which is thicker 15w 40 or 20w50 - JeepForum.com
post #1 of 22 Old 08-14-2009, 10:18 PM Thread Starter
austtill
1992 XJ Cherokee
ok guys i know this is a stupid question which is thicker 15w 40 or 20w 50.i want to put a thicker oil in my jeep but i dont which is thicker or maybe u guys could suggest a weight of oil to use.thanks.
austtill is offline
post #2 of 22 Old 08-14-2009, 10:31 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
The higher the number, the higher the viscosity.
In XX-W-XX multi-weight oils, the low # reflects the cold viscosity, the high # reflects the hot viscosity.
20w50 is thicker at both low and high temps than 15w40.
'09 Rubicon
Kruzin is offline
post #3 of 22 Old 08-14-2009, 10:34 PM
comptiger5000
Kruzin - Other way around on the hot vs cold. A 15W-40 is designed to measure the same as a hot 40 weight when hot, and the same as a cold 15 weight when cold. Still thicker when cold, however.
comptiger5000 is offline
post #4 of 22 Old 08-14-2009, 10:37 PM
TowMaster
Thats how I always knew it ^
NightCrew #125
Why don't they have braille at drive-thru's?
TowMaster is offline
post #5 of 22 Old 08-14-2009, 10:43 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You are correct...Typing faster than thinking...and I corrected my post.
'09 Rubicon
Kruzin is offline
post #6 of 22 Old 08-14-2009, 10:43 PM Thread Starter
austtill
1992 XJ Cherokee
what i want is a weight to hold better oil pressuse at both ends something that wont drop off when hot.but still have high when cold dont know if i can find that or not.
austtill is offline
post #7 of 22 Old 08-14-2009, 10:49 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
10w30 or 10w40 will do just fine. Even 5w30.
It's just oil. As long as you keep it clean, change it at regular intervals (3-5k), you're gonna be fine.
Oil pressure means jack. As long as oil is flowing, it's all good.
If you put a high velocity oil pump in, you'd get higher pressure all the time...but it aint gonna help anything.
'09 Rubicon
Kruzin is offline
post #8 of 22 Old 08-14-2009, 11:02 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Oil pressure is not important? Ok thats a new one. I guess ill be fine going down the highway towing a trailer in 100F heat with 5 lbs of oil pressure and be ok? Dont think so.
WiCkeDuDe is offline
post #9 of 22 Old 08-14-2009, 11:06 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
If you have this scenario, you probably have a bad oil pressure sender, causing a false reading on your guage.
Factory guages are notoriously inaccurate.
'09 Rubicon
Kruzin is offline
post #10 of 22 Old 08-14-2009, 11:10 PM
elmer_fud
no, but you should be fine with anything above 30
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #11 of 22 Old 08-14-2009, 11:25 PM
moparrr07
yeah on the off chance that the gauge might actually read right for once, even if you have 40 psi, you could have a hhuge blockage still that keep the pressure up but your not actually flowing to the important stuff
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #12 of 22 Old 08-15-2009, 10:42 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Um yeah. Heard of being sarcastic anyone? Oil pressure is a important factor as well.
post #13 of 22 Old 08-15-2009, 11:06 AM
4jeepers
I second that motion!
4jeepers is offline
post #14 of 22 Old 08-15-2009, 02:06 PM
cmonson
huh? what? confused...
cmonson is offline
post #15 of 22 Old 08-15-2009, 05:06 PM Thread Starter
austtill
1992 XJ Cherokee
wow this post went south quick just like oil pressure ha ha
austtill is offline
4.7 Valve Train Noise - Will thicker or thinner Oil make it better? ddruker ZJ Grand Cherokee Forum 23 10-15-2014 10:39 PM
