WJ Build Thread - Page 16 - JeepForum.com
post #226 of 252 Old 02-07-2012, 03:01 PM
MWyatt
I'm liking the D44 swap. Did you buy a complete axle and pull the tubes or just a separate housing? Also how did you go about adding the transmission cooler? That's something I want to do but don't know where to mount it.
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #227 of 252 Old 02-08-2012, 07:04 AM
240impala
2003 WJ
I added a cooler to mine fairly easy mounted it to the radiator. And just pulled the rubber hose off the metal line added a longer hose to the cooler and ran it to the radiator line
"Don't Do It"
IRO 6.5" lift, IRO Front long arms, rear iro adj upper a arm and adj rear lower, custom 4x4 fab front bumper, rough country winch, 15" crager soft 8's, procomp 35-12.50 tire, fenders trimmed KOR light bar, malone roof rack
240impala is offline
post #228 of 252 Old 02-19-2012, 07:56 PM Thread Starter
tsconver
2003 WJ
Originally Posted by SnowLeopard View Post
You have one of my favorite WJ's out there. It's a great piece of mechanical engineering and fabrication work. What's the difference between the 5100's and the 5125's? I have 5100's front and rear.
The 5125 is not application specific, it is basically a 5100 with standard valving and can be had in almost any length so you can get the length you need versus compromising on length or application. FOr instance a lot of the 5100 shocks at 6" of lift are 3" lift TJ rears so teh vaalving is for a lighter vehicle.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #229 of 252 Old 02-19-2012, 07:58 PM Thread Starter
tsconver
2003 WJ
JUst ordered a IRO tierod. Will post some pics when I get it installed, was missing hardware or I would have it on already. Hopefully they can express me out the missing parts Monday. Will have my JKS tierod for sale once teh conversion is done and the kinks worked out. THe IRO unit is over teh knuckle and uses heims where the JKS is beefy but still uses factory TRE's and is still low and exposed to rocks.
A few goodies
2006 Red Liberty
tsconver is offline
post #230 of 252 Old 02-22-2012, 12:01 PM
Trevino
Wow, pretty sweet build man. Can't believe this is the first time I come across your build thread. Keep up the sweet work man.
Trevino is offline
post #231 of 252 Old 02-23-2012, 06:27 PM
MWyatt
I'm interested in how the IRO tie rod is. It's something I've been considering. Can't wait to see pics and hear how it is!
MWyatt is offline
post #232 of 252 Old 03-07-2012, 05:10 PM Thread Starter
tsconver
2003 WJ
Still need to install it. Been playing with my bike lately.
A few goodies
2006 Red Liberty
tsconver is offline
post #233 of 252 Old 03-29-2012, 12:08 AM
snobrdrkid07
snobrdrkid07's Avatar
I was reading through again, and I believe you had installed an aux trans cooler. If you did, do you have any pictures or suggestions that you could give me for when I install mine? Thanks!
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #234 of 252 Old 03-30-2012, 05:56 AM Thread Starter
tsconver
2003 WJ
not sure if I have any pics. It is pretty easy install, just use the zip tie fasteners on mine and added it in front of tranny line coming from the tranny to the bottom of the radiator, then to the the AC condensor. Ran the output from the radiator cooler to the aux tranny cooler then the I ran the output from the aux cooler to a spin on filter then back to the tranny. I like being able to quickly swap a new spin on filter onto the tranny adds a little extra filtration to the pancake filter and adds about a quart of extra fluid for additional fluid volume which also helps with cooling.
A few goodies
2006 Red Liberty
tsconver is offline
post #235 of 252 Old 03-30-2012, 05:59 AM Thread Starter
tsconver
2003 WJ
I got the IRO tierod installed, went really well, did not even have to remove teh tires, would have been easier if I did but was not required. Measured the width from two marked spots on my tires for a before width and then set the new tierod to get back to that width so I did not need to do an alignment.
Steering is tight, it is up higher, gives a lot of clearnace between the dif cover and the tierod, my old tierod actually rubbed my diff cover as I have an aftermarket diff cover. Also removed one of my SS that was really dented and probably not doing anything and so far no DW, knock on wood, :-)
Will try to get a few pics up of it.
A few goodies
2006 Red Liberty
tsconver is offline
post #236 of 252 Old 03-30-2012, 10:36 AM
snobrdrkid07
That is what I planned to do as well. Run the aux cooler after the factory cooler. So it would be, fluid from the trans, into the factory cooler, out the factory cooler, then in to the aux, then out the aux cooler and back to the transmission. Is your factory trans cooler in the A/C condenser too?
I have been having conflicting research to show which of the lines is the feed and which line is the return. I want to run the aux cooler on the return line although I can not figure out which one it is!
-Michael-
post #237 of 252 Old 03-31-2012, 07:39 AM Thread Starter
tsconver
2003 WJ
What engine / tranny you have? Mine is the i6 n 42re. The original tranny cooler is in the radiator on mine. The return line on the i6 combos is the line without the check valve on the end of the steel tranny line. The chceck valve is on the output line from the tranny. Oh and take the check valve off and drill it out if you have one. No ill effect and lets the tranny flow more also running cooler.
A few goodies
2006 Red Liberty
tsconver is offline
post #238 of 252 Old 03-31-2012, 11:46 AM
snobrdrkid07
An 2004 with the 4.0/42re. My cooler for the transmission was in the ac condenser lol. That was the key information right there. The check valve is on the feed to the cooler/output from trans. I made a whole thread about it all here I basically just dove into the project yesterday afternoon after class and got it all done. I did not mess with the check valve or that line with the check valve on it. If you take that off, wont all the oil flow out and have to re-prime every time??
-Michael-
post #239 of 252 Old 03-31-2012, 07:01 PM Thread Starter
tsconver
2003 WJ
My check valve has been drilled for years no ill effect no lag when going into gear. most everyone that works on them drills them out.
A few goodies
2006 Red Liberty
tsconver is offline
post #240 of 252 Old 04-01-2012, 05:56 PM
snobrdrkid07
That is pretty interesting to know. Next time I am under there I will consider it. For now, I have had enough of the ATF bath! Thanks for the info!
-Michael-
GraKee99 WJ build thread GraKee99 Grand Cherokee General Discussion 666 12-08-2014 04:24 AM
WJ_Renegade's Build Thread XJ_Renegade Grand Cherokee General Discussion 32 12-18-2009 02:52 AM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
