UTZJ 5.9 DD stock build.......for now - JeepForum.com
post #1 of 101 Old 06-10-2013, 12:27 PM Thread Starter
adavis39
Picked up the 98 5.9 on Saturday. Its going to be replacing my WJ (some of you may have followed my other build) as a DD. The WJ will now be a trail rig only.
I have wanted a 9er for a Loooooooonng time. Finally decided to pull the trigger. She has 175k on her. Very clean on the inside. Has a few cosmetic issues on the outside but most a easily fixed. (paid $2850 for her.....i think thats pretty good considering)
Main issues at the moment:
AC is dead. Compressor kicks on for only a few seconds at a time. Air blows strong from the vents but its warm. Im thinking it may just be out of freon. Ill try that first then chase it from there
249 is shot (no surprise). Wheel hop is pretty bad at slow tight turns. Not a big deal since I was planning a 242 swap anyway.
Muffler has a small hole. Again, no big deal. Muffler delete will be occuring this weekend anyway!
Rear hatch is tricky to open. You have to pull up on the latch as you use your thumb to push where the key would go. Looks like the cable may have some slack and not completely releasing the latch. Should be an easy fix
Going to make this a basic "re-build" for the time being. Once the wife is done with her masters (about 2 years) I really want to start looking into a 408 build. For now ill be ordering some basic parts (new front rotors, pads alla round, new belt and plugs, new steering linkage, new headlight assemblies, diff fluids, etc.....)
More pics will follow soon.........
First gas fill up.......ouch
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #2 of 101 Old 06-11-2013, 08:30 AM Thread Starter
adavis39
Changed the oil last night and new air filter. Tranny fluid looks perfect. Here are a few pics from this morning:
And a couple shots of what needs fixed:
rear hatch needs fixed......might have to ultimately replace it but for now ill just sand it down and color match these two rust spots
rear bumper cover has a small crack.
hood vents need re-painted
I have a new OPTIMA RED TOP coming ym way this week for FREE!! so i think the terminals will be replaced as well. They have obviously seen better days
All in all id say its in pretty good shape for 176k. The guy I bought it from was the second owner and had owned it since 2000. EVERYTHING power wise works. I think I may have blown a fuse for the fog lights because they worked yesterday. But when I came back out from the store, they turned on the right back off and wont come back on. I inherited the stupid "low coolant sensor" warning. Going to have to fix that ASAP. Headliner is perfect except for the rear sound bar. It is SLIGHTLY falling. I need to get it re-covered. All of the speakers work and sound great.
Also, getting a used Superchips from the guy that is giving me the Optima. He used to own a 9er with an ATLAS II
Couple 9er Newb questions. what is the normal running oil pressure and engine temp. Oil seems to hold around 32 around town and 42 on the interstate. Engine temp sits around 208 when im moving. When sitting in traffic, it creeps to around 215-216 before the fan kicks on and brings it back down to abour 210.......normal?
TNJEEPS.COM
BUILD:
adavis39 is offline
post #3 of 101 Old 06-11-2013, 10:42 AM Thread Starter
adavis39
new OE headlights ordered. Nothing fancy, just getting rid of the mis-matched levels of haze on the current ones for some nice new clear ones. $50 bucks....not bad
TNJEEPS.COM
BUILD:
adavis39 is offline
post #4 of 101 Old 06-11-2013, 02:43 PM Thread Starter
adavis39
bought a new toy.....got tired of borrowing my father-in-law's. Muffler be GONE as soon as I get home. Anyone interested in a 5.9 exhaust tip?
TNJEEPS.COM
BUILD:
adavis39 is offline
post #5 of 101 Old 06-11-2013, 03:55 PM Thread Starter
adavis39
Bilstein 4600's ordered from KOLAK. Hope they get here soon. My current shocks are DEAD. there is almost ZERO compression left in them. The ride is just a little bumpy
TNJEEPS.COM
BUILD:
adavis39 is offline
post #6 of 101 Old 06-11-2013, 08:23 PM Thread Starter
adavis39
Drive shaft gone. No more wheel hop for the time being. Leaky muffler deleted. Sounds sooooooo much better
TNJEEPS.COM
BUILD:
adavis39 is offline
post #7 of 101 Old 06-12-2013, 07:47 PM Thread Starter
adavis39
Replaced the belt with a new Gates one. The old one was really cracking bad.
New belt is on and its much more quiet
Engine was already pretty clean when I got it but im going to try and really get it to shine
PIcked up some PB Blaster to go ahead and start soaking the shock bolts for when the Bilsteins show up. Also picked up a few supplies for this weekend
Couple driveway shots
TNJEEPS.COM
BUILD:
adavis39 is offline
post #8 of 101 Old 06-12-2013, 07:51 PM
bananaslug
looks like a clean one!
bananaslug is offline
post #9 of 101 Old 06-12-2013, 08:05 PM Thread Starter
adavis39
THanks! Shes got her rough spots here and there but the interior znd the engine are damn near spotless which was a HUGE plus for me. Only thing bothering me now is the check engine light keep randomly coming on and off. Havnt pulled any codes yet but im wondering if its a fuel problem. Seems to come on alot when I really punch it or if I take a hard turn (like if the gas shifts hard inside the tank) need to track that down this week but shes running very strong so im hoping its nothing to bad
TNJEEPS.COM
BUILD:
adavis39 is offline
post #10 of 101 Old 06-13-2013, 10:44 AM Thread Starter
adavis39
alright so yesterday REALLY sucked with no AC. I knew the AC wasnt blowing cold when I bought it. When you turn the AC on, air blows strong from the vents but its VERY warm....almost hot if you put your hand right by the vent. Compressor will kick on and run for about 3 seconds then cut off. It repeats this over and over (on for 3 seconds then off for a few then back on). I tried filling it with an entire can of 134a hoping that the freon had just leaked out over time and the compressor was kicking off do to a lack of pressure. It took the whole 22oz bottle with absolutely ZERO change in temp from the vents. Im thinking it was either completely empty on freon and needs more, or has a huge leak. I dont really want to just go buy more 134a and dump it in and end up wasting money or over filling it. Im no AC expert at all but would like to avoid a shop if at all possible. when the compressor would kick on, the low side would hold steady at 100. Any thoughts?
TNJEEPS.COM
BUILD:
adavis39 is offline
post #11 of 101 Old 06-13-2013, 01:56 PM Thread Starter
adavis39
picked up some FREE stuff from a buddy.
He had a set of manifold gauges. Looks like the system is holding pressure good and the freon was full. Looks to be the fan. It will only kick on for a few seconds then turns off for a minute or so before kicking back on for just a few seconds. AC seems to blow slightly more cold when going down the interstate and air can move across the condensor. Looks like ill swapping ina new fan soon.
TNJEEPS.COM
BUILD:
adavis39 is offline
post #12 of 101 Old 06-13-2013, 02:25 PM Thread Starter
adavis39
looks like from my brief research, that the low speed fan not wanting to kick on may also be the reason the engine is running around 208............
TNJEEPS.COM
BUILD:
adavis39 is offline
post #13 of 101 Old 06-13-2013, 04:16 PM Thread Starter
adavis39
ordered a new fan motor and the new connector:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
should be here Saturday thanks to Amazon Prime. Hopefully going to get this AC issue worked out soon
TNJEEPS.COM
BUILD:
adavis39 is offline
post #14 of 101 Old 06-13-2013, 05:32 PM
dillonjm
2013 WK
Originally Posted by adavis39 View Post
...should be here Saturday thanks to Amazon Prime. Hopefully going to get this AC issue worked out soon
I've saved way more in shipping than the cost of membership. I love Prime.
Jeep looks nice, I used to rock the 5.9 in my first Ram ('01), I liked that motor. FWIW I'm not 100% but Id guess the oil gauge is just a dummy gauge like most of the era and newer. If its reading normal it should be good.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #15 of 101 Old 06-13-2013, 06:58 PM Thread Starter
adavis39
Good to know. I was too concerned with the oil more the engine temp. Looks like 208 is higher than it should be but I think I x
Solved that with the fan. Will have to wait and see
TNJEEPS.COM
BUILD:
adavis39 is offline
