WJ Lift? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > WJ Lift?
New Product Release: Flowmaster Force II Dual Tailpipe AxlFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIJeep Long Arm Upgrade Kits on SALE for as low as $649.95 S
Unread 04-20-2015, 11:46 AM   #1
OffRoadingChick
WJ Lift?
Woohoo... it's time to lift my memorial WJ for my bro!
Right now, I need something more or less inexpensive, so the plan of 4.5-6.5 has to be put on hold So, Im thinking 2" with beefy tires.
What 2" lift would you recommend? And what size tires? Wanting mean, beefy tires.. not too big that it looks silly though, lol.
And... if you have lifted your WJ... post pics!!! Include what you've done
OffRoadingChick is offline   Reply With Quote Quick reply to this message
Unread 04-20-2015, 12:16 PM   #2
99WJ539918
I installed a 2.5"/2" BB from JGCParts that I got on eBay. I plan on running 245/75/16, but some people run larger tires. Pics are in my build thread. Once you lift it you might run into other issues with worn out suspension components. Good luck.
99WJ539918 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2015, 11:53 PM   #3
SteeleJay
Vulcan Ambassador
SteeleJay's Avatar
Depending on your budget, you might want to just do a BB (budget boost - basically just spring spacers) to get the two inches of lift, then do a long arm later on when funds are available. The BB has very little impact on ride quality. The upper lift limit for the stock short-arm setup is about 4" max - you want more than that and you'll need a long-arm setup. As to tires, with only 2" of lift, you're not going to be able to get much larger than a 30-31" tire in there without some trimming. I'm at 4.5" lift on my LA and I had to get pretty aggressive with trimming the front bumper cover and fender liner just to fit my 32s.
You can see my build thread here: http://www.jeepforum.com/forum/f197/...build-3066009/
Stress is the result of the mind overriding the body's desire to use a hammer to make a part fit where it was supposedly designed to fit.
I Jeep, therefore I swear.
SteeleJay is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 05:49 AM   #4
derekmac
derekmac's Avatar
If planning on going bigger later, just get the BB spacers. Willing to do some cutting? If you are, you can fit 255/75-17.
This is mine with the BB, trimmed and 32's.
2002 WJ Olympics Commemorative Edition
32" BFG Mud Terrains | Custom Sliders
2" BB | Viair OBA
Build thread.
derekmac is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 03:53 PM   #5
OffRoadingChick
thank you!!!!!! sexy rides
Im debating tires now... between 245/75/16 (i have 245/65/17 on now, and i can't wrap my head around paying $1000 to go a tiny bit bigger…. ??) and 265/75/16. The lift seems to be the easy part LOL
Unread 05-02-2015, 08:24 AM   #6
ZJPunk98
you could go with Kolak's OME lift it will get you 2-3". more expensive than a BB spacer kits because it uses taller springs and shocks. I got 2" out of his lift, some people get more.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote Quick reply to this message
