Transmission problems - JeepForum.com
post #1 of 6 Old 12-08-2009, 03:22 AM Thread Starter
ddaniels72
1999 WK
Hi all thanks in advance for your help.
1. I have a 99 Jeep Grand Cherokee, 4.0L, Straight 6, 2 wheel drive. How can I find out which transmission I have? The 42re, 45rfe or 545rfe?
2. The transmission will over rev when shifting into 2nd or 3rd gear and when shifting into over drive when acceleratng. After the trans warms up the problem goes away. ( I've read about the codes here and mine is not giving any codes. After following steps 1 and 2 there are no codes displayed or flashes on the overdrive indicator light, and odometer reads done.
3. Last problem my air bag warning light goes on and off while driving around the city in stop and go traffic on the highway it's fine.
Thanks,
D
ddaniels72 is offline
post #2 of 6 Old 12-08-2009, 09:14 AM
97DCZJ
post this in tech section
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #3 of 6 Old 12-08-2009, 11:14 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
1. 42re was the transmission for all automatic grand cherokee 4.0's after mid 1993.
2. gov pressure sensor and solenoid probably need replaced.
3. might be clockspring, might be something else, need a drbiii tool to find out.
ratmonkey is offline
post #4 of 6 Old 12-08-2009, 11:38 AM
biggoofy
where can i buy both of those other than the stealership
Zack
98 Slate Grey 5.9
96 ZJ HP44 / 9" (RIP)
90 XJ on 33s (sold)
biggoofy is offline
post #5 of 6 Old 12-08-2009, 11:58 AM
MoonyJohn
MoonyJohn's Avatar
You dont have an OBDI, so you cant get codes through the OD light switch. Try taking it to a transmission shop to see if they can pull any codes
MoonyJohn is offline
post #6 of 6 Old 12-08-2009, 10:24 PM Thread Starter
ddaniels72
1999 WK
Thanks will def do next time
Thanks for the info. That's what I was thinking after reading and reading just wanted to be clear.
42re, great deals on eBay Motors, Automatic Transmission Parts on eBay!
Thanks MoonyJohn. Would they be able to do this at AutoZone with there diagnostic tool? Or is it transmission specific?
You guys are great thanks for the fast replys.
DD
Transmission problems. HELP! jmack549 WK Grand Cherokee & XK Commander Forum 9 10-31-2008 12:01 AM
transmission problems 01gt ZJ Grand Cherokee Forum 5 11-14-2007 06:47 AM
transmission problems jeepnurse ZJ Grand Cherokee Forum 7 08-28-2007 06:04 PM
Transmission problems dogbait ZJ Grand Cherokee Forum 1 06-05-2005 08:03 AM
Some transmission problems and then some BOOM ZJ Grand Cherokee Forum 16 04-02-2004 11:57 PM
