vw engine swap - Page 2 - JeepForum.com
post #16 of 36 Old 06-07-2013, 12:26 AM
StPaul59
Originally Posted by PolkaPower View Post
Just gear it 5:13 haha.
Thats how they did the early 90s Pathfinders. 150hp 180tq.. Crazy low gears 4:63? They were slow but sort of decent with small tires.
StPaul59 is online now
post #17 of 36 Old 06-07-2013, 08:20 AM
PolkaPower
PolkaPower is online now
post #18 of 36 Old 06-07-2013, 09:18 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
keep the 4.0, its a great motor
HighLonesome is online now
post #19 of 36 Old 06-07-2013, 01:05 PM
Jons59ZJ
You really looking into a diesel Jeep? The late 2000 models made the GC w/ a 3.9L(I think) turbo diesel motor. If you can't figure that swap, look into a
4BT or 5.9L Cummins into a GC... Now your talking. I've seen one Wrangler Unlimited that had a 5.9L, lots of work.
Good luck.
98ZJ 5NINER-Trail Ready Front w/ Grill Guard--Rugged Ridge 8500lb-IRO 5 1/2"LA Fully Adj.Kit-16x8 Pro Comp 7089 Flat Black-35x12.5 Pro Comp Mudd Terrains--Upgraded to NP231HD-Tom Woods Rear Shaft-Rusty's Intake-K&N Filter--ADDCO F & R Sway bars, Currie HD Steering-3"Cat back w/ Flowmaster 50-TireGate HG Series Rear tire carrier
Jons59ZJ is offline
post #20 of 36 Old 06-07-2013, 01:25 PM
dnuccio
Originally Posted by Jons59ZJ View Post
5.9L Cummins into a GC. Good luck.
can you say "firewall modification"
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #21 of 36 Old 06-07-2013, 01:42 PM
rebelbowtie
Originally Posted by Mickey_D
Yeah, I don't know of ANY VW engine that would effectively move a ZJ. I think your movement would be measured with a calendar instead of a speedometer.
You obviously don't know much about VW then, I can think of many many engines that would effectively move a ZJ and better than the Chrysler engines they came with.
rebelbowtie is offline
post #22 of 36 Old 06-07-2013, 02:07 PM
PolkaPower
Cool now just redesign the engine bay.
Here's one with a Cummins 3.9. http://mallcrawlin.com/forum/showthr...3679-Diesel-ZJ
post #23 of 36 Old 06-07-2013, 02:22 PM
Moparich
when i was in europe i seen a few jeep cherokee turbo diesels
UJC #174
Moparich is offline
post #24 of 36 Old 06-07-2013, 02:26 PM
PolkaPower
Those 2.5 ZJ diesels had about the same torque as the 4.0 and comes with cracking heads from what I have read.
post #25 of 36 Old 06-07-2013, 02:31 PM
Siva283
The VW 2.5 TDI would do a pretty good job. The 1.9 YDI can move a wrangler towing 1000 pounds pretty good too. You can run 17 pounds of boost constant all day long on the 1.9
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #26 of 36 Old 06-07-2013, 03:26 PM
davigzj
Their is a web site for this but im not home on VWs into a wrangler ..it was in fourwheel n offroad i belive last isse...
davigzj is offline
post #27 of 36 Old 06-07-2013, 03:30 PM
Glasssplinter
1994 ZJ
The Touareg has a nice engine in it. Straight from VW:
TDI® Clean Diesel:
3.0L, 24-valve, DOHC, V6, TDI® Clean Diesel engine with common rail direct injection; 240 hp, 406 lbs/ft of torque
compare that to the 5.9L 245 hp 345 lbs/ft. Wouldn't mind having that engine in my Jeep. Plus it has a 8 speed transmission with it. If I had the parts I'd do it.
'94 ZJ, 4.0L, 231 TC
Icom V-8000 with 1/4 wave
Glasssplinter is offline
post #28 of 36 Old 06-07-2013, 04:20 PM
kg6mov
Hears the voices
kg6mov's Avatar
Audi R8 V10, it'll totally fit.
kg6mov is offline
post #29 of 36 Old 06-07-2013, 04:26 PM
kg6mov
Hears the voices
kg6mov's Avatar
Ecu is gonna be the biggest problem, engine mounts are engine mounts if you can weld.
Dunno about the tcase options.
kg6mov is offline
post #30 of 36 Old 06-07-2013, 05:04 PM
rebelbowtie
No way this VW engine can move a Jeep....
http://youtu.be/F-HDbhgca5g
Lets not forget VW is the parent company to Audi, Bugatti, Bentley, Porsche, Lamborghini NONE of them have an engine that can move a Jeep.
