Start button fail - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Start button fail
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 06-20-2014, 07:09 AM   #1
Cerkelens
Start button fail
My 2014 Grand Cherokee Summit with a diesel engine has failed on five occasions now to engage the start sequence when the start button is pushed from a cold start. Outside temperature is in the 60s - 80s F. The dashboard flashes on for less than a second, sometimes the starter will hit momentarily (like in the old days if you had a weak battery) but the engine does not start, the dash goes dark, and only the "Run" light on the ring around the start button stays illuminated. The button does not then function to turn off the "Run" light until pressed about five or six times over 10-15 seconds. The jeep eventually starts and seems normal until it happens again.
Anyone else having this problem?
Cerkelens is offline   Reply With Quote
