Quantcast transfer case damaged ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > transfer case damaged ?
Old 03-16-2010, 11:58 PM   #1
dishfear
i had a huge build this last 6 months , i bought a dana 44 for my rear end of zj . had to weld mounts on and buy axle shafts for it . the dana 44 is from a tj . my installer put the drive shaft in and i think its to long as the dana 44 pinon is an inch longer then a d35 . so its it int jeep and i have drove local for 1 day ,, speed bumps and reverse from drive way to road i hear this huge clunk , like its bottoming out . at frist i thought something was loose but i checked everything , now im sure its the drive shaft smashing into my transfer case . so i have stoped driving it and got another drive shaft at pick-a-part and am getting it shortened , now my question is , have i ruined my transfer case by driving it the little i have maybe 50k ?
dishfear is offline   Reply With Quote
Old 03-17-2010, 12:07 AM   #2
Virmagicus
Headed Out West
Virmagicus's Avatar
How do you know that it is indeed too short? Is it a external or internal slip TC ?
Virmagicus is offline   Reply With Quote
Old 03-17-2010, 12:28 AM   #3
dishfear
not to short , too long . and there is not enouf room for bumps and the drive shaft to move in and out . i have found a few threads that say xj swaps to 44 need an inch chopped off the driveshaft ,so it seems that if i remove a stock 35 for a 44 , i would still need to chop it . not sure what i have but its an quadratrac awd
Old 03-17-2010, 12:29 AM   #4
Virmagicus
Headed Out West
Virmagicus's Avatar
Ahhh typo ...my bad. There is damage that can be done...it all depends. It could damage your TC,axle, and driveshaft.
Old 03-17-2010, 12:32 AM   #5
dishfear
i know nothing , just that i spend a hella lot of cash on this setup and now i have a death clunk , want to fix it befor i load the family into it ,btw n00b to auto repair and to cheap to pay for it to get done . willing to get dirty thou
Old 03-17-2010, 12:34 AM   #6
Virmagicus
Headed Out West
Virmagicus's Avatar
Did you disco your driveshaft and see if that it is indeed too long?
Old 03-17-2010, 12:37 AM   #7
dishfear
the yoke is pushed all the way into the transfer case then squeezed into the rear , no room for play . like its a tight fit to tighten up
Old 03-17-2010, 12:37 AM   #8
dishfear
road driving is fine , just bumps and hils
Old 03-17-2010, 12:43 AM   #9
Virmagicus
Headed Out West
Virmagicus's Avatar
It's really a no brainer. If you removed it and there is no room and the slip yoke bottoms out you need to shorten the DS or try to shorten the shaft which is not easy if you are not experienced. Hopefully no problems will arise. You should be ok if it was only run for a short period of time. I noticed you said 50K and your from Canada so you should be ok if it is not 50 thousand miles ; )
Old 03-17-2010, 12:46 AM   #10
dishfear
droped off my drive shaft i got at a pick-a-part at the machine shop to be shortened today , 1 inch . but i mean , have i caused damage already to my tc? cause i have clunked it maybe 5-10 times
Old 03-17-2010, 12:46 AM   #11
dishfear
whats better , a 241 ,242n or my quadratrack
Old 03-17-2010, 01:02 AM   #12
Virmagicus
Headed Out West
Virmagicus's Avatar
242 .
Old 03-17-2010, 12:25 PM   #13
xgerstandtx
You have probably not damaged the Tcase. But that is speculation. The Shaft is Too long after the swap so cutting it and getting balanced is necassary.
And out of the Tcase options you listed the 242 is the best option. You can use the search function and find tons and tons of information.
xgerstandtx is offline   Reply With Quote
Glock Forum
