-   Grand Cherokee General Discussion (http://www.jeepforum.com/forum/f197/)
-   -   TJ's ZJ Build (http://www.jeepforum.com/forum/f197/tjs-zj-build-1518251/)
tucsonzj 05-03-2013 01:20 PM
TJ's ZJ Build
5 Attachment(s)
So now that the parts have started arriving, it's time to start a build thread for fun.
Starting- 1995 ZJ, UC package, factory skid package, D30 & D35C with 3.73 Gears
So here's the list of Done's/to-do's
Parts that are already here
-New Pads & Rotors-Done, Stillen Cross-Drilled Rotors and Stillen Pads from Kolak
-3.5" RE- Done
-RE Front Adj Track bar & Rear track bar- Done
-Procomp 33x12.5r15- Done
-Uniden 510XL CB radio with FireStik 4' Antenna Done
-JKS Quicker Disco's Done
-Trimmed fenders Done
Future Mods (Pending money and parts :thumbsup:
-More lights!
-Steel Bumpers (tube front & rear with tire carrier?)
-"Monstaliner" rocks and cladding black
-Custom Storage Box
-Ford 8.8?
More will come as I think of them, but again this is just the beginning!
tucsonzj 05-10-2013 11:28 AM
2 Attachment(s)
2.25 bb
RE adj track bars front & rear
RE Twin Tube Shocks
31's
All put on.
So I have the factory skid package, I get some rub during full lock on the front bumper, considering just taking the whole bumper fascia off as it's barely hanging on anyways.
Would upload bigger pics but phone size is like 1.3 mb so I can't upload to the website as they were taken.
Myusername1674 05-13-2013 12:33 PM
Looks good! I like the setup you've got, looks pretty similar to mine! How do those a/t work? I almost went with those but decided on the treadwright m/t instead.
I'd say go ahead and ditch the fascia, maybe throw some paint on the metal till you build your own.
GCjunkie93 05-13-2013 01:08 PM
x2 on the fascia. What kind of bumper are you going with?
tucsonzj 05-13-2013 03:08 PM
5 Attachment(s)
So update on todays work:
Fascia came off, i'll post pics below, but it was being held on by 1 tree of the 4 ontop, can't believe it didn't fall off. Half of the plastic in the wheel wells were were unclipped as well, so I ripped all that out, there was a ton of crap behind it so cleaned it all out. So now some mud will get back there, but thats what a power washer is for. Might consider getting a plate tacked in there before winter to keep the salt out.
I'm thinking about doing the bumper from Notch Customs, i'm on their wait list and we'll see what I think come the time they call my number. I do like the tube bumper from KOR, but the price is steep for my budget. I'd love to just bend and weld one myself, but no equipment to do that.
On it's voyage to work the fire captain hit his siren at me, I'm assuming to warn me they don't want me with no bumper cover. So I might grab a strip of sheet metal from Home de-pot and just screw it in to keep them off my back.
Oh and banged that stupid a** strip of steel inside the from wheel wells that's asking to rip open my new tires. BFH made the job easy.
tucsonzj 05-13-2013 03:09 PM
I really like them so far, Saturday is Go Topless Day, so I'll be testing them out on the trail runs and will report back. I wanted to go with the m/t but it's my dd so didn't want to run them down on the roads.
tucsonzj 05-13-2013 03:10 PM
2 Attachment(s)
ok, so the only negative I've found in my set up so far (and it's really not that bad) is my rear track sits on my exhaust. Not a big deal, doesn't squeak or rattle, but won't be going up to the 3" pipes anytime soon haha.
ZJNewbi3 05-13-2013 09:07 PM
I got the same shocks and lift coming in the mail and was wondering how they are treating ya? Love the build!
tucsonzj 05-14-2013 03:14 AM
Like them a lot, expect the rear spacers to fit a little odd at first, but when you put the spring back up it is fine.
I ride a little stiffer with this set up, which is fine for me because the shocks are 1000x better then the UC ones that I had on.
tucsonzj 05-14-2013 03:32 PM
2 Attachment(s)
After work found a hill of rocks, played around a little.
As I was leaving a cop was pulling in, assumed he was coming to yell at me haha.
tucsonzj 05-16-2013 03:15 PM
cb antenna and install kit got here today. Will install mount and run wires to wait for the radio to get here tomorrow.
GCjunkie93 05-16-2013 09:07 PM
What cb did you get?
tucsonzj 05-16-2013 09:22 PM
Uniden 510xl. Was adviced to cheap on the cb, get a good antenna. So I got a fire stick 4' antenna. I'm finishing install of the antenna and the radio is suppose to be here tmrw so ill throw that in. Since jf is being a PITA and messed with the photo upload, I can't upload directly from my phone. Don't want to photobucket cuz once they trash their server since you have the free account there goes my build thread. So ill have to download, resize, then upload.
tucsonzj 05-17-2013 01:03 PM
8 Attachment(s)
So got the quicker disco's on today. Was actually an easy swap out. As usual for me I over thought the process. they work like a charm. Still need to finish up the tie up so when they're disconnected they don't get in the way.
Also finished up the antenna/cb install and hook up today.
I'll kinda walk though how I did it for those who want to know.
On my first I found a place where I had easy access to the metal body without tearing up the plastic. There's an access panel on the drivers side for the tank release. You can reach all the way through. So I drilled through there and secured the mounting bracket. I pulled the tail light and drilled a large hole to run the coax cable through and out (if you do this, line the cable with extra electrical tape to keep it from getting cut). After that I ran a ground wire (from some 240v wiring cable, so it's the good copper stuff) down through the tail light, behind the rear bumper down to the unibody attachments so it's grounded. got all the lengths right and then taped the ground to the coax cable outside so it looks nice a clean then put the tail light back. After that I ran the cable under the wheel well carpet/floor crack all the way up, under the back seat, under the drivers seat and under the center console. I didn't have time to finish cleaning up the wiring cover up before work so i'll do that tonight.
As for the Cb it self. I wanted it to shut off automatically with a fuse when I turned the key on/off. So I pulled my fuse access panel on the passenger side dash, used the fuse that links with the cigaret lighter (since I don't use it anyways) and jammed it in there. Ran the wire hidden inside the dash and under the VIC. After that I ran a ground directly from my battery along the inside upper wheel well on the passenger side (again using the 240V ground wire) through the fender and through the door jamb. Worked out nicely I think. All the pics are below. Want to see something else or a different angle let me know.
Edit: the reason why I did it in this location ontop of easy of install, is easy of hiding the wiring when not in use. People around here will steal my antenna if I left it on all the time, so now I can take off the wiring and antenna. Put the wiring behind the tail light when not in use (it's 3 bolts and pull for a tail light, so easy access) and just leave the mounting bracket out there
DNFJ 05-18-2013 03:41 PM
Go to advance auto and get an add a circuit. Plugs into a fuse and much safer than doing what you're currently doing. Otherwise, nice work.
The time now is 05:55 AM.
