swapping to ujoints? - JeepForum.com
post #1 of 7 Old 06-27-2010, 08:28 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
I have the cv style axle shafts, and wanted to switch to ujoints. Can I just swap them, or do I have to change something in the differential?
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline
post #2 of 7 Old 06-27-2010, 08:33 PM
squashman702
1994 ZJ
Just a straight swap. Have you changed shafts before? Make sure you have a 13MM 12 point wrench or socket on hand.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #3 of 7 Old 06-27-2010, 08:36 PM Thread Starter
Mudzilla6661
2010 JK Wrangler
Yeah I have swapped them before, but only back to cv not ujoints
post #4 of 7 Old 06-27-2010, 08:42 PM
squashman702
1994 ZJ
Same process then. Just make sure that the U joints are good before you swap (if you're buying used ones).
Think Twice Garage
post #5 of 7 Old 06-27-2010, 08:47 PM
IslandManMitch
Does CV's have any advantages over u-joints?
IslandManMitch is offline
post #6 of 7 Old 06-27-2010, 09:18 PM
Technohead
Yes, they maintain "Constant Velocity" which means less vibration and longer life. And they don't loose as much strength as the angle increases.
Make sure the u-joint axles you swap in have 5-760 u-joints or else you are just wasting time. Any of the u-joint axles will accept these joints. Install them before running the axles. Make sure to use Spicer's.
-Eric
Technohead is offline
post #7 of 7 Old 06-28-2010, 07:26 AM
squashman702
1994 ZJ
Any ZJ shaft should accept a 760. There were XJ U joint shafts that were 260x sized. You can tell by looking at them though, the U joint is much smaller.
Think Twice Garage
Front axle ujoints gomes512 ZJ Grand Cherokee Forum 1 04-16-2009 04:13 PM
Swapping D44a axles, anything funny about swapping their brakes? Jerry Bransford ZJ Grand Cherokee Forum 9 02-26-2009 08:40 AM
ZJ 5.2...CV or Ujoints? 88XJSport ZJ Grand Cherokee Forum 4 06-05-2008 12:01 PM
stock Ujoints, are they identical on a 93ZJ? knl ZJ Grand Cherokee Forum 0 05-10-2008 12:16 PM
Front Drive Shaft UJoints -Joe- ZJ Grand Cherokee Forum 19 05-01-2006 04:36 PM
