Think Twice Garage's Project TPFB - Page 14 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Think Twice Garage's Project TPFB
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-13-2012, 07:33 PM   #196
CTeunuch
Found one solenoid to be bad, I had been testing them incorrectly. The Warn solenoids ground through the mounts, not through the second small post, which explains why I was having problems troubleshooting them. At least I got the new one ordered, should be here Friday, so the winch will be read for Rausch.
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
www.undergroundjeeps.net
CTeunuch is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 08:05 PM   #197
billyjp2
1994 XJ Cherokee
Hows the 42RH swap coming along? I think this thing is gonna kick major dick with a slush box.
billyjp2 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2012, 08:46 PM   #198
CTeunuch
HI BILLY YOU KICK DICK BRAH
Think Twice Garage
Unread 06-15-2012, 07:30 AM   #199
squashman702
1994 ZJ
BA10 swap bruh.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2012, 10:45 AM   #200
billyjp2
1994 XJ Cherokee
I love me some peugeot
Unread 06-15-2012, 04:12 PM   #201
CTeunuch
Nothing makes me happier than a french tranny.
Think Twice Garage
Unread 06-16-2012, 08:09 AM   #202
squashman702
1994 ZJ
And a bad one at that.
Think Twice Garage
Unread 06-18-2012, 08:40 PM   #203
CTeunuch
Originally Posted by CTeunuch View Post
Bold stuff is done.
Supposed to wheel this weekend, before I do I'd like to:
-Install t-case skid
-Rebuild front shaft
-Hook up t-case linkage
-Fix winch - Sort of, I have power in at least
-Install passenger seat so I can pretend I has frendz
-Swap in Durango box
-Swap sway bar bushings
And before I go to Rausch in a few weeks I'd like to:
-Replace D30 pinion bearing half-*** style
-Swap in WJ leather seats and new carpet
-Rebuild a set of spare shafts
-Build a roof rack? - Didn't end up needing the space
-Fix e-brake - Broke the adjuster trying to free it up, so this will have to wait
-Alignment
-Lube/Check/Tighten erraythang - Last thing to do on Wednesday
I'm doing laundry/packing tomorrow, then final checks Wednesday before we head out around 8pm. I'm getting excited finally...
Think Twice Garage
Unread 06-24-2012, 09:28 PM   #204
CTeunuch
1 dislocated shoulder + 1 destroyed Jeep = 2 disastrous trips to Rausch Creek.
Expect a big update later in the week, followed by either a part out or major reconstructive surgery.
Think Twice Garage
Unread 06-24-2012, 09:33 PM   #205
PurpleZJ
wtf man. heal up soon, looking forward to the update.
1996 ZJ- 4.0, [COLOR="Purple"]AX-15 5SPD/NP242[/COLOR], RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
[CENTER][COLOR="Blue"]RIP Troy (bigbluezj94) you wont be forgotten[/COLOR]
[COLOR="Purple"]December 2010 GCOTM[/COLOR]
5spd ZJ Club Member 001
[/CENTER]
[QUOTE=bddisi;6376248]Glad you are ok. If you were a cat, you would be down to 8.:D[/QUOTE]
[QUOTE=Greengc4x4;10782815]Everything looks great, Hellen Keller! :D[/QUOTE]
[QUOTE=rritch;10960201]plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:[/QUOTE]
[CENTER][COLOR="Purple"]RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11[/COLOR][/CENTER]
PurpleZJ is offline   Reply With Quote Quick reply to this message
Unread 06-24-2012, 11:58 PM   #206
SnowLeopard
^ What he said. Heck, Jeepers are taking a lot of blows.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote Quick reply to this message
Unread 06-25-2012, 09:02 AM   #207
little_Jeep
Sheet metal is replaceable....... your body parts aren't. Hope you have a speedy recovery.
BTW.... post lost of pics and then come back to this thread to post a link to them or your trail ride summary.
little_Jeep is offline   Reply With Quote Quick reply to this message
Unread 06-25-2012, 12:20 PM   #208
wj4play
wj4play is offline   Reply With Quote Quick reply to this message
Unread 06-25-2012, 12:42 PM   #209
AgitatedPancake
Ahh shoot man, ya can't leave us hangin! What happened!?
Get well soon, and rebuild it dont part it out
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 06-25-2012, 03:36 PM   #210
WJ04
This ^^^
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
October 2011 GCOTM Winner
Some of my videos: http://www.youtube.com/user/LockedWJ?feature=mhee
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline   Reply With Quote Quick reply to this message
