Who wants a Diesel WJ in Phoenix AZ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Who wants a Diesel WJ in Phoenix AZ??
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueLast Day to take advantage of 5% off August Promo
Unread 08-06-2015, 08:56 AM   #1
Max78
1992 XJ Cherokee
Came across a diesel WJ in Phoenix, not sure if this is factory or not, If I had the money I would seriously consider buying it if everything checked out and I could get them down a little on price.
http://phoenix.craigslist.org/nph/cto/5077379831.html
http://phoenix.craigslist.org/nph/cto/5077289994.html
92 Cherokee - All nude and in need of some tlc!
Max78 is online now   Reply With Quote Quick reply to this message
Unread 08-06-2015, 09:01 AM   #2
car5car
2002 M-38
Top speed like 50cc Chinese scooter.
Pay triple price but you can save on gas...because it doesn't need gas! Diesel fuel cost 50% than gas.
01 XJ 2wd 4.0
car5car is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 09:07 AM   #3
Max78
1992 XJ Cherokee
Ya they are a bit expensive and not sure why they are left hand drive if they are imported from Germany and Italy supposedly? Did they not make any right hand drive ones?
Unread 08-06-2015, 10:25 AM   #4
Double E
2000 Laredo V8
Double E's Avatar
Aussie market?
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is online now   Reply With Quote Quick reply to this message
Unread 08-06-2015, 10:50 AM   #5
alfaitalia
CRD Pilot!
alfaitalia's Avatar
??? They are nearly all left hand drive! Australia and UK drive on left but all the rest mentioned (ie Germany and Italy) drive on right like you guys.
Sent from the Dark Side (of the Pond) using only the Force.
Going to war over religion is like killing someone because your imaginary friend is better than theirs!
alfaitalia is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 10:50 AM   #6
mr312712
SPEED FREAK V8 FOR LIFE.
mr312712's Avatar
No thanks, I'll keep my 4.7 H.O.
Jeep's have engine's not motors.
If you own a Jeep, then u shouldn't be worried about MPG.
Castrol Edge 10W30 Advanced Full Synthetic
04 WJ Overland 4.7 H.O. Inferno Red
mr312712 is online now   Reply With Quote Quick reply to this message
Unread 08-06-2015, 10:54 AM   #7
alfaitalia
CRD Pilot!
alfaitalia's Avatar
What? Top speed identical to 4.0. Same torque as HO at half the revs. Let's see which of us can tow a 7000 lb caravan up a hill from a standing start fastest shall we! (Would still swap her for an HO in a flash if I could afford the fuel.....!)
Btw diesel is about the same price as gas over here.....bloody expensive! About $8.00 a gallon...was about nine per gallon but have recently seen the price drop a little!
Unread 08-06-2015, 04:17 PM   #8
mr312712
mr312712's Avatar
Lol let's see who's gonna take the longest to start up at -25 F. But anyway the H.O. makes 330 pound of torque @ 3600 RPM and 270 HP @ 5100 RPM. The 2.7 Diesel makes 161 HP @ 4000 RPM and 295 pounds of torque @ 1800 RPM, so they don't mimic the same torque. The H.O. has 100 more horses and 35 more pounds of torque. Not to mention the 2.7 0-60 Is 11.2 seconds and the H.O. Is only 6.7 seconds.
Unread 08-06-2015, 04:24 PM   #9
xrunndonex
1994 ZJ
Better yet....the engine pics are the same in both pics. Look you can see the the jeep is blue in the engine bay pics...
xrunndonex is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 04:26 PM   #10
Svensson
I had my 2,7 reprogrammed to right around 210hp.. It's like a bullet now.
Svensson is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 07:12 PM   #11
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
A motor that turns at 1500 rpm is gonna just run and run forever. Im sure you can find some diesel fanatics could put a sweet turbo on there too
I wouldnt buy a diesel for racing, but Id take it for longevity.
MoonyJohn is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 10:08 PM   #12
xrunndonex
1994 ZJ
This is a scam.... the engine bay pics tell it all... look they are the same engine bay in both pics
Unread 08-06-2015, 10:11 PM   #13
Jeeples
Elbows Deep In WJ's
Jeeples's Avatar
I just want the power folding mirrors...
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Build Thread
Real men run the stock rear sway bar at any height
Jeeples is online now   Reply With Quote Quick reply to this message
Unread 08-07-2015, 01:09 AM   #14
alfaitalia
CRD Pilot!
alfaitalia's Avatar
My mistake, I meant same torque as non HO V8! 0-60 is of course much faster...but if you do that too often you probably bought the wrong vehicle. I think however you would be quite impressed with the flexibility of the Merc unit. It takes a steep hill to drop her out of top! Don't get me wrong...I'd love a V8 but funds don't allow......did take a long look at a V8 with LPG recently though....that's a possibility of anything happened to my old Jeep (hope it doesn't though!).
Unread 08-07-2015, 01:14 AM   #15
alfaitalia
CRD Pilot!
alfaitalia's Avatar
My friend in the U.S. says the same. But he also wants the galvanized body, side turn signal repeaters, the standard UC suspension that all CRDs get, the heavy weight stainless Freedom edition style side steps (rather than the puny alloy ones he has!), rear fog lights, superior and virtually indestructible tranny with none of that antiquated overdrive nonsense etc etc etc! Will have to keep a close eye on him when he visits or half my car is going to go missing!
