The Wifes Jeep WJ "build" - Page 6 - JeepForum.com
post #76 of 107 Old 10-25-2010, 08:38 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Perhaps one end of the drag link end can still be threaded in (would require disconnecting that end from the pitman arm or knuckle)?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #77 of 107 Old 10-25-2010, 09:21 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
I tried threading it in as far as possible, but then I try to adjust it to straighten the steering wheel and it locks up, so I have to rotate the drag link the other way in order to get a straight wheel, thus offsetting the pitman arm.
-Dave
AustinCJer is offline
post #78 of 107 Old 10-25-2010, 09:26 AM
smunns
I don't think the pitman arm sits perfectly straight when properly adjusted. Do you feel you have the same amount of steering wheel travel in each direction when it's centered?
smunns is offline
post #79 of 107 Old 10-25-2010, 09:37 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
I know I do. I had the wife turn the wheel both ways and the knuckle "stopper" touched the axle on both sides when giving it a full turn.
I tried to compare the position of the WJ with my TJ, but the TJ's drag link is 3 piece, so its easier to reduce the length.
-Dave
post #80 of 107 Old 10-25-2010, 10:46 AM
1993ZJ
for the driver's side door popping... take a look at the hinge bushings. I am not sure how the hinges are set up in the WJ but on my ZJ my hinge bushings were bad causing some sag in the door and definitely causing some popping when operating the door. I would suggest the "HELP" section door hinges and bushings but they wore out on my jeep in less than a year ...
1993 ZJ 4.0L AX-15 2" BB Rola Roof Rack, Warn 8274, 235/75/R15 BFG AT's, that's about all for now...
1993ZJ is offline
post #81 of 107 Old 10-25-2010, 11:13 AM
smunns
It should be fine then. If it's got equal travel in each direction, it doesn't matter if the pitman arm is pointed straight or not. I'm pretty sure mine is off to one side.
smunns is offline
post #82 of 107 Old 10-25-2010, 09:29 PM
freakinheep89
I believe theres a write up floating around somewhere on the sagging door problem and a cheap fix using parts from autozone or somewhere vs the $60 from the dealer. What causes the popping is like he said the hinge bushings wear down and allow the door to sag, which puts increased load on the roller wheels that keep your door from closing on you, causing the pop. unfortunately I believe the hinge pins have a flat head on both ends and you have to drill off one end to remove them. If you cant find the write up try hosing them in PB blaster every morning for a few days, it restores rubber and poly bushings.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #83 of 107 Old 10-27-2010, 11:28 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Where can I get replacement clips for my door panel?
-Dave
post #84 of 107 Old 10-27-2010, 11:37 AM
smunns
Dealership, or New Jeep Grand Cherokee Parts: Door & Related Items.
smunns is offline
post #85 of 107 Old 10-27-2010, 11:53 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Holy ****. $24 for clips?
-Dave
post #86 of 107 Old 10-27-2010, 12:03 PM
ArloGuthroJeep
Mr. Hyde!
I bought 50 clips for $8 (or something stupidly cheap) the other day. Let me see if I can find out where it was.
post #87 of 107 Old 10-27-2010, 12:04 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Awesome, I only need a half dozen. If you have some to spare, id throw you a couple bucks.
-Dave
post #88 of 107 Old 10-27-2010, 12:05 PM
ArloGuthroJeep
Mr. Hyde!
Found em:
https://www.clipsandfasteners.com/Pr...uctCode=A20765
Fast delivery and the clips work great - happy with the quality. Make sure you order the right clips - different years had different clips.
post #89 of 107 Old 10-27-2010, 07:32 PM
freakinheep89
wait til the blend door in the HVAC fails. somewhere to the tune of $800 IIRC. shoulda got a ZJ
and i found the thread, this worked great for me though im not sure the WJ doors are the same but you can check at advance and see if the WJ part numbers are the same as these
http://www.jeepforum.com/forum/f13/z...1/#post3295899
TJ-
post #90 of 107 Old 10-27-2010, 07:57 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
I don't have the blend doors. Don't you worry bout that.
-Dave
2003 , build up , grand cherokee , jeep
WJ=Wifes Jeep. WJChris' Slow Build WJChris Grand Cherokee General Discussion 134 12-28-2011 07:03 PM
wifes wrangler broke afgd1 Wrangler General Discussion 1 03-14-2010 02:22 PM
The Wifes New Rubicon Wheels and BFG MTs lordfeyr WK Grand Cherokee & XK Commander Forum 8 10-23-2009 08:26 PM
Retired the wifes daily driver shiftless06 Wrangler General Discussion 9 06-01-2009 11:40 AM
Stumbling 4.0 in wifes GC? NYJeeper ZJ Grand Cherokee Forum 2 03-12-2003 05:51 PM
