Why is it ok when an xj has 40+ tires but not a zj?? - Page 2 - JeepForum.com
post #16 of 25 Old 05-29-2013, 09:00 PM
shackwrrr
You can get zj's all day long for under 2k here, xj's are all 3k plus.
I think the big reason is that ZJ's are more expensive to lift. For an xj, you only need one set of long arms. Zj you need, front and rear long arms and 2 adjustable track bars. Also the nature of link suspension pushes the axle away from the link mount under compression meaning on the ZJ rear you need to do a lot more trimming to fit a 40.
shackwrrr is offline
post #17 of 25 Old 05-29-2013, 09:02 PM
HeavyArms
I think it all depends on the owner. My friend has a 5.2 zj on 42" iroks with d60's.
Il upload a pic when im not on my phone
Wiggle wiggle wiggle
HeavyArms is offline
post #18 of 25 Old 05-29-2013, 09:02 PM
Scopez
1994 ZJ
That's true...kinda didn't even think about have coils in the rear on a ZJ. Leaf springs are always cheaper...
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #19 of 25 Old 05-29-2013, 09:06 PM Thread Starter
cmorris2431
Please do I would like to see the trimming he did! Thanks
cmorris2431 is offline
post #20 of 25 Old 05-29-2013, 09:13 PM
HeavyArms
Here she is in all her glory. Everything is custom made by him. The blonde is 5'4" just to give you an idea of how big it really is.
image-1420376184.jpg   image-2271238959.jpg   image-3803128450.jpg   image-1985254998.jpg   image-3608112090.jpg
post #21 of 25 Old 05-29-2013, 09:17 PM
riot1987
Originally Posted by underpowered View Post
same reason you see more TJs on 40's than XJ's. quantity and aftermarket support.
there are more XJ's out there to start with, and the Xj has more aftermarket support for it.
^^this.
OP
Anyone who is LEGITIMATELY running 40"+ tires on an XJ has put quite a bit of time and/or money making it happen. Anyone can lift a jeep and put mondo tires on it but doing it correctly aint ever cheap or easy. XJ's are simpler, smaller and lighter too which makes em a bit more desirable for serious wheeling I would guess as well
Build thread^^
riot1987 is offline
post #22 of 25 Old 05-29-2013, 09:17 PM
GCjunkie93
So much for the theory of "having to trim a lot"
1993 ZJ 5.2 V8-Some Stuff/Beater
1984 CJ7 258/Auto/Dana 300/Daily Driver
GCjunkie93 is offline
post #23 of 25 Old 05-29-2013, 09:26 PM
HeavyArms
From what i remember
The front is a radius arm setup with reverse high steer, 6.?? Gears, arb, 12" or 14" coilovers, custom flairs
Rear is triangulated with 7" clayton coils and 2" pucks, bilstines, and an arb. Theres 14" under the diff and 17" under the tubes on the rear d60.
Tires are 42x??x17 iroks on raceline raptors.
The bumpers, rockers, and belly skid were all home made. He relocated the gastank with a fuelcell in the hatch. The ac was converted into a oba setup.
He still has to finish the rear flairs and swing down tire carrier. Only reason they wernt done in the pics is he was rushed due to The Blessing Of The Jeeps here in Michigan.
post #24 of 25 Old 05-30-2013, 10:21 AM
mtnmarc
Its also like why all the toyota guys have 4d's and up. They have a greater after market support which also drives the prices down. Look at trail gear, very large toyota (mostly) support. Leaf springs and some shocks, cut fender and you can easily clear 4d's. I have buddies that have done that.
Yet with a jeep, coils or coilovers plus long arms for larger tires. And axles for sure. Dana 30s barely hold up on 32s for some people.
Toyota housings, with a few upgrades, can be very durable.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #25 of 25 Old 05-30-2013, 05:35 PM
CRJEeP_wj
Xjs are flat and square, easy to cut on and make look as good as factory and nobody minds beating on them. The grands are too pretty with nice body lines you don't wanna hack up or beat on. Plus all the before mentioned reasons.
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread
CRJEeP_wj is offline
