Think Twice Garage's Project TPFB - Page 5 - JeepForum.com
post #61 of 540 Old 10-24-2011, 08:57 AM
jeep360limited
Nice looking zj!
Charlie
2003 Ford Ranger Edge
1986 Jeep CJ7
1998 Jeep Grand Cherokee 5.9 Limited-----SOLD
jeep360limited is offline
post #62 of 540 Old 10-24-2011, 01:06 PM
aircruiser
aircruiser's Avatar
Looks good man so after wheeling an XJ compared to a ZJ, which do you prefer? Same with auto to stick. For me it just seemed like the ZJ did better all around. More stable, more comfortable, I'm just debating on picking up an XJ or another ZJ for a beater after I get my truck. Really leaning towards another ZJ
aircruiser is offline
post #63 of 540 Old 10-24-2011, 06:14 PM Thread Starter
CTeunuch
Thanks for the compliments guys.
As far as ZJ vs XJ, I'm not 100% because it's a fairly uneven comparison of my two. I started wheeling a ZJ too, 4.5" on 33's open/open. Comparing my XJ when I started, 3"/33's open open to the first ZJ, I have to say ZJ I think. The suspension flexes much better with fewer mods, and obviously doesn't have any annoying spring wrap. It's also a LOT nicer inside.
Stick vs auto, hands down stick is better. It's much more of a challenge than auto, but that's what the sports all about right? It wasn't as difficult as I expected, though I did stall 7 times, but it did give me a lot more control over the rig. I think once I get better at picking the right gear in 4 low for the obstacle I'll like it even more. So my advice is find an OBD1 ZJ 4.0 and swap an AX-15 in, or if you get lucky like I did find a real one in decent shape.
Now for some bad news. I forgot to run a breather line, and the rear axle filled with crap. On the way to/from work today it was howling like a banshee when I was on the throttle, and quiet when I got off it. I changed the fluid tonight, and it's still loud at speeds and it growls when I go ~15mph. Seems like I'm going to be rebuilding the 8.8 sooner than I thought. Do you guys think I should
A. Pick up a V8 ZJ from a friend for $200, steal the axles, then junk it. Possibly Aussie the 44A
B. Rebuild the 8.8 with a free LS
C. Rebuild the 8.8 with a Detroit, like I planned when I go to 4.56's
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
CTeunuch is offline
post #64 of 540 Old 10-24-2011, 06:16 PM
little_Jeep
Originally Posted by cteunuch View Post
thanks for the compliments guys.
As far as zj vs xj, i'm not 100% because it's a fairly uneven comparison of my two. I started wheeling a zj too, 4.5" on 33's open/open. Comparing my xj when i started, 3"/33's open open to the first zj, i have to say zj i think. The suspension flexes much better with fewer mods, and obviously doesn't have any annoying spring wrap. It's also a lot nicer inside.
Stick vs auto, hands down stick is better. It's much more of a challenge than auto, but that's what the sports all about right? It wasn't as difficult as i expected, though i did stall 7 times, but it did give me a lot more control over the rig. I think once i get better at picking the right gear in 4 low for the obstacle i'll like it even more. So my advice is find an obd1 zj 4.0 and swap an ax-15 in, or if you get lucky like i did find a real one in decent shape.
Now for some bad news. I forgot to run a breather line, and the rear axle filled with crap. On the way to/from work today it was howling like a banshee when i was on the throttle, and quiet when i got off it. I changed the fluid tonight, and it's still loud at speeds and it growls when i go ~15mph. Seems like i'm going to be rebuilding the 8.8 sooner than i thought. Do you guys think i should
a. Pick up a v8 zj from a friend for $200, steal the axles, then junk it. Possibly aussie the 44a
b. Rebuild the 8.8 with a free ls
c. Rebuild the 8.8 with a detroit, like i planned when i go to 4.56's
c
little_Jeep is offline
post #65 of 540 Old 10-24-2011, 06:38 PM
Freestyle713
1994 ZJ
zj's looking good. where are you wheeling in those pics? might have to go there some time
Freestyle713 is offline
post #66 of 540 Old 10-24-2011, 09:05 PM
Spike300
keep the 8.8
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #67 of 540 Old 10-24-2011, 09:25 PM
1stblack97ZJ
definitely option b or c
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #68 of 540 Old 10-25-2011, 03:24 PM Thread Starter
CTeunuch
B or C were my main choices, it just depends on my budget. If I can sell the 2 D60 lockers I have, then I'll definitely go Detroit, otherwise it would be a few weeks before I could cough up the ~$800 for a Detroit and overhaul kit. Not sure I really want to spend that much on a toy right now, but we'll see. I'd consider a lunchbox, but I've had bad luck with them in the past. Thanks for the input guys.
EDIT: My only other 'concern' with putting in a Detroit now is that I eventually want to run 33 or 35 spline Dutchman's in the rear, and it would be a shame to have to buy a new locker when I do that. Maybe double packing the LS is my best bet for now...
Think Twice Garage
CTeunuch is offline
post #69 of 540 Old 10-28-2011, 04:30 PM Thread Starter
CTeunuch
I ended up going with option B to save some cash and get the axle done faster. I ordered the install kit and a lubelocker today from ECGS, only ~$130 total with shipping. I'm planning to get into it 2 weeks from now because I have some side work lined up next Saturday, until then I'll just cross my fingers and hope she doesn't blow her guts on the highway. Between now and then I'll double pack the factory L/S I got from Squash to get a little more oomph out of it.
Think Twice Garage
CTeunuch is offline
post #70 of 540 Old 10-29-2011, 08:30 AM Thread Starter
CTeunuch
Maybe these, opinions?
http://www.discounttiredirect.com/di...n=72&typ=Truck
Think Twice Garage
CTeunuch is offline
post #71 of 540 Old 10-29-2011, 09:32 AM
squashman702
1994 ZJ
Originally Posted by CTeunuch View Post
Maybe.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #72 of 540 Old 10-29-2011, 10:00 AM Thread Starter
CTeunuch
I think they look sick in the black/silver, but the offset is terrible.
Also, it looks like I have a trade lined up for a 231 with a RR SYE already installed. I really wanted a D300, but this will work for now.
Think Twice Garage
CTeunuch is offline
post #73 of 540 Old 11-03-2011, 05:23 PM Thread Starter
CTeunuch
Some goodies came in today from ECGS, so now I have all the parts to rebuild the 8.8, but still no dial indicator. The MAC guy at work promised me a nice digital one for next week, but it turns out they're back ordered and anything else he offers is well over 2hunge. It turns out I can get an indicator and a stand with on/off switch from ECGS for $45, which is less than half the MAC price. I wish I'd known that last week....
Also tonight I fixed the clunk in the front end I've had since wheeling. I guess I wasted the stock trackbar, so I threw my Rusty's adjustable one in, with a new TRE instead of the conversion bushing. I replaced the axle end bushing too, I figured 3 seasons of hard wheeling were enough for it. I have to say that despite how much **** people talk about Rusty's quality, I've never had an issue. This trackbar has been in three Jeeps now, two of which were jumped multiple times, and it's still straight as the day I took it out of the box. Their customer service is excellent too, I called the other day to make sure this trackbar would work under 4" of lift and they were very polite and knew the answer without having to look anything up and make me wait. Big ol' thumbs up to them.
Think Twice Garage
CTeunuch is offline
post #74 of 540 Old 11-03-2011, 05:29 PM
1stblack97ZJ
I like em.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #75 of 540 Old 11-04-2011, 09:39 PM
MoonyJohn
I love red laredos.. I want mine back now. Anxious to see this build!
MoonyJohn is offline
Project Zoe WCHLVR Grand Cherokee General Discussion 27 04-15-2013 11:43 AM
A New Project stmprnch ZJ Grand Cherokee Forum 3 05-02-2010 05:00 PM
YJ Project GumboroJeep10 Wrangler General Discussion 1 04-21-2010 12:53 PM
My project dodgetk81 Wrangler General Discussion 1 06-13-2008 09:45 PM
My New Project! BlackPearl96 ZJ Grand Cherokee Forum 13 02-27-2007 08:29 PM
