Wj on 1ton dana 60's - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Wj on 1ton dana 60's
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 06-07-2011, 01:57 PM   #151
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
except you cant race stock class at KOH in a buggy
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 06-07-2011, 02:10 PM   #152
cherrybomb05
2010 JK Wrangler
Subbed!
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline   Reply With Quote Quick reply to this message
Unread 06-07-2011, 07:07 PM   #153
MGDWJ
I am not that worried about rolling my wj after the build because I would have the full cage inside and out. The main reason I am leaning to a buggy is because it is more capable. The way my dub sits now works very well for expedition type wheeling. Lol if I could just keep the damn front shafts from breaking. Maybe I should try a little less skinny pedal or just swap a 44 in the front.
I am not really wanting to compete in KOH I just enjoy huge obstacles and going fast.
WJ build thread.
MGDWJ is offline   Reply With Quote Quick reply to this message
Unread 06-07-2011, 08:10 PM   #154
AgitatedPancake
Honestly WJ's can be build plenty capable. There are only 3 (huge) limiting factors on these things compared to a buggy when you go all out on a build, weight, body width and rocker height. The weight is honestly a really interesting subject, and I personally do NOT think weight is such a bad thing. I use my WJ's momentum to my advantage all the time, by giving myself a rolling start on obstacles (and breaking 9"s haha), but it's own momentum pulls it up over obstacles. Also, trophy trucks are in the 6-7000lb range, and they are the role models of go fast
The other two factors are the huge ones that are hard to ignore. The WJ is a big sum***** no matter how you look at it. Width doesn't really limit me on the trails I'm generall attempting, but I've also given up my worry for body panels because of how often they hit. A lot of buggy chassis nowadays are in the 48" wide range, probably 2 feet narrower overall than our WJ.
Rockers are the final thing that totally screw us. Though if your thinking buggy, you should consider removing your WJ's doors permenantly and boatside like a foot up the sides (Like CrawlerReady's ZJ, great build). I've chopped out my rockers and knocked an inch and a half out of my doors for clearance. That's just about the max you can do while retaining fully functional windows, but it still bites me in the ***
Personally, WJ all the way
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 07-18-2011, 04:11 PM   #155
MGDWJ
Well it seems that the buggy deal has fallen thru the cracks. I am going to continue with my original plans for my dub. If all goes well I should start on it beginning of next week.
WJ build thread.
Unread 07-18-2011, 04:26 PM   #156
1stblack97ZJ
good choice!
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline   Reply With Quote Quick reply to this message
Unread 07-18-2011, 04:28 PM   #157
AgitatedPancake
You should check out my build thread for some inspiration, I'm getting rid of one of the issues with my WJ, the width of the front end with a sweet dovenose . I've taken 13" of width out of the grill, and am keeping the original headlights hehe
Unread 07-19-2011, 01:01 PM   #158
mtnmarc
I'll be glad to see some pictures of the build!
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 07-19-2011, 02:24 PM   #159
RedZJ
Taste Like Chicken
RedZJ's Avatar
http://www.mallcrawlin.com/forum/sho...ose-under-way*
ZJ Build
RedZJ is offline   Reply With Quote Quick reply to this message
Unread 07-19-2011, 02:32 PM   #160
AgitatedPancake
LOL! Red, marc is familiar with my build, I think he's excited to see pics in this thread haha
Unread 07-19-2011, 03:15 PM   #161
mtnmarc
Very familiar. Ha.
Unread 07-20-2011, 10:28 AM   #162
MGDWJ
Ill be glad to see it transform as well.
I believe the determining factor was last week I changed all of my ball joints with the adjustable flavor. After the job was done and them adjusted all the way in my tires where still not straight. After a closer inspection we discovered that my dana 30 housing is bent. Probably half an inch or more on the long side. That with the crushed control arm mount on the frame I decided it was best to go ahead and build the dub.
Hopefully in a couple of years I will get to build a bad *** buggy..... we will see.
WJ build thread.
Unread 07-20-2011, 12:07 PM   #163
mtnmarc
do you have plans to keep the arb bumper and design an exo around it?
Unread 07-20-2011, 12:42 PM   #164
MGDWJ
Plan was to tie the exo cage in to the ARB using some of these http://www.ballisticfabrication.com/...mp_p_1467.html that way if I have a need to remove the bumper later I still can with out a torch or grinder.
WJ build thread.
Unread 07-20-2011, 01:01 PM   #165
SnowLeopard
It's a shame that the buggy deal fell through. At least you've got plans for the dub though. I don't know how you do it. But my Jeep is my DD as well, and I fear tearing it up. So I'm overly careful. You've got plans that will iron out the damage though. So you're going through with the axle swap and the whole shebang?
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
