Tj's 01 WJ Build thread - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Tj's 01 WJ Build thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 09-28-2012, 10:37 AM   #76
TJSWJ
Originally Posted by ARdirty View Post
Tj- I waslooking at the pull-a-part website and saw that I could get an entire axle assembly for 125$.
If I found a v8 wj with a 44 and the quadradrive- could I just swap it on? I've done brakes, axle shafts, control arms so I feel like installing it back on to my jeep wouldn't be that hard.
Originally Posted by AustinTexasXJ View Post
it would be very easy to swap that axle in. there is a good write up here on jeep forum. search around a little bit
agreed, you could very easily swap it over. Thats a good price too!
[URL="http://www.jeepforum.com/forum/f197/tjs-01-wj-build-thread-1023461/"]4.5" Claytons, 33's, 231hd, locked, and more. Click here for details[/URL]
TJSWJ is offline   Reply With Quote Quick reply to this message
Unread 09-28-2012, 09:04 PM   #77
TJSWJ
Originally Posted by Bama_WJ View Post
Good deal. You did get the bearing, washer, castle nut and cap for the swing arm right?
I know I gave your buddy those small parts along with the lug nut socket and he put it in a small tool box.
Yep, got everything I need.
Unread 11-16-2012, 09:42 PM   #78
TJSWJ
Ive really neglected this thread because there are just way to many build threads going on in the general discussion thread. If anyone wants any info on my jeep, you can find the build thread I actually use here http://www.xjor.org/forums/viewtopic.php?f=26&t=243
Unread 03-10-2013, 09:10 PM   #79
Bama_WJ
Nice meeting you today. Cool to finally put a face with the username.
Look forward to some nice updates!
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 03-10-2013, 10:49 PM   #80
TJSWJ
It was good finally getting to meet you as well. Thanks for the hook up!
Ill do an update to this thread for anyone who may be following along, tomorrow.
With the claytons ill be installing:
231HD with sye, wide chaing kit, 6 pinion planetary, and terra 2lo that I built and is sitting on my bench.
505 performance stage 1 cam kit
6 hole bosch injectors
Ill be porting and polishing my intake and cylinder head
Rocker panel delete with 2x6 3/16th tubing put in place
Tank tuck
And there are probably a few other things that I forgot about.
Unread 03-12-2013, 06:10 PM   #81
TJSWJ
Pics of my parts gathering
Also got this new toy. Thinking about building an aluminum/uhmw belly skid.
Disc brake conversion brackets for the sterling
more axle brackets
pics from the 231hd rebuild/ upgrade: Sye, new bearings, wide chain and seals, terra 2 lo, 6 pinion planetary set
Unread 03-12-2013, 08:34 PM   #82
mtnmarc
I want that 2lo kit. And 4:1..
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 03-12-2013, 10:17 PM   #83
TJSWJ
If your going to build a 231 mated with big axles, I think the 2 lo kit is a must. Especially for how cheap it is. the 4:1 kit on the other hand is freaking pricey! As much as I wanted to do a 4:1 while I had the case apart, I just couldnt justify the extra grand. At that point I might as well just started off with a 241OR from a rubi. But... if I find a deal on a 4:1 kit for the 231 I will jump on it and just tear the box apart again.
Unread 03-12-2013, 11:22 PM   #84
mtnmarc
I mean, to get 2lo you can unlock your hubs. I might have to look into that.
Unread 03-13-2013, 12:11 AM   #85
TJSWJ
yeah, but that requires getting out and into the mud/rocks/sand/whatever. The beauty of the terra 2 lo is that you can shift in and out of 4lo/2lo on the fly. Its mostly used to make sharper turns with a locked front diff (which with a wj you can use all the help you can get for tighter turns). Also, if your front wheels have no traction, but your rear wheels are bitting, you can remain in lo and send all the engine power to the rear wheels instead of burning it up sending power to the front.
Its a VERY simple install for any 231 case. Hell, anything on the 231 is easy to do. Its one of those things that if your already into your t-case (sye install or whatever) you might as well do this too, its that simple.
Unread 03-13-2013, 12:44 AM   #86
mtnmarc
That's why I got an e locker :-)
I've been looking and reading at the 2lo kit. I may just have to get it since I'm putting in an sye.
Unread 03-13-2013, 08:15 AM   #87
TJSWJ
ah, e-locker. I forgot you went with that, NICE! I really want to do a full case locker up front, but its just not in the budget right now. Plus I already have an aussie for it.
Unread 03-15-2013, 12:08 AM   #88
mtnmarc
What size tires are you gunna run?
Unread 03-15-2013, 12:13 AM   #89
TJSWJ
Short term goal of 36's, long term goal of 37's on a 17" wheel. I still havent made my mind up on gearing. Its going to be either 5.13's or 5.38's, still gotta spend some more time with a gearing calculator.
Unread 03-15-2013, 10:01 AM   #90
mtnmarc
I have 5.38s with a 4.7 and 37s. I'll let you know how it is when its done.
