratmonkey is offline
post #22 of 25 Old 03-30-2013, 05:21 PM
Timo_90xj
Timo_90xj's Avatar
Working today on the ZJ and XJ removing a 249 and a 242:
* Several bleeding cuts and scratches on both hands
* Couple nice bruises from slipping the 242 and landing it on my left hand
* Got fairly dizzy from inhaling the brake cleaner fumes and drinking a few beers
* Got some oily crap onto my eyes and in my mouth
* Snap ring came flying off the snap ring plyers, hitting me in the nose (this was before the brake cleaner and beer)
In other words, a fairly normal day working on the Jeep
I haven't had any real serious injuries, but a couple close calls and several mild ones like having pretty much every possible liquid in my eyes (I'm suprised I can still see ), the normal bruises and cuts on my hands, etc...
The worst close call was when I was in the army, we were doing some routine maintenaince on a large army truck close to the battery tray, when a friend of mine dropped a wrench right between the battery poles on a 24V quad- battery system. We took off pretty fast, the last thing I remember seeing when I looked back was the glowing red wrench Didn't take too long for the batteries to launch towards orbit. Good thing was at that point we were about 10 meters away behind a wall. It was a mess, wasn't too nice cleaning the remnants of the battery acid and all other crap
The funniest must've been when I was rebuilding the top-end of a V6 DOHC engine a few years ago during summer holiday. We got fairly drunk during the warm summer day with a couple of friends, figured it was time to stop working on the engine when I ended up falling head- first into the engine bay and it took quite a few efforts to work my way out of there. I guess we had a bit too much beer that day.. The engine came out good though, and fired up on the first start
***Under construction***
Timo_90xj is offline
post #23 of 25 Old 03-30-2013, 05:26 PM
Timo_90xj
Timo_90xj's Avatar
Cinderblocks are a big no-go, but wood is a completely different story IMO.
Properly placed and proper type wood blocks can support tens of thousands of pounds of weight, spread the loads evenly and add friction. We use hundreds of pounds of wood every day at my workplace for load- spreading and supporting heavy equipment for ocean-going shipments etc.. The problem is, if they are placed wrong or are wrong type, you most likely end up with an injury.
post #24 of 25 Old 03-30-2013, 05:57 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Was installing IRO skid and drilling holes in the frame, I had safety glasses on but the wind picked up and metal shavings went into my left eye. Went to the doctor 3 times before they finally found all the pieces. That was a terrible 3 days.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #25 of 25 Old 03-30-2013, 06:08 PM
Timo_90xj
Timo_90xj's Avatar
I had a similar thing happen at my workplace; tiny metal shaving found it's way to my left eye, almost rupturing it. Had to go to an eye- specialist three times for them to get it all off my eye. It felt horrible when the piece of metal was in my eye, and even worse when they got it off. I didn't see much of anything other than blur with my left eye for the next 4-5 days. I'm still having some troubles with my left eye, and it's been about a year now since the incident.
