Tj's 01 WJ Build thread - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Tj's 01 WJ Build thread
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 06-10-2013, 06:03 PM   #241
TroubleNEO
This is what I got:
http://www.pscmotorsports.com/motors...-hose-kit.html
Not sure what the rating is since it hasn't come yet, but all their other hose is goodyear so far...
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline   Reply With Quote Quick reply to this message
Unread 06-12-2013, 11:06 AM   #242
TJSWJ
Picked up a Everlast Power Ultra 250P last night. It can be used for Stick and DC TIG welding as well asa Plasma cutting up to 5/8 steel . Only thing I plan on using it for is as a plasma cutter. This machine along with my Thermal arc 185tsw TIG welder puts me one step closer to making aluminum/uhmw skids.
[URL="http://www.jeepforum.com/forum/f197/tjs-01-wj-build-thread-1023461/"]4.5" Claytons, 33's, 231hd, locked, and more. Click here for details[/URL]
TJSWJ is offline   Reply With Quote Quick reply to this message
Unread 06-12-2013, 11:19 AM   #243
TroubleNEO
You got a damn good deal on that thing too. How clean of cuts does it make? The one I used during my lift was horrible, but it had really bad old tips that needed replacement. On the other hand I saw someone outboarding shock mounts and cutting the frame with one, and it looked only slightly rougher than a grinder cut.
I might have to rent that from you when I do my outboard.
Unread 06-12-2013, 03:19 PM   #244
TJSWJ
I dont know how well it cuts yet, I have to order a set of cones, consumables, and an air dryer before I use it.
Unread 06-12-2013, 04:26 PM   #245
TroubleNEO
Ah! Of course with a deal like you got it would need consumables, figures.
Unread 06-12-2013, 05:48 PM   #246
TJSWJ
I bought it knowing that it needed consumables. It can take harbor freight consumable but I chose to stick with everlast. 85 shipped for a 25 piece set puts me at 535 for a working plasma cutter (the TIG and Stick torches and pedal assembly are brand new never used), not bad for a 2 year old unit thats 995 new.
As far as the steering goes, box is competely tapped. Ill be cleaning it and re-assembling it tomorrow. Just been super busy trying to put our John Deer front end loader back together, havent been getting long lunch breaks.
Unread 06-16-2013, 09:52 AM   #247
CountryRebel60
2008 WK
man havent I taught you anything? john deere are pieces of ****
CountryRebel60 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 12:40 PM   #248
TJSWJ
Nah, this one is die hard! Then again, it was built back when things were built to last. Its a 76 John Deere 544B
Man in the shiny brown van just dropped off my ram. Scored a lightly used psc 1.5" bore, 6" stroke ram off of Pirate4x4. Im happy to report that so far im into my hydro assist steering for under the 300 dollar mark as far as parts go. That includes: Gearbox and Pump seal kits, 2 snap-on 1/4 npt taps, 2 drill bits, -6AN adapters for the gear box and the cooler, Derale heat sink cooler, and now the ram.
Looks like all the rest of the fittings, and hoses to plumb the ram,cooler, and power steering hoses are going to be right around 160 or so. Then the tube clamp to bolt the ram to the tie rod is 42.00, then prolly about 20 bucks in metal to make the axle side mount. Im shooting to be under the 500 dollar mark once its all finished and I actually get a chance to add up the receipts.
Unread 06-17-2013, 01:55 PM   #249
TroubleNEO
Nice! Mine is all done and plumbed minus the ram, just waiting on that now.
Unread 06-17-2013, 02:01 PM   #250
dillonjm
Looking good. Love to see your parts list/write up when your done. I'm sure I'll do something similar in the future.
[B]03 Rubicon[/B] (Weekend Toy) [URL="http://www.jeepforum.com/forum/f176/marshals-03-rubi-2822258/"]Build thread[/URL]
[B]11 Ram 2500 [/B] - H&S tuned 6.7 Cummins (DD/Tow Rig)
[B]05 Liberty Limited[/B] (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 02:25 PM   #251
TJSWJ
Ive been taking a ton of pictures, and Im saving all the part numbers. Im going to post everything once I have it finished, that way I know it works as it should.
Unread 06-18-2013, 12:20 PM   #252
TJSWJ
On the topic of the loader.... Started pulling a front axle for elcorvino
Unread 06-18-2013, 12:22 PM   #253
TroubleNEO
I've always wanted to just ram a vehicle and stab it with one of those.
Unread 06-18-2013, 04:15 PM   #254
TJSWJ
Its more fun to lift them all the way up then drop them
Unread 06-21-2013, 10:56 PM   #255
mtnmarc
Any news on the box rebuild?
And list of fittings
Gotta reseal my box and I'm gunna tap it while its apart.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
