TX-WJ's build thread. - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > TX-WJ's build thread.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFather's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPI
Unread 06-15-2009, 01:14 AM   #46
TX-WJ
TX-WJ's Avatar
Got a chance to work on the Jeep this weekend, and decided to take care of the washer bottle issue as I get ready to move bigger; went ahead and "downgraded" to a ZJ bottle, found one off a '98 for like $18 on flebay, came with level sensor and pumps; opted to use the WJ's sensor and pumps so I did not have to mess with the connectors, just plug and play; I made room behind the stock airbox next to the master cylinder, minimal trimming was needed to the ZJ bottle's mounting tabs to clear the hood strut and that vacuum solenoid looking thing (whatever that is ) which was relocated forward (see pics). Overall, things went pretty well, happy with the result, almost OEM'ish; just took some time to fit things in there so the hood would clear.
Out with the Old: (Ye ole swan).
In with the "older"
David.
2004 WJ Ltd. (steel blue pearlcoat)
4.7, QT-II, 3" lift on 32's BFG ATs, Aussie locked D44a.
TX-WJ is offline   Reply With Quote
Unread 06-15-2009, 01:35 AM   #47
Jones
Consider the following...
Jones's Avatar
"Older" = better.
When are the axles going in?
Put your bacon where your mouth is!
Jones is offline   Reply With Quote
Unread 06-15-2009, 06:29 PM   #48
TX-WJ
TX-WJ's Avatar
Originally Posted by -ZJones- View Post
"Older" = better.
Dunno, but the parts continue to pile up, waited quite a while for the rear JK swap bracket kit from clayton's, but I'm glad I waited, just got them last week, they look very well designed and pure beef as anticipated, plus I got a pretty good $ deal on them as first costumer for the kit, so can't complain . Got the steering for the front almost figured out now, still need to source new pinion yokes........ so hopefully I'll make it to GSW next year .
Unread 06-15-2009, 06:55 PM   #49
gatorayde
You should tune the audi and give the lift/axles to me
gatorayde is offline   Reply With Quote
Unread 06-15-2009, 07:07 PM   #50
TX-WJ
TX-WJ's Avatar
Already did, APR Stage II, upgraded piston DV and custom PCV fix + catch can, "got boost"?
Sorry, you can't have the axles, well, at least not until I'm done playing with them .
Unread 06-15-2009, 08:15 PM   #51
CaribouLouWJ
2007 WK
Originally Posted by TX-WJ View Post
OK, so then started thinking on going bigger (it's like a disease ), and considered getting 4" teraflex coils to run 33 MTs, but then the axles became the weak link as I knew eventually I would want 35s, so the next phase started, and the brown truck paid me a few vitis.
Hobart handler 210 (disregard the niteshades can LOL, that's for a different project).
Need I say anything?
JK Rubi 44s FTMFW!
Rubi 44's, and a english bull terrier....we got alot in common dude
2007 WK Overland
5.7 Hemi, 18% tint, baby seats
2000 F350 PSD CC LB
2001.5 B5S4 500awhp gutted track car
2002 WJ Limited
4.7 HO, 6.5" LA, 37's, JK 44's SOLD
CaribouLouWJ is offline   Reply With Quote
Unread 07-11-2009, 08:21 PM   #52
TX-WJ
TX-WJ's Avatar
Started to work on the front axle today; drained diff, pulled brakes, shafts and knuckles; now to get it cleaned up in preparation for:
- Inner sleeves (Off Road Evolution) for axle tubes
- Weld axle tubes to diff housing at joints
- Tack weld u-joint caps on axle shafts (till I can ponny up for chromollys )
- RockKrawler truss for long axle tube
- Gusset axle C's (ORE's)
- HD relocating track bar bracket (Polyperformance) to match plans for high steer drag link
- Drill out / add insert to pass. knuckle in preparation for high steer DL
- Upgrade to stronger BJ's (having a hard time finding aftermarket ones)
- Riddler HD diff cover
- Swap JK style pinion flange to U-joint style yoke
- Weld on LCA bracket skids (OREs) and strenghtening inserts (Clayton's)
- Coat knuckles, color TBD.....Red maybe
Most of the parts for the front axle build already piled up somewhere in the garage .
Unread 07-11-2009, 08:23 PM   #53
-Shoey-
Well damn it, you need to hurry up. I can't wait to see it with some 35's!
2002 Grand Cherokee Limited
2004 Chevrolet Tahoe Z71
USN Jeep Club #115
Originally Posted by Sgt.Fuzz View Post
On a 1-10 scale, I give it.... Tits.
-Shoey- is offline   Reply With Quote
Unread 07-11-2009, 08:28 PM   #54
TX-WJ
TX-WJ's Avatar
Yah, me too, I feel bad enough just firing up the WJ in the driveway once a week, I really need to speed up the build and swap these puppies so I can take it out again; it's just been hard the past few months with work, wife expecting our third child, and life in general; at least I got off my butt today and gave things a little boost .
Unread 07-17-2009, 09:17 PM   #55
TX-WJ
TX-WJ's Avatar
Spent some time working on the front axle this afternoon; cutting and grinding the RK truss and drilling, cleaning the axle tubes to plug weld the ORE sleeves.
Sharp cobalt and cutting oil FTW!
Unread 07-17-2009, 09:42 PM   #56
GraKee99
Rapist Wit
GraKee99's Avatar
Nice, some progress. You should do the rear axle first so you can ship me your aussie sooner.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote
Unread 07-17-2009, 09:49 PM   #57
TX-WJ
TX-WJ's Avatar
The rear will be a lotta work since all brackets have to be cut and new ones welded, so I decided to start with the front first; plus the rear is under a mountain of heavy boxes with parts .
Unread 07-19-2009, 08:58 PM   #58
TX-WJ
TX-WJ's Avatar
OK, so my JK rubi axles have an '08 build date, and AFAIK, the failures noted where the pass. tube fractured was reported on the '07s; but I sure did not want to take any chances, so I got some sleeves for the axle tubes and the RK truss; I went with the OR-Evo's sleeves as they have an outer seal with built in grease zerks.
It was quite tedious drilling all those holes (like 15 total), but otherwise, pretty straightforward job; talk about beef
Unread 07-19-2009, 11:39 PM   #59
Bama_WJ
Bama_WJ's Avatar
This is looking awesome. Can't wait to see some more updates on this build.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel.
facebook. - Wheeling pictures and videos.
The Jeep Wave. Bringing it back.
For Sale Now:
- WJ JKS Shock Conversions
- OEM WK Springs
Bama_WJ is offline   Reply With Quote
Unread 07-20-2009, 03:40 PM   #60
cloiselle
hey whats the metric size of you tires ?
cloiselle is offline   Reply With Quote
