Winter jeep dd/beater - Page 2 - JeepForum.com
post #16 of 47 Old 10-15-2013, 01:04 PM Thread Starter
Thomahawk
Originally Posted by Thomahawk
Tried spare sensors from my another ZJ That was running before pulled apart, TPS, IAC, MAP, but still same, and readings Are within spec, thats why i am leaning back on the aftermarket CPS,,,? Also read in haynes manuell That the CPS have to be insert to the correct depth, the original should come with a paper spacer for the install. I was not able to push the CPS down, when i tightened the bolt, so it might not be seated 1000% in distance to the wheel inside, can this make it run, but to be off, how important is this?? Might re mount the CPS again later today if i find the time,
Tried to remount the CPS this Way, and push it down when tightened it up, no dice
Guess my next move will be a new Mopar CPS since it been adviced so many times now, just have to eliminate, right?
Or anything Ells i am missing???
Buildthread
Thomahawk is offline
post #17 of 47 Old 10-16-2013, 07:47 AM Thread Starter
Thomahawk
Changed to Mopar CPS,
Disconected battery,
New Champions spark plugs,
New spark wires,
Still not running correctly and wont idle,
I am about to give up on this 4.0 POS
Buildthread
post #18 of 47 Old 10-16-2013, 10:55 AM Thread Starter
Thomahawk
Got it running now, and idles perfect
Been reading in manual, and saw how important it is to Get the distributor assemblied the correct Way with piston #1 at Top Dead Center. PO did try to swap distributor from the other parts Jeep but aperently he didnt read the Hayness manual he gave me, and did it incorrect. The rotor was a notch of when i found TDC, then i disassemblied it and remounted after manual.
Now i have a Winter DD/Beater, SWEET
And thx to EVERYONE helping me out, highly apriciated,
THX GUYS BIGTIME!!!
Buildthread
post #19 of 47 Old 10-17-2013, 04:02 PM Thread Starter
Thomahawk
Licence plates tomorow morning, cant wait to Get it tested out
Buildthread
post #20 of 47 Old 10-18-2013, 10:20 AM Thread Starter
Thomahawk
Good Jeep day
Got licence plates,
filled air in tires,
Toped of with fuel,
quick wash,
Leather seats upgrade
Fix rear hatch panel,
Pulled parts and engine/trans/transfer from the blue parts ZJ, got some parts delivered and sold 2 sets with really bad Winter wheels, more money in return.
Buildthread
post #21 of 47 Old 10-19-2013, 09:52 AM Thread Starter
Thomahawk
Pulled axles and rest of what neededto be pulled from the part out Jeep today, got it ready for delivering to wrecker on monday morning, also sold some more parts
Replaced headlight bulbs on the Winter beater
Buildthread
post #22 of 47 Old 10-19-2013, 10:23 AM Thread Starter
Thomahawk
Here Are my other set wheels, just need some Winter tires on them
Buildthread
post #23 of 47 Old 10-21-2013, 09:40 AM Thread Starter
Thomahawk
Got the blue parts Jeep to the wrecker today,
Checked diffs and transfer fluid,
Front real Black fluid, didnt drain just topped off with .1qt, idk about color cause level was very low, added about 1qt!!!, transfer fluid looked ok, added .2qts.
The drivetrain howling DIDNT Go away though
Buildthread
post #24 of 47 Old 10-23-2013, 04:02 PM Thread Starter
Thomahawk
I checked out the front driveshaft today, in search of my howl, seems like the slip yoke have some desent play up/down and/or sideways,,,
Will try swap it to another one i have laying around from the other parts Jeep.
Also bought and mounted a really cheap Kenwood radio/mp3 headunit today
Very Nice to have some music to cover up on all Those rattles, vibs, and howl, lol
Buildthread
post #25 of 47 Old 10-23-2013, 06:14 PM
bananaslug
How did you get the parts Jeep on the trailer with no axles??
bananaslug is offline
post #26 of 47 Old 10-24-2013, 12:56 AM Thread Starter
Thomahawk
No problem, only need to use some old fashion wiking power, lol, no jkd
My friend who has the mech Work shop got all sorts off tools and equipment, also a fork lift.
Buildthread
post #27 of 47 Old 10-24-2013, 12:03 PM Thread Starter
Thomahawk
Today i tried to swap in the other DS i had laying around. Didnt cure the howl, bad pinion bearing Are my next guess, i am not going to Fix this.
Buildthread
post #28 of 47 Old 10-25-2013, 11:30 AM Thread Starter
Thomahawk
^^^But it did Fix my 60mph vibration though
Buildthread
post #29 of 47 Old 10-29-2013, 09:29 AM Thread Starter
Thomahawk
Today i desided to service my front diff, since oil was all Black and guggy at earlier check up.
Pop off cover, drained Black gunk, cleaned out magnet, cover, and gears with brake cleaner, RTV back together again.
While waiting i did a quick engine oil and filter change, with some oil i had laying around, so i only had to buy the filter.
Refilled the front diff with some spare 75w-140, also just laying around.
Didnt cure my howl, but atleast it has proper fresh fluid inside
Buildthread
post #30 of 47 Old 11-04-2013, 05:31 PM Thread Starter
Thomahawk
Been working on my friends ZJ engine swap last week, converted the 4.0 out of the blue 93 parts ZJ, into his 98 ZJ, which he got almost for free with a shoot engine
So we took the chance and pulled the engine out of the blue parts ZJ, noticed That the Transmission was not same, AW4 93 vs 42RE 98, Also all sensors, dizzy, torque converter, and more was different so we decided to use the block only from the 93, and swaped over intake, exhaust, dizzy, torque converter, flywheel and everything. New oil filter, rotor, cap, sparks and wires,,,
Ok, quite confident we done everything right, we tried to mount the engine, F, something wrong here guys flexplate dont line up with the engine/trans holes,,, WTF!!!
So by further investigating we found the AW4 and 42RE flexplates Are differ, auch bummer. So next, where the H is the other flexplate??? Everyone??? Its inside the blue parts Jeep already at wrecker 3 days ago,,,
Short story, 1 week later, another correct flexplate from Sweden, lesson learned the hard Way.
Thx.
Ok so this weekend the engine mounts in fine, no problems with That, flywheel boltet together with converter. Start to mount up power Steering, AC/dynamo,,,, AND serp belt F dont line up with the fan/waterpump wheel, auch!!!
Again lesson #2!!!
Seems like the 93 waterpump wheel have differ offset, and the the oil pressure sensor was different and we needed to buy another for the 98, plug was differ to. Lesson #3 i guess.
Ok, today monday morning comes, Lucky Jeep day today Got my hands on water pump and temp sensor, suprices me they got it on shelf, local, dirt cheap
I grabbed the parts, Went over to my friends shop and supriced him with the parts.
All Went well together, new water pump, temp sensor, and grinded off the tap That interfered with serp belt, then we mounted fan and radiator, AC radiator, hooked everything together, check all fluids, time for test start.
WROOOOOM at 2th attempt with the key, guess we needed to let the fuel pump fill the rail, wow cool jepp Jeep jippi, it started right up!!!
At first it got a bad rattle/tick
But after 2 min idle, we shut it down, Rechecked/toped off all fluids, then we let it idle for another 15 min,,,
tick/rattle sure gone by now, idles and runs smooth like a clock
Rechecked/top off oolant, engine oil, trans fluid again, another30 min idle, everything looked perfect, runs smooth and Nice, no Leaks so far, assemblied front fascia, grill headlights, test drove it around the block a couple times, runs strong and tight, everything checked out Good, all gauges shows perfect
Big thank to EVERYONE who helped out in Haralds shop and all info we got here at JF, it was a great adventure, also learned very much out of this project, Really cool to save another Jeep from the wreck yard, its sure a Nice Jeep, my buddy Will enjoy it
T 0||||||0
Buildthread
