Whiskeypete's WJ - (build to come) thread - Page 2 - JeepForum.com
post #16 of 21 Old 05-19-2010, 10:04 PM
PDXCoug
Here is what I did with my Hella 500's, I really like the final product
Lights are Mounted! - JeepsUnlimited.com Forums
Washington State University GO COUGS!
PDXCoug is offline
post #17 of 21 Old 05-19-2010, 10:08 PM Thread Starter
Whiskeypete
yep i saw that option, but it wont work for me. im installing the perforated grill mesh from custom car grills, so no way i can put the lights behind. thanks for the input coug...yours is looking good
Whiskeypete is offline
post #18 of 21 Old 05-19-2010, 11:13 PM
PDXCoug
I didn't have to mess with the actual grille to get those lights to fix. Just those support brackets on the front facia
PDXCoug is offline
post #19 of 21 Old 05-22-2010, 03:19 PM Thread Starter
Whiskeypete
plug job complete. first time i ever did one. not bad that bad in difficulty or what it takes to do. just read thru and follow the write up on wjjeeps.com and its all good. i would love to smack the sadist that designed the setup for the back two plugs on the passenger side. between the wiring harness, tranny fluid stick and the cowl those two are a major pita. old plugs were gapped anywhere from .03 to .035 on all 8 of them. gapped at .04 as prescribed and can immediately feel the difference, much smoother than before.
found out the rubber bushings that really hold down the factory air box were worn out and rotten, so now the box is slightly loose.
fun day of putzin' around and learning
post #20 of 21 Old 05-24-2010, 03:03 PM Thread Starter
Whiskeypete
build sheet info:
Code Description *JL Leather Trimmed Bucket Seats -DV Dark Slate Gray ADLP Skid Plate Group AFFP Luxury Group AHX Trailer Tow Group IV APAS Monotone Paint AWE Up Country Suspension Group A82P 4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ) BAZS 136 Amp Alternator BC6S 625 Amp Maintenance Free Battery BRYS Anti-Lock 4-Wheel Disc Brakes CACS Low Back Bucket Seats CBWS Highline Door Trim Panel CFNS Rear 60/40 Folding Seat CGUS Child Seat Anchor System-LATCH Ready CG1S Next Gen Multistage Front Air Bags** CKDS Floor Carpet CKNS Cargo Compartment Carpet CKTS Cargo Tie Down Loops CLES Front & Rear Floor Mats CLHS Cargo Trim Panel w/Storage Net CLPS Door Sill Scuff Pads CSCS Cargo Compartment Cover CSRS Passenger Assist Handles CUDP Mini Overhead Console CUFS Full Length Floor Console DGES All 5-Speed Automatic Transmissions DGQ 5-Spd Automatic 545RFE Transmission DHAS Lock-Up Torque Converter DHPS Selec-Trac Full Time 4WD System DJJS Dana 30/186MM Front Axle DMEP 3.73 Rear Axle Ratio DRKP Dana 44/226MM Rear Axle EVA 4.7L V8 MPI Engine GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEGS Deep Tint Sunscreen Glass GEPS Flipper Liftgate Glass GFAS Rear Window Defroster GNCP Sun Visors w/Illum Vanity Mirrors GNKP Rear View Auto Dim Mirror GTM Power Heated Mirrors GXMP Remote Keyless Entry GXXS Sentry Key Theft Deterrent System HAAS Air Conditioning HGAS Hood Insulation HGDS Deluxe Insulation Group I48S Route 48 - UP, Mira Loma, CA JAYS Instrument Cluster w/Tach JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JHBS Rear Window Wiper/Washer JJBS Dual Note Electric Horns JKAS Locking Glove Box JKPS 12V Auxiliary Power Outlet JKYS Power Accessory Delay JPBS Power Locks JPDS Power Windows, Driver One-Touch JPTP Power Front Driver/Passenger Seats K4KS STRIPE/BADGE/MOLDING/COLOR K5KS STRIPE/BADGE/MOLDING/COLOR LACS Illuminated Entry LAGS Warning Chime LAZP Vehicle Information Center LBBS Courtesy Lamps LBCS Glove Box Lamp LBDS Ash Tray Lamp LCES Rear Courtesy/Reading Lamps LDBS Cargo Compartment Lamp LETP Traveler/Mini Trip Computer LMBS Halogen Headlamps LMGP Automatic Headlamps LNJ Fog Lamps LPSS CHMSL Lamp LSAP Security Alarm MDAP Front License Plate Bracket MFZS Bright Grille MHAS Black Windshield Moldings MVBS Grand Cherokee Badge MVCS Jeep Badge MVEP V-8 Badge MWGS Roof Rack MWTS 4X4 Badge NAS 50 State Emissions NBVP Low Emission Vehicle (LEV) NFPS 20.5 Gallon Fuel Tank NHFP Power Steering Cooler NHMS Speed Control NMHP Hydraulic Engine Cooling PS5 Silverstone Metallic Clear Coat QS5S Silverstone Metallic Clear Coat RAAC All Radio Equipped Vehicles RBP AM/FM Cass/CD Radio w/Changer Ctrl RCEP Infinity Speakers RDDS Fixed Long Mast Antenna RDZP Steering Wheel Mounted Audio Ctrls SBAS Power Rack and Pinion Steering SCLP Leather Wrapped Steering Wheel SDUP Heavy Duty Suspension w/Gas Shocks SUAS Tilt Steering Column TBLS Inside Mounted Spare Tire TBWS Full Size Matching Whl Spare Tire TTBP P245/70R16 OWL All Terrain Tires TZAP Goodyear Brand Tires WDRS 16X7.0 Lux Alum Silver Wheels WLZC All Aluminum Wheels XEAP Tow Hooks XEEP Fuel Tank Skid Plate Shield XEFP Transfer Case Skid Plate Shield XEUP Front Suspension Skid Plate XFHP Class IV Receiver Hitch XFKP 7 Pin Wiring Harness XFLP 7 to 4 Pin Wiring Adaptor XGDP Universal Garage Door Opener XPFS Protective Coating and Remover
post #21 of 21 Old 06-27-2010, 12:40 PM Thread Starter
Whiskeypete
just turned 88,000 yesterday. pulled the throttle body today and cleaned it out. the IAC was caked. it definitely idles smoother now and the throttle is 'cleaner' and more responsive. quick easy job that takes less than an hour
2012 JKU Rubicon - all stock at this point
2002 WJ - 4.7L V8 - Selectrac - D30/44 - 255 BFG AT's - BB - Rancho 9000's
1999 WJ - 4.0L I6 - 4x4
CLNinja's Build Thread CLNinja Grand Cherokee General Discussion 1238 05-04-2013 04:29 PM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
