Split Nail WJ Build Thread - Page 92 - JeepForum.com
post #1366 of 2220 Old 03-31-2011, 07:47 PM Thread Starter
SplitNail
Originally Posted by Skytard
what new stuff?!!
Starter, alternator, and new battery cables.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #1367 of 2220 Old 03-31-2011, 07:51 PM
narnwv
narnwv's Avatar
Originally Posted by SplitNail View Post
2 gauge is it. Winch coming soon.
Should I run 2 gauge to my starter? And from my alternator? And for both of my grounds?
I did 4 gauge grounds, 4 gauge to the alt and starter. Lights are brighter and the starter sounds like it's in hyperdrive when cranking
I don't see a need for anything too much bigger than stock on the starter. I like the bigger wire on the alternator, as it allows more current (not that the stock wire was insufficient) Part of my lights brighter could be just that I replaced an 11-12 year old corroded cable with a new one.
I used 4ga, as I had about 25 feet of it hanging in the garage that was used for amp wiring in an old car of mine.
I took a wire brush wheel cup that fits into my air-powered die grinder and cleaned up the body around the grounds, taking some paint off as well, and put on big copper connectors. I need to get pics of all of this.
This: is what I used in my 10,000 rpm die grinder to clean the body where the grounds attach.
~Aaron
narnwv is offline
post #1368 of 2220 Old 03-31-2011, 07:52 PM
narnwv
narnwv's Avatar
are you just replacing **** just 'cause?
~Aaron
narnwv is offline
post #1369 of 2220 Old 03-31-2011, 08:12 PM Thread Starter
SplitNail
My starter is 12 years old, my cables are 12 years old and I want to upgrade where I can. I have a duel post battery. I'm going to put one of the grounds on the side post. I'm hoping to get some more power with fresh cables and new alternator. I'm tired of the dragging starter too. It's very weak. So I'm going to freshen the electrical system up.
post #1370 of 2220 Old 03-31-2011, 08:15 PM
narnwv
narnwv's Avatar
That's why I re-did my wiring too. (age) I'd keep the side posts free for your winch. It has to be directly connected to the battery. You can't ground it to the body. Too much current pull (under HEAVY load).
~Aaron
narnwv is offline
post #1371 of 2220 Old 03-31-2011, 08:16 PM Thread Starter
SplitNail
Awe!!! Good point! I guess I'll splice the grounds together for the negative. So there are 4 cables all together?
post #1372 of 2220 Old 03-31-2011, 08:18 PM
narnwv
narnwv's Avatar
For what? A winch? The winch should have 2 wires for power, then something else for a switch/remote to trigger a solenoid/relay to allow the current to flow to the winch motor.
~Aaron
narnwv is offline
post #1373 of 2220 Old 03-31-2011, 08:24 PM Thread Starter
SplitNail
For my jeep. Two grounds. One starter and one alternator?
post #1374 of 2220 Old 03-31-2011, 08:29 PM
narnwv
narnwv's Avatar
there is no ground for the alternator. It gets it's ground from the block. It sure doesn't hurt to add a ground to the alternator bracket. I used to do that when I was heavy into car audio stuff, just trying to squeeze every little amp out of everything.
~Aaron
narnwv is offline
post #1375 of 2220 Old 03-31-2011, 08:36 PM Thread Starter
SplitNail
I think I have 2 grounds though.
post #1376 of 2220 Old 03-31-2011, 08:39 PM
narnwv
narnwv's Avatar
one goes to the body, the other should go to the block right at the starter if I'm not mistaken.
~Aaron
narnwv is offline
post #1377 of 2220 Old 03-31-2011, 08:55 PM
islandwheeler
I may have missed the page where this could have been discussed already but, did you replace your front driveshaft? I'm looking to do a 4" lift but the one thing really holding me back is replacing my front driveshaft. my 2000 WJ is has a quadradrive nv-247 so its in 4wheel all the time unfortunately, so thats why I'm really concerned about my front driveshaft.
2000 WJ 4.7L - 4.5" 32" KM2
2000 TJ 4.0 5spd
2001 XJ 4.0 79k
2012 WK2 Altitude Hemi
islandwheeler is offline
post #1378 of 2220 Old 03-31-2011, 08:57 PM
narnwv
narnwv's Avatar
You're not in 4wd all the time.
The front drive shaft turns all the time, even for those of us who have a true 2wd option on our tranfer cases. The 4x4 system has nothing to do with the front drive shaft needing replaced with the lift.
~Aaron
narnwv is offline
post #1379 of 2220 Old 03-31-2011, 09:00 PM
islandwheeler
Oh okay well thats my mistake because I thought your 2wd was technically rear wheel, therefor the front driveshaft wouldnt spin unless put into 4wd. And what do you mean I'm not in 4wd all the time?
2000 TJ 4.0 5spd
2001 XJ 4.0 79k
post #1380 of 2220 Old 03-31-2011, 09:03 PM
narnwv
narnwv's Avatar
This isn't conversation for SplitNail's build thread......
You'll find this information in the tech forum.
Have a read here:
http://wjjeeps.com/tcases.htm
~Aaron
narnwv is offline
ANOTHER WJ lift thread...yes another WJV8QD WJ Grand Cherokee Forum 7 04-11-2013 05:33 PM
Another tire thread. EndGame WJ Grand Cherokee Forum 9 08-11-2010 03:16 PM
Another overheating thread narnwv WJ Grand Cherokee Forum 15 08-07-2010 09:35 PM
01 WJ brake thread safari2000 WJ Grand Cherokee Forum 7 07-16-2010 05:38 AM
$50 Budget boost build thread! Howiedooit WJ Grand Cherokee Forum 11 07-13-2010 11:56 PM
