Towing 2010 Grand cherokee - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Towing 2010 Grand cherokee
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipSome Free shipping Coupon codes
Unread 02-06-2015, 07:18 AM   #1
Charlie2010
Hello, what is the best way to tow my jeep behind an RV? It is a limited with auto trans, so it is fulltime 4x4 and I don't have a way to shift it out, no other shifter then the 1 on the column. I thought I saw something where it said it couldn't be flat towed? So could I use a tow dolly?
Thanks in advance
Charlie2010 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 03:28 PM   #2
DeChache
2003 WJ
If you don't have the option to put the transfer case in neutral. Which is done by pushing the little button next to the "T-Handle" for 4LO. You have to get all 4 tires off the ground to tow it.
His 2003 Limited 4.7 QD 145K
Hers 2008 Laredo 3.7 QT1 119K
DeChache is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 10:36 AM   #3
Charlie2010
Thanks for the reply,I was hoping I could use a tow dolly and not have to get a car hauler trailer. Bummer
