WiCkeDuDe's 02 WJ Build Up Thread - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > WiCkeDuDe's 02 WJ Build Up Thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 03-22-2011, 11:07 PM   #16
WiCkeDuDe
First off, take the tie rod end clamp and drill out the square bolt hole with a 31/64 drill bit. I will explain why later. I did mine in the pic on the vehicle but its easier in the vise.
Once done you need to spread the clamps out or unscrew your installed tie rods on your WJ. I wonder which you will pick? You need to spread them alot to go over the trackbar and draglink, so be careful not to break the steel. Once open enough slip the SS clamp over the trackbar. Then take the tie rod clamp and slip it over the steering draglink, up near the pitman arm. As you can see the clamp is the same size as the pitman arm tie rod. Now bend the clamps back down enough for the bolts to go through. I used a big pair of channel lock pliers to do this.
I used a Rancho SS - RS5409 ($52) for my 2nd SS shown in the pic. Its the same one used for the factory position. The tube end goes towards the driver side and has a bigger bushing hole (M12 bolt) than the boot side (M10 bolt). The Rancho shock comes with a M10 x 1.5 bolt that will work here being just over 4" long. For the tube side you need to get a M12 bolt just over 4" long. I used a M12 x 1.75 x 110 bolt.
Place the M10 bolt through the trackbar clamps and the M12 bolt through the steering draglink clamp. The reason for drilling the clamp so for the bigger M12 bolt to go through. You will now need some spacers to go on the bolt. You can use what you want, but I tried to get the shock about parallel with the trackbar. You can use washers too if you wish. I turned some 1" diameter steel spacers on the lathe that were 5/8" thick. One spacer needs to have a hole for a M10 bolt (25/64"), and the other a larger hole for the M12 (31/64"). Put the spacers on the bolt and position the clamps as shown in the pic below.
[U][COLOR="Red"]I Have WJ Stuff for Sale[/U][/COLOR]
[B]
[URL="http://www.jeepforum.com/forum/f126/zj-wj-double-cardon-front-driveshaft-52098707-a-3142201/#post29561665"] Grand Cherokee Double Cardon Front Driveshaft[/URL]
[URL="http://www.jeepforum.com/forum/f126/np-242-hd-v8-transfer-case-99-04-wj-selec-trac-2784426/"]99-04 Grand Cherokee WJ NP 242HD Transfer Case [/URL]
[/B]
WiCkeDuDe is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 11:09 PM   #17
WiCkeDuDe
Now you are ready to install the SS. I used some hex flange lock nuts, the same as what came with the Rancho SS. You dont want these clamps loosening up so use a locknut. Remember the tube end goes driver side. Snug up the bolts just enough to where you can still move the clamps.
On my WJ I locked the clamp all the way to the passenger side on the trackbar, next to the locknut. I then locked the other clamps as far up as possible on the steering draglink. Turn and position the SS so that it is parallel and does not bind when turning. You may need to space your SS different and position differently than me. I was initially concerned the SS would bottom out when turning right, hence why I pushed the clamps out to the max.
It turned out to not be a concern as I did not bottom out the SS. I am running 5" of lift on my WJ. Be sure to check that the SS does not bottom out! Below in the pictures you can see the full left turn and full right turn extension. Though the boot looks cramped, I still have just over 1" of travel in the SS when turning right. Be sure also to check that the SS does not bind when turning which can bend the SS and also affect your turning radius. Once your sure you are where you want to be then lock down the nuts and enjoy!
[B]
[/B]
Unread 03-22-2011, 11:14 PM   #18
WiCkeDuDe
So I added some 3/4" poly spacers to the rear with my teraflex springs. I am now perfectly at 5" lift at all 4 corners or 23" hub center to fender lip. This caused my rear driveshaft to pull too far out of the transfer case and I would get some vibes at high throttle. I took it out and over to a local six states today where they cut the tube out and lengthened it 1.25" as I had requested. I have my rear JKS arms adjusted to 18.75" which brought my u joint angles to within 2 degrees. Put the shaft back in and no more vibes. The Tom Woods SYE would be cool for my NP242HD, but I was quoted $650 for that and a new shaft so I went this route.
[B]
[/B]
Unread 04-03-2011, 09:21 PM   #19
rfjeeper
Well it's been a couple of months since you told me where you got your wheels on your red WJ at and now i finally have a set too,i just loved the looks and had to have a set ,THANKS for the heads up,they even cut me a good deal on tires too,love discount tire now!!
rfjeeper is offline   Reply With Quote Quick reply to this message
Unread 04-04-2011, 08:19 PM   #20
WiCkeDuDe
Looks good! How do the KM2's ride and wear?
[B]
[/B]
Unread 04-05-2011, 02:08 AM   #21
rfjeeper
She rides pretty good,the tires are load range e (all they have in this size) so a little stiff but really not bad,she has a low tire hum that i know from past BFG mt's will get louder but that's ok too i love the tire hum,only have had them on for a little over a month but no wear what so ever so far
Unread 08-10-2011, 03:10 PM   #22
WiCkeDuDe
Finally got my painted Overland sliders installed. Im pretty happy with how they look on a Limited.
[B]
[/B]
Unread 09-08-2011, 05:01 PM   #23
snobrdrkid07
snobrdrkid07's Avatar
Really Clean WJ's man. Good stuff.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
~ Snobrdrkid07's ~ Overland Build Thread ~ Blue WJ "Build" Thread ~ Jeep Videos ~ Fuelly ~WJ 4.0 Trans Aux Cooler Info ~
-Michael-
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 09-09-2011, 11:52 AM   #24
RedlegWJ
Notice any wetness on the Rancho SS shafts from siiting sideways? Mine isn' quite a year old and the shaft is oily, but doesn't drip yet.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline   Reply With Quote Quick reply to this message
Unread 09-11-2011, 04:43 PM   #25
WiCkeDuDe
Every once in awhile I see some water in the SS boot but no oil. Havent had an issues with them whatsoever.
[B]
[/B]
Unread 03-03-2013, 09:03 PM   #26
three_jeeps
OK, so why?
I get it, you replaced the steering stabilizer. Some questions:
1)Why is the ranchero better than factory?
2) I am a little confused....did you replace the original? you first post said something about adding a second SS.....
tow hooks still available?
three_jeeps is offline   Reply With Quote Quick reply to this message
Unread 04-16-2015, 09:57 AM   #27
WiCkeDuDe
Im in the process of painting my WJ and fixing a few damaged areas. Thought I would upload some new photos and update my build thread this I havent for a long time.
Ive now upgraded to the Clayton Long Arm kit using Teraflex springs and my same bilstein 5100 series shocks and I love it. No more death wobble and the ride is sooo much better. Kinda figures since my short arms were at almost 35 degrees and the new long arms sit about 10 degrees.
Here are some pics of the Clayton install. Overall I was very impressed with the quality of the Clayton kit... it does take a long time to weld and cut though! ...
[B]
[/B]
Unread 04-16-2015, 10:23 AM   #28
WiCkeDuDe
Next up I just got my KOR skidplate fitted, tapped, painted and bolted up. I used some silver POR 15 that hopefully will hold up well to all the punishment.
Im pretty pleased with it overall other than I didnt like the carriage bolt usage they wanted up front on the crossmember.
[B]
[/B]
Unread 04-16-2015, 10:25 AM   #29
WiCkeDuDe
I think its safe to say I need to sell off some of my wheels and clean the garage up....
[B]
[/B]
Unread 04-16-2015, 10:44 PM   #30
SteeleJay
SteeleJay's Avatar
It's an old part of your thread, but I'm curious how the engine rebuild worked out for you?
Jeeping: The art of getting dirty and going broke while slowly heading nowhere and taking all day to do it.
Build Thread: http://www.jeepforum.com/forum/f197/...build-3066009/
SteeleJay is offline   Reply With Quote Quick reply to this message
