TX-WJ's build thread. - Page 26 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > TX-WJ's build thread.
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 07-12-2012, 02:46 PM   #376
platinum5.9
2003 WJ
Originally Posted by TX-WJ View Post
Clayton's WJ rear axle bracket kit. Top notch stuff like all his goodies.
Ah it looks like very nice stuff. What are you doing for the front?
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2012, 03:08 PM   #377
TX-WJ
TX-WJ's Avatar
The front is done (just needs mounting); I just cut / raised and relocated the stock JK spring perches, re-inforced the stock LCA JK brackets, then added a new polyperformance trackbar bracket.
TX-WJ is offline   Reply With Quote Quick reply to this message
Unread 08-01-2012, 10:50 AM   #378
TX-WJ
TX-WJ's Avatar
Got back in town after vacation this weekend, came home to find the chromoly shafts for the rear JK44 waiting for me ; I wanted to go with the ten-factory ones, but those have been back-ordered for months, so I went with alloy USA ones instead; I had them press tone rings and retaining plates on the shafts so I can keep the stock shafts as trail spares. Took a few comparo shots with the stock rubi44 axles and the D44a shafts.
Chromo on the left, stock rubi44 on the right:
The splines are cold rolled and the splined section is slightly longer on the chromo shafts, the chromo ones are heavier as well:
Tone ring and retaining plate pre-installed:
Installing the lugs with a drop of the red stuff onto the flange:
Stock rubi44 on the left, stock D44a on the right; the JK shafts are clearly thicker (32 vs. 30 spline) and the bearings / retaining plate hardware / seals are all bigger as well:
This monring I finished cutting the fame side LCA brackets; actually instead of cutting them off completely, I made a slit on them then folded and rewelded them flat, thus bracing the frame rail, I figured this will keep some better structural integrity than just cutting them off; I then wire wheeled the clayton's subframe since I was getting a little surface rust and sprayed things with primer:
Rear LCA bracket:
Front LCA bracket:
Unread 08-01-2012, 07:28 PM   #379
platinum5.9
2003 WJ
Awesome work as always...
Unread 09-20-2012, 12:22 AM   #380
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Impatiently waiting for updates! hah. Can't wait to see what's been happening.
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote Quick reply to this message
Unread 09-20-2012, 07:32 AM   #381
platinum5.9
2003 WJ
Me too....
Unread 09-20-2012, 10:16 AM   #382
AustinTexasXJ
Witty Title Here
AustinTexasXJ's Avatar
hey man did you see the post in the texas forum section and in GCGD about a GRAND SLAM TEXAS?
Benjamin
>Dirty Betty II: The Story Continues..<
>ATXJ's $800 Dollar seXJ Build<
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline   Reply With Quote Quick reply to this message
Unread 09-26-2012, 08:14 PM   #383
Jcurl
Do you ever wheel East? There is a new place in Huntsville TexasOffroadranch check them out on face book. It looks like a lot of fun. I was at 4wd appreciation weekend at hidden falls and some guys from Texas4wd told me about it. I am gonna be taking a group out there on Nov 4th.
Jcurl is offline   Reply With Quote Quick reply to this message
Unread 10-08-2012, 05:23 PM   #384
platinum5.9
2003 WJ
Updates updates updates.....
Unread 12-09-2012, 08:10 AM   #385
shockracer
Spent 4 hours reading all this.
You have one hell of a build, well done so far!
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
[COLOR="SeaGreen"] Colorado Jeep Club Member #262[/COLOR]
shockracer is offline   Reply With Quote Quick reply to this message
Unread 09-13-2013, 10:51 AM   #386
Maybs
What happened
Where can I find the rest of your build.
Maybs is offline   Reply With Quote Quick reply to this message
Unread 01-08-2014, 12:22 PM   #387
RollMeOver_WJ
Great read! Good work!
RollMeOver_WJ is offline   Reply With Quote Quick reply to this message
Unread 03-09-2014, 10:44 AM   #388
platinum5.9
2003 WJ
Its been so long..... I hope this awesome wj is still alive!!!
Unread 03-09-2014, 09:44 PM   #389
TX-WJ
TX-WJ's Avatar
Yeah, the WJ's still alive , got busy with life but I'll make sure to update the thread (took plenty of pics along the way). Still working on a few things left (it never ends), but pretty happy with how it's all turned out so far.
In fact, today I worked on the radio antenna relocate and bend. I was tired of the antenna getting hung up on branches, but the most annoying part was having to take it off every time I got the jeep up on the lift (it would hit the ceiling of the shop). I decided to drill a hole in the fender closer to the body and then bend the stem to follow the lines of the A-pillar. To prevent it from flopping around and hitting the jeep while on the freeway (making noise), I accidentally discovered I could tuck it in the weather stripping by the passenger door and it stays in place nicely (not shown in pics). It's a stupid mod but worth it to me to not have to take the antenna off and on each time I put the jeep on the lift. I used a trim plastic rivet to cover the factory hole as a temporary fix, I'll come up with something nicer later.
Low riding 35"s
Sprayed the scratches with some Krylon.
Unread 03-10-2014, 02:37 AM   #390
HiPERnx
My wj don't have a antenna
All the European wj (wg) had the antenna built into the driver side rear window
It's maybe possible to retro fit to a American wj?
Gustaf Nilstadius, Sweden
Jeep WG -99 v8 BDS 2" lift RC .75" coil spacer & SS Spidertrax spacers
HiPERnx is offline   Reply With Quote Quick reply to this message
