UTChavok's build thread. - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > UTChavok's build thread.
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-21-2009, 09:57 PM   #31
Jones
Consider the following...
Jones's Avatar
Nice score on the 8.8, my friend is getting a new 8.8 for his explorer, so he might sell/give me his old 8.8 with 3.73 and its in good shape. How hard would it be to swap in? I hear its a fairly easy replacement install.
The hard part is getting all the ZJ bracketry correct on the 8.8.
Put your bacon where your mouth is!
Jones is offline   Reply With Quote Quick reply to this message
Unread 04-21-2009, 10:01 PM   #32
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
Like coil spring holders, shock mounts, things like that?
MoonyJohn is offline   Reply With Quote Quick reply to this message
Unread 04-22-2009, 06:13 AM   #33
UTChavok
They sell complete kits if your swapping it back into short arms, ~$270. Its not hard if your doing that since you can just look at your old axle, get the measurements and make sure its centered and go at it.
UTChavok is offline   Reply With Quote Quick reply to this message
Unread 04-25-2009, 04:15 PM   #34
UTChavok
All cleaned up. The chunk still has some rust, but ill clean up more where the truss will be welded to, not to concerned.
heres a nice comparison between my spare 35 shafts and the new 8.8
Im ordering around $350 worth of stuff from ballistic on monday, so hopefully this will get rolling soon. I still need to find a 30 with 4.10s, or just say screw it and go without 4x4 for a while and find the waggy 44.
Unread 04-26-2009, 09:19 AM   #35
spidermonkey
Lookin good man, the waggy 44 would be nice but they are low pinion, get the shafts and cut down a HP ford housing down the the waggy width for best results. There are threads all over the web on it.
98ZJ, 4.0,242, 8.8 Detroit, hp30, 3.5" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here: http://www.jeepforum.com/forum/f197/spidermonkeys-98-zj-build-716209/
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers www.nsw4x4.com
spidermonkey is offline   Reply With Quote Quick reply to this message
Unread 04-26-2009, 01:30 PM   #36
besthaticouldo
dude...you have a beautiful build. a great ZJ.
niice 8.8 thats gonna be a sick set up.
besthaticouldo is offline   Reply With Quote Quick reply to this message
Unread 04-26-2009, 03:32 PM   #37
UTChavok
Yeah thats what I was concerned about. I never really thought about cutting down a full width high pinion. Ill have to think about that one for sure.
Thanks, I really appreciate comments like that. Makes me feel like im doing something right . Have learned a lot the past 2 years since all of this is a first time for me.
Unread 04-26-2009, 07:12 PM   #38
squashman702
1994 ZJ
How does your ZJ ride without aftermarket UCA's? I'm going to be lifting mine to about 5" soon, and I'd like to avoid buying UCA's for the time being if I can get away with it. I've got a full set of adjustable LCA's though.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2009, 07:22 PM   #39
UTChavok
The ride isnt bad, Its not stock but it rides well. I view it a little harsh after riding in my buddies that has long arms, but nothing compares to that. Its definitely fine.
Unread 04-26-2009, 07:25 PM   #40
ajmorell
What paint/coating did you end up using for your exhaust manifold, and how well has it held up?
ajmorell is offline   Reply With Quote Quick reply to this message
Unread 04-26-2009, 07:39 PM   #41
UTChavok
I used some krylon high heat paint that was said to withstand up to 600 degrees with 1200 degree bursts, needless to say its completely gone from the header now. Its all burned off. If your going to paint yours Id say get the ceramic header stuff you have to bake on. I cheaped out and it showed.
How do you like the shift kit in your 42re? I was going to get them to put one in when it was rebuilt but I forgot to mention it when I dropped it off.
Unread 04-26-2009, 07:42 PM   #42
ajmorell
Worth the money. Shifts are firmed up a bit for sure.
Unread 04-26-2009, 08:01 PM   #43
UTChavok
Did you put yours in? I looked on the transgo site and they only had instructions for the 46rh, but that one seemed pretty straight forward and easy.
Unread 04-26-2009, 08:41 PM   #44
ajmorell
No, when I replaced my transmission it was already installed in the replacement. It should be pretty easy, IIRC you just need to drop the valve body which is an easy job.
Unread 04-26-2009, 09:08 PM   #45
squashman702
1994 ZJ
Sounds good, I may hold off on the UCA's now. What LCA's are you running?
Think Twice Garage
