"Why did you get that?" Niner Build! - Page 58 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > "Why did you get that?" Niner Build!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 04-02-2012, 07:18 AM   #856
jlipka98zj
Originally Posted by HeavyArms View Post
Any chance they sent you 4.5" coils or mabe you orderd the wrong ones? Its just really hard to believe theyd drop that much. Bds has an incredible sprig rate compared to other company's.
x2. Most likely they sent you the wrong springs. If you had them send you 8" springs, you would likely be too tall then. It's simple physics with springs, the spring rate dictates how much the spring will compress under a given load. They wouldn't sag that much. Figure that if those were actually 4.5" springs, they gave you 5" of lift, which is what most manufacturers do. They usually give you more than advertised. Perfect example, my OME coils were advertised for 1" of lift, but I got nearly THREE!
If it were me, I would be pressing BDS to send you "another" pair of 6" coils. I bet they are different than what you have. Then you can send them back and rub it in their face. I'm guessing that, like my OME coils, there is no way to verify part number? Like it's not stamped on the coil somewhere? My coils had a cheesy sticker with the p/n, but that promptly came off.
Oh, and for reference, your 5.9 doesn't weigh hardly anything more than a 5.2. Most of the differences are internal (rods, crank, etc).
'98 5.9 Limited - Got some stuff done to it...
jlipka98zj is offline   Reply With Quote
Unread 04-02-2012, 09:49 AM   #857
hotrodjeeper
According to BDS theres an all around 150-200 pound difference upfront from the 5.2 and 5.9. And the part numbers that were on the box matched what was on the web site for the coils. This is the second set of front springs iv had that sagged around 2"s. the whole reason I ordered these was cause I was told they wouldn't sag as bad to what I had in there before hand. I called them before I ordered these and asked about the sagging, I was told it would sag about 1"-1.5"s cause of the V8 which I was fine with as I had planned to add an extra spring isolator to help level it. I'd rather the jeep have a "hotrod" stance then ride high in the front.
BUILD THREAD BELOW http://www.jeepforum.com/forum/f197/why-did-you-get-niner-build-1200616/"]http://www.jeepforum.com/forum/f197/why-did-you-get-niner-build-1200616/
hotrodjeeper is offline   Reply With Quote
Unread 04-02-2012, 11:16 AM   #858
comptiger5000
The difference between a 5.2 and 5.9 engine is none at all. The tranny in the 5.9 ZJ (or early 5.2) is about 40 - 50 lbs heavier than a 96 - 98 5.2 tranny, IIRC. There is a little extra weight in the other 5.9 stuff, but I would figure the 5.9 ZJ is no more than 70 lbs heavier up front than a 5.2.
They probably base their lift ratings off a 4.0, which would be about 150-ish lbs lighter on the nose.
comptiger5000 is online now   Reply With Quote
Unread 04-02-2012, 11:36 PM   #859
aircruiser
I would agree, I have helped a couple buddies do 5.9 swaps (2 in trucks, 3 in Jeeps), the weight difference is hardly noticeable at all.
1996 XJ on 36s, 4", locked F/R, stretched, main wheeler Build Thread
1998 XJ on 34s, 4.5", locked rear, trail rig
2001 Dodge Dakota SLT QC 4x4 on 33s, some go fast goodies and other stuff, DD and tow pig
aircruiser is offline   Reply With Quote
Unread 04-03-2012, 12:28 AM   #860
hotrodjeeper
Ohwell there tech people were talkin about all the weigt differences from the 4l to the 5.2 and 5.9. It is what is. I just don't want the pucks in there
If any of yall want a fishing poll holder its $30
Unread 04-12-2012, 10:19 PM   #861
hotrodjeeper
It was slow at work so I decided to disconect the fronts and see what it could do. I can go a little more. A few checks away from ordering bumpers and dana44a rebuild kit. tranny is starting to slip sometimes going from 1st to second.... Heres some pics. Also I bought see foam for the jeep and the guy at the store warned me about how strong it is and made me second guess it. just curious if i should just put half the bottle in with a full tank and play iit safe or the whole bottle?
Unread 04-12-2012, 10:27 PM   #862
Freestyle713
1994 ZJ
I would do half in the tank, half in the vaccum line coming off the brake booster
[B]94 Grand Cherokee 5.2[/B] [SIZE="1"]33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's[/SIZE]
[CENTER][COLOR="Yellow"][URL="http://www.jeepforum.com/forum/groups/zombie-outbreak-response-vehicles/"][COLOR="Yellow"]Zombie Outbreak Response Team[/COLOR][/URL][/COLOR][/CENTER]
[QUOTE=elcorvino;14544406]Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.[/QUOTE]
[QUOTE=ScottD16;14460352]I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.[/QUOTE]
Freestyle713 is online now   Reply With Quote
Unread 04-12-2012, 11:55 PM   #863
biebs53
This
[CENTER][FONT="Franklin Gothic Medium"]1998 Jeep Grand Cherokee 5.9 Limited
Build thread: [url]http://www.jeepforum.com/forum/f197/project-raven-biebs53-build-thread-1215245/[/FONT][/url][/CENTER]
biebs53 is offline   Reply With Quote
Unread 04-13-2012, 08:07 AM   #864
comptiger5000
I wouldn't even both with putting it in the tank. It's not that strong. The reason it's effective through the brake booster is because it soaks into the carbon, which loosens it up some.
Unread 04-22-2012, 12:11 PM   #865
hotrodjeeper
Muddin the night before prom wasnt such a good idea haha. Bumpers are ordered, should be here in about 2-3 weeks.
Was a pain to clean haha
Unread 05-01-2012, 11:04 PM   #866
hotrodjeeper
I got to confident and tried to crawl through this mud whole on a trail today and just dug my self in lol.... I stepped in it and i sunk to the top of my knee haha. Called protofab today and my bumpers should be here in about a week maybe 2 depending on shipping.
Reinstalled my HIDS, still cant get them to work right but its whatever.
Unread 05-03-2012, 02:31 PM   #867
YERFDOG
What exactly are the HID's doing that are not letting them work right? Mine have no problems. Do you have an HID harness for them? Our Jeeps have a lot of trouble with HID's without a harness as not enough current or whatever can not power the ballasts. Therefore you need the direct battery power for them.
Eric
*1998 Jeep Grand Cherokee 5.9 Limited*
http://www.jeepforum.com/forum/f197/yerfdog-s-white-5-9-build-picture-thread-1087847/
YERFDOG is offline   Reply With Quote
Unread 05-03-2012, 02:36 PM   #868
jlipka98zj
Every bi-xenon kit (which these GC's use) I've ever seen comes with a battery harness. Has to in order to get the relay that controls the bi-xenon functioning.
Not to say that the chinsy $15 harness they give you is worth anything, but it's probably better than using the stock wiring (which isn't saying much). Build your own.
Unread 05-03-2012, 07:22 PM   #869
hotrodjeeper
Its powed by the relay. The jeep says there are in high beam mode and wont click out of high beam mode. Not sure if its something in the kit is wrong or if its the jeep. My buddy bought the same exact kit and we installed it in his mustang the same way as the jeep and he has no problems. We'v tried switching the polarity to and it effects nothing. The kit should have been a high and low beem kit.
Unread 05-03-2012, 07:34 PM   #870
hotrodjeeper
heres a pic of what I ordered off the site. And I added a new sticker today lol.
