TX-WJ's build thread. - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > TX-WJ's build thread.
Unread 10-01-2009, 08:46 PM   #136
TX-WJ
TX-WJ's Avatar
I gots me a part time dub jay!!
So, since I could not source a local 242HD, went to car-parts.com and found me one out of an '02 with 11K mi . It arrived today .
Next, TW SYE / DC shaft .
TX-WJ is offline   Reply With Quote Quick reply to this message
Unread 10-01-2009, 08:52 PM   #137
GraKee99
Rapist Wit
GraKee99's Avatar
Nice but should have done the 231 with the tera4:1 low kit. That would have been bad ***. But the 242 will be sick too.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2009, 08:58 PM   #138
TX-WJ
TX-WJ's Avatar
Yeah, I really debated on that a lot, but I went this way instead; I priced the 231 + Tera low kit, and it was a little more than what I wanted to spend. In fact, what I wanted was some kindda doubler set-up to have more speed options..... anyways, an ATLAS some day....maybe? . Imma re-gear the diffs though, and sticking to 35s, so I should be good for what I do.
Unread 10-01-2009, 09:00 PM   #139
TX-WJ
TX-WJ's Avatar
Originally Posted by Bama_WJ View Post
Ouch. Looks exactly like my D35 shaft when it broke. Make sure to replace the bearing and race on the side of the break.
Psst.... do you need a spare 44a housing by chance? for cheap .
Unread 10-01-2009, 09:14 PM   #140
GraKee99
Rapist Wit
GraKee99's Avatar
I need a spare Aussie locker 44a for cheap.
I hear ya, it is almost a grand for the 231 with the kit. The last 3 guys who helped me with CJ parts had atlas II in their riga. I was drooling a lot.
Brian
WJ, WK, CJ5
Unread 10-02-2009, 12:10 AM   #141
Bama_WJ
Originally Posted by TX-WJ View Post
Nah, not replacing it, will just wait for the JK swap to be complete.
D'oh, totally forgot about the JK axles. Brain fart.
No, the one I got is in pretty good shape. I can't wait to truss it. Thanks though!
Same here!
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 10-02-2009, 01:40 AM   #142
Shinobi
Sweet !! i got the same TC waiting for install .. will you be doing a write up for it so I can follow
Shinobi is offline   Reply With Quote Quick reply to this message
Unread 10-02-2009, 03:42 AM   #143
GraKee99
Rapist Wit
GraKee99's Avatar
There is one in the faq that nierce did.
Brian
WJ, WK, CJ5
Unread 10-03-2009, 06:28 PM   #144
TX-WJ
TX-WJ's Avatar
Today I took the 242HD case apart to inspect it and get the main shaft out; overall pretty simple process, just take your time and work carefully, you don't want to mess the aluminum case. I followed TW's website instructions here.
Start with this:
Remove the tail-cone, then you'll see an external snap ring right at the "speedo case" bearing (of course, no speedo on our WJs), remove it, then remove the speedo case itself.
Followed, remove the rear half case (tap it around with a dead blow hammer, again take your time, then use a flat head screwdriver on the side slots to carefully pry it appart, you'll brake the seal eventually, just takes a little bit of patience).
Now inspect things; no need to rebuild this puppy, everything looks good, and shifts well as should be expected for an 11K mi case.
The 242HD in all it's glory:
Then simply pull the main shaft out while working the chain off the front output chain sprocket at the same time; now you'll have a couple'a more snap rings to remove the intermediate sleeve and the planetary assembly off of the main shaft, and done.
Here's the main shaft and speedo housing ready to ship monday to TW to get SYE'd .
Unread 10-06-2009, 08:42 AM   #145
LSRGreg
i got a weird question for ya.. last weekend, i was on a pretty difficult trail, and when under a pretty decent load (trying to get front tire up a back cut ledge higher than axle center line) i got some popping noise like my t-case was skipping... i have heard of the chains skipping when they are really worn out, but this case only has around 80k miles, and i wouldn't think it could be that worn to cause that chain to be able to skip like that.
Since you have pulled your case apart, is there anyway i might have the shifter linkage not properly adjusted, to maybe cause it to skip like it did? Like it wasn't fully engauged?? I thought for sure i would be snapping a cv joint on my front axle long before i would have any issues with my 242...
G-
04 WJ, Limited, 4.7 HO, w/ lots of goodies
Incline Winch bumper from WWW.FRANTZDESIGNWORKS.COM
LSRGreg is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 01:16 PM   #146
SaturnICL
G-
My chain started slipping at 90k
[QUOTE=FPKites;7800928]You're all wrong....he's making side stingers
:rofl: :rofl: :rofl:[/QUOTE]:)
SaturnICL is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 01:24 PM   #147
TX-WJ
TX-WJ's Avatar
That is weird, but if it's truly a TC issue, then I would check the chain for loseness, and the shift forks for any sign of bending causing as you said, incomplete locking of the center diff. You sure it's not the front diff? (IIRC you have the QD diffs, right?, maybe one fo the clutches on the diff it's on it's way out from turning 35s? ).
Edit: You may want to check the U-joints on the front DS as well, dunno if you re-built it or not; I know you have a new rear DC DS so that one should be good.
Unread 10-06-2009, 01:27 PM   #148
bigbluezj94
1994 ZJ
jeep looks sweet. im staying tuned for the rubi swap.
[CENTER]94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
[COLOR="RoyalBlue"][B]BigBlue build 33s, 6in lift and short arms[/COLOR][/B]
[B][U][URL="http://www.jeepforum.com/forum/showthread.php?t=679496"]http://www.jeepforum.com/forum/showthread.php?t=679496[/URL][/U][/B]
[COLOR="RoyalBlue"][B]BigBlue build 3/4 ton axles, LAs, 37s [/COLOR][/B]
[B][U][url]http://www.jeepforum.com/forum/showthread.php?t=818891[/url] [/U][/B]
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
[color=Black][center][size=4][font=Showcard Gothic][color=Black][url="http://groups.jeepforum.com/Built_Not_Bought"][color=Black]Built Not Bought #033[/color][/url][/color][/font][/size][/center]
[/color]
[/CENTER]
bigbluezj94 is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 10:26 PM   #149
SaturnICL
G-
Oooo good point TX I did have an intermittent popping under stress in my front axle when the trak-lok was giving up the goast
Unread 10-07-2009, 01:40 AM   #150
Shinobi
heres the vid ... Is this the pops your talking about Gerg ??
[yt]MhWxo0zfzRA[/yt]
