The Wifes Jeep WJ "build" - Page 4 - JeepForum.com
post #46 of 107 Old 10-18-2010, 11:08 AM
SplitNail
I also hate oil leaks. My axle housing where the axle tube meats the center section "sweats" its really annoying.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #47 of 107 Old 10-18-2010, 11:28 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Originally Posted by ArloGuthroJeep View Post
I tried to get my "leak" fixed under my 7/70k warranty. They said it was "sweating" oil, not leaking So it wasn't covered. Remind me...4.0 or 4.7? 4.0's just leak - it is what they do and they do it damn well.
Mine never leaks enough to leave drips on the ground though, just enough to coat the bottom of the oil pan with oil.
4.0L... its enough to make a silver dollar sized spot overnight.
I hate that is a "new to me" Jeep and I am having so many issues... oh the WJ blues... Ill slowly fix stuff and hopefully square it all up. The reason i worry so much is because its my wifes Jeep, I need it to be reliable and safe.
-Dave
AustinCJer is offline
post #48 of 107 Old 10-18-2010, 11:40 AM
SplitNail
My jeep or my friends jeep has never left them stranded. Take that for what you want. Do you plan on wheeling that jeep? We have a club meeting this sunday if you wanna come.
post #49 of 107 Old 10-18-2010, 11:48 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
No wheeling, its my wifes DD... I know all my issues are easy. (Except the possible tranny issue, but again, I may just be paranoid)... I just got it yesterday, so its just me being manic, wanting it to be perfect TODAY... I just need a good solid weekend to work on it, but with a Rugby game this weekend and work next weekend, im stuck for a couple weeks. I may have to pull the night lights out and work into the wee hours of the evening, I just worry that doing that will leave us stuck without a vehicle if im not able to get it back together before morning.
-Dave
post #50 of 107 Old 10-18-2010, 12:17 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
I wanted to add a shot of the inside... when I got it, it was so messy it made me not want to even drive it, but after 3 hours and blood, sweat, and tears, I got it clean. It has a very nice interior once I got the 1 inch of crud off of everything. Dont let the crappy picture throw you off.
-Dave
post #51 of 107 Old 10-18-2010, 12:46 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
im on RockAuto... what would be the middle ground tie rod ends? i dont want cheap, but I dont want to spend $60 per tie rod end...
-Raybestos
-moog
-acdelco
-mevotech
-Dave
post #52 of 107 Old 10-18-2010, 01:28 PM
smunns
-Raybestos
-moog
-acdelco
-mevotech
Go to O'Reilly's and get their Master Pro tie rod ends. Great price, quality, and a lifetime warranty. I've been very pleased with them on my WJ.
smunns is offline
post #53 of 107 Old 10-18-2010, 01:35 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Good advice... at $20 a piece, that is in my budget.
I know some of you wont agree with this, but I think I am going to try to just put a zirk on the current ends and try to lube them. If I cant get them lubed or if they are damaged, then ill replace them.
Just found out my t-case fluid needs changing and my front diff needs servicing. So I need to save money any way I can.
-Dave
post #54 of 107 Old 10-18-2010, 02:16 PM
freakinheep89
if they are bone dry, the damage is done and greasing them wont help. they will have pitting and all sorts of damage.
Also Im willing to bet the bad idle is coil packs. like Arlo said, there are no plug wires, its COP. there is one coil on top of each spark plug. they are kinda pricey. Its typical for people to put off changing them for as long as possible because they cost about $40 each and theres 6.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #55 of 107 Old 10-18-2010, 02:28 PM
SplitNail
I HIGHLY doubt its the coils. It either works or it doesnt. You prolly need to clean the thottle body and Idle air control. Then get a new air filter and reset the computer. I wouldnt throw $240 just yet.
post #56 of 107 Old 10-18-2010, 02:33 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
How do I reset the computer? Is it disconnecting the battery for 20 minutes?
-Dave
post #57 of 107 Old 10-18-2010, 02:41 PM
SplitNail
Yes. Turn your headlights on and disco your battery and let it sit for like 2 minutes. That should reset everything.
post #58 of 107 Old 10-18-2010, 04:18 PM
freakinheep89
I wasnt recommending just blindly throwing $240 at it, just something to check. Coils dont just "either work or they dont", they can have issues that cause a weak spark and depending on the age of the plugs and the gap, they can cause a slight miss at idle. Ive seen it countless times on COP systems.
TJ-
post #59 of 107 Old 10-18-2010, 08:11 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Update:
-cleaned throttle body and IAC, replaced air filter, it idles like a dream now.
-tightened sway bar links, clunking stopped for the most part... Still a little clunk around corners, but it's Almost completely gone.
-I think the rear main seal is leaking. Its leaking at the bell housing. I changed the oil and added some leak protectant. We will see how that works...
-Dave
post #60 of 107 Old 10-20-2010, 11:32 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
quick little update.
-the leak additive has DRASTICALLY reduced the leak, and it says it works over time, so im hoping after a couple more oil changes, itll be practically gone.
-Doing all 4 TRE's this weekend. Im getting the ones from O' Reillys, per a suggestion from one of you, as well as a new steering stabilizer. I disconnected mine yesterday and its very easy to push and pull...
-Still running great since the TB and IAC cleaning. Going to do the same with my TJ, hope itll bring my idle down.
-I thought I felt my tranny starting to slip when I was stopping... at very low speeds, it feels slightly jerking going from D to N... but someone said it can be caused by the slip yoke... There is a big long write up on the JU website, so it just requires removing the driveshaft and lubing the slip yoke. Guy said it stopped the "bump stop" issue, as he called it. I am hoping thats all it is. The tranny is fine other than that issue, so i cant imagine its a tranny issue... oh well... I may do a tranny fluid change and get a new filter from mopar to ensure longevity
-As time goes on and I play with it, its slowly starting to run and perform to my standards... just needed a little TLC which the last owner apparently didnt give it... Plus I think he was full of **** when he said he had it fully serviced at the dealership.
I appreciate you alls input and help along the way.
-Dave
2003 , build up , grand cherokee , jeep
WJ=Wifes Jeep. WJChris' Slow Build WJChris Grand Cherokee General Discussion 134 12-28-2011 07:03 PM
wifes wrangler broke afgd1 Wrangler General Discussion 1 03-14-2010 02:22 PM
The Wifes New Rubicon Wheels and BFG MTs lordfeyr WK Grand Cherokee & XK Commander Forum 8 10-23-2009 08:26 PM
Retired the wifes daily driver shiftless06 Wrangler General Discussion 9 06-01-2009 11:40 AM
Stumbling 4.0 in wifes GC? NYJeeper ZJ Grand Cherokee Forum 2 03-12-2003 05:51 PM
