Starting problems - JeepForum.com
post #1 of 2 Old 03-12-2013, 05:41 PM Thread Starter
chiwheels
Starting problems
I have a 2000 Grand Cherokee with a 2.7 L Mercedes Diesel engine.
This morning I had severe starting difficulty and had to give up to try again later in the day. Each time I tried to start it would immediately fire, run for a second and stop. I waited for the glowplug indicator to go out each time and once I tried turning the key three times to heat up the glow plugs as much as possible before turning the engine over but to no avail.
It was a cold morning but I didn't think it was drastically cold overnight - perhaps -6 degC. When I was trying to start it at 07:30 it was -2 degC. hence I didn't think the diesel was gelling but I could be wrong. I filled it up previously at Tesco's but reading the forums I got the impression that Tesco's diesel being problematical is described as an urban myth but I don't know enough to comment.
It has been ratty starting even under normal circumstances.
Any ideas anyone ?
chiwheels is offline
post #2 of 2 Old 04-24-2013, 05:55 AM
Jzsailor
2003 WJ
Hi there
I have exactly the same problem with my WJ, and it is also a 2,7l mercedes engine from 2003, have you got any solution or know where is coming from the problem?
If so it will be a great help for me.
Thank you
Cheers
Jose
Jzsailor is offline
