Tj's 01 WJ Build thread - Page 15 - JeepForum.com
post #211 of 389 Old 06-03-2013, 01:31 PM
mtnmarc
Greg had a pretty janky p/s system. Factory hoses doing circles cuz he has done some body work.
But he's completely redoing it with all new lines and pump with a massive cooler. It should be pretty nice when its done.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #212 of 389 Old 06-03-2013, 01:40 PM Thread Starter
TJSWJ
lol, I stand corrected. Im sure whatever he is planning its going to be sick!
TJSWJ is offline
post #213 of 389 Old 06-03-2013, 06:58 PM
CountryRebel60
2008 WK
you need to pimp that yota out haha. let loose with some camo paint on that thing
CountryRebel60 is offline
post #214 of 389 Old 06-03-2013, 08:41 PM Thread Starter
TJSWJ
That actually might not be a bad idea. It would help cover up the massive bondo fail on the drivers rear quarter panel. I very well may have to do that. Maybe we will have a camo paint party next time your up.
TJSWJ is offline
post #215 of 389 Old 06-04-2013, 01:01 AM
CountryRebel60
2008 WK
hell yea and paint the punisher symbol on the hood!
post #216 of 389 Old 06-04-2013, 07:10 AM
TroubleNEO
Hows working on the assist doing? I pulled the trigger on the pump and reservoir, will probably be getting the rest here soon. We'll probably be doing ours around the same time, we could have a hydro install party.
Basically just waiting to get everything aligned and make sure there are no steering issues before throwing anything on.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #217 of 389 Old 06-04-2013, 08:10 AM Thread Starter
TJSWJ
I just got the rebuild kit in yesterday, sadly its not a "rebuild" kit per say, more of just a complete seal kit since it didnt include any bearings. After looking for a second time I cant seem to find a kit that includes any bearings, so im just going to use the seal kit.
Now that my hectic schedule is slowing down I can start getting back to doing little things on my lunch breaks at work. So today ill be going out back and pulling a gear box out of one of the parts wj's and I should be tearing into it tonight or tomorrow.
What pump/resi kit did you go with? Im not going to do a pump upgrade yet, but that factory style aluminum reservoir that PSC is blowing out right now looks pretty damn sexy. Im thinking of ordering it when I order my ram. Im still trying to figure out wether to go with a 1.5" bore or a 1.75" bore ram. Im leaning towards the 1.5" since the wj see's a lot of street driving, especially in winter. Im worried the 1.75 would be too slow for a street vehicle, but im waiting to hear back from PSC.
TJSWJ is offline
post #218 of 389 Old 06-04-2013, 08:18 AM Thread Starter
TJSWJ
lol a punisher symbol might be a little much for the little toyota lol. But who knows what would happen with You, Cricks, Yuhas, and I getting together for the paint job lol.
TJSWJ is offline
post #219 of 389 Old 06-04-2013, 08:43 AM
TroubleNEO
I got the remote res kit. The ones that are on sale are on sale for a reason, and that's because they suck and cause cavitation. There have been threads on here about that specific res and the problems were fixed when putting the remote on which has baffling and whatnot. I even talked to Lance last week and said I didn't want to run the built in aluminum res one they make and he said "Yeah you definitely don't want that for an assist kit, you want the remote res pump kit."
There is a reason all the good assist/full hydro setups have a remote res, and the placement of it is just as important. I would run the aluminum tank replacement res if I was just upgrading the steering pump and that's it.
post #220 of 389 Old 06-04-2013, 09:09 AM
TroubleNEO
Yep, after looking into it, with free shipping and $25 more you can have this, and it has a big *** 10AN feed to the pump.
http://www.quadratec.com/products/56112_8017.htm
post #221 of 389 Old 06-04-2013, 09:11 AM
TroubleNEO
Here is that Reservoir with baffling and the filter.
post #222 of 389 Old 06-04-2013, 10:14 AM Thread Starter
TJSWJ
Yeah, Ill prolly just go that route then. I just didnt want to try and find a place to mount it, but that shouldnt be too much of an issue.
TJSWJ is offline
post #223 of 389 Old 06-04-2013, 11:00 AM
TroubleNEO
Reading on their site too, it looks like you want the reservoir above the pump inlet if possible, and less than 16" away. Crazy how much small things matter, but then again you are dealing with moving a lot of fluid at a high psi.
post #224 of 389 Old 06-04-2013, 05:21 PM Thread Starter
TJSWJ
Yeah that fancy stuff is going to have to wait for now. Im just going to stick to the original plan and use the stock pump and see how it works.
Got a gearbox out of a parts wj today and got it on my bench. I started looking at it and realized I ordered the wrong size fittings. I ordered 3/8npt when I needed 1/4npt. So Ive got new fittings and a tap on the way, should all be here friday.
As far as the ram goes, the wj steering has 6" of travel. Perfect for a 6" ram. But, keeping in mind the axles im building, I may need a larger ram down the road once the new axles are finished. Now im torn. Do I order the 6" ram and use it untill the axles are ready? Or do I order the 8" ram and internally limit it, that way I buy it once and am done? The second option is more work obviously. Im leaning towards getting the 6" and using it, then selling it when I need the larger one.
TJSWJ is offline
post #225 of 389 Old 06-05-2013, 08:58 AM
TroubleNEO
You shouldn't have an issue selling the 6" ram once you're done with it, thats the same stroke I just ordered....
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
Moparmatters Build Thread moparmatters Grand Cherokee General Discussion 27 12-08-2009 10:53 PM
