"The UTE" Build Thread - Page 52 - JeepForum.com
post #766 of 965 Old 04-02-2013, 11:51 AM Thread Starter
BLACK04WJ
Originally Posted by adavis39 View Post
i think my trac bar is going to force me to get around to the install sooner than later. After i installed the KOR bushings, my bump steer was fixed for several months, but now the OEM tracbar mount is starting to wallow and my problems are coming back. I just need to go ahead and drill the mount out and put my 9/16'' bolts in and be done with it. then throw on the new knuckles to flip the drag link and tie-rod.......I hate being busy
I had the same problems so I welded washers to the front and back of the frame side mount nice and tight steering now.
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #767 of 965 Old 04-02-2013, 07:20 PM Thread Starter
BLACK04WJ
Taurus fan is here already. now I just need a 1999-2000 V8 WJ power steering pump and high pressure line and I can start the install.
Oct '12 GCOTM
post #768 of 965 Old 04-03-2013, 07:20 PM Thread Starter
BLACK04WJ
front axle almost ready for paint.
Oct '12 GCOTM
post #769 of 965 Old 04-04-2013, 04:50 PM
85IrocZ-28
Holy Mother, that truss is HUGE.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #770 of 965 Old 04-04-2013, 06:46 PM Thread Starter
BLACK04WJ
sure is! that thing is SO heavy haha
the truss acts as a bumpstop so I can get rid of my spacers on the frame.
Oct '12 GCOTM
post #771 of 965 Old 04-05-2013, 12:00 PM
mtnmarc
Is there gunna be any interference with the oil pan with a truss that big?
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #772 of 965 Old 04-05-2013, 12:16 PM Thread Starter
BLACK04WJ
I don't see how there would be. it might with a smaller lift but I'll be up pretty high. higher than I want actually. I'll have to build a steel bumper to lower it some.
I'm guessing its why IRO suggests 4" lift minimum for this axle, to clear the pan.
Oct '12 GCOTM
post #773 of 965 Old 04-05-2013, 07:54 PM Thread Starter
BLACK04WJ
finally had a chance to play with the the front bumper and get it back on over the winch mount. fits nicely
Oct '12 GCOTM
post #774 of 965 Old 04-10-2013, 07:29 PM Thread Starter
BLACK04WJ
ordered a thread insert and johnny joint for my IRO A arm. also painted my rear LA brackets and one of the axle knuckles. will be buying por15 this weekend and painting the axles.
Oct '12 GCOTM
post #775 of 965 Old 04-12-2013, 01:08 AM
GODMODEX
any progress on the taurus fan?
01 TJ, 32RH, 4.0, 8.8, hpd30, 35's, metalcloaks
07 CBR600RR, full Akra exhaust, PC V, etc.
GODMODEX is offline
post #776 of 965 Old 04-12-2013, 09:49 AM Thread Starter
BLACK04WJ
haven't done anything with it yet. I still have to buy an older power steering pump and high pressure line before I can do the swap.
Oct '12 GCOTM
post #777 of 965 Old 04-16-2013, 08:38 PM Thread Starter
BLACK04WJ
Rear axle done besides brakes.
Oct '12 GCOTM
post #778 of 965 Old 04-17-2013, 10:42 PM Thread Starter
BLACK04WJ
cut the exhaust off right after the main cat so I can have room for long arm brackets. drilled 10 of the 20 holes so far. should get the rest drilled tomorrow and then bolt up the brackets. also will be painting the front 44 with por15 tomorrow.
Oct '12 GCOTM
post #779 of 965 Old 04-19-2013, 12:19 PM Thread Starter
BLACK04WJ
didn't get a chance to paint yesterday but I did cut out the threads on my A-arm and have a friend weld in some new threads for me. I also used a Johnny joint instead of the RE one that IRO uses, should be a good upgrade
now I need to install 1 more bushing on the A-arm and paint it.
Oct '12 GCOTM
post #780 of 965 Old 04-20-2013, 12:49 AM
85IrocZ-28
I like the Johnny Joint upgrade, you shouldn't have any sloppiness in that joint at all...no worries about it coming loose.
