Split Nail WJ Build Thread - Page 57 - JeepForum.com
post #841 of 2220 Old 02-14-2011, 07:07 PM Thread Starter
SplitNail
I put a can of restore in it to see what happens. I wonder if this issue could be in the heads..
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #842 of 2220 Old 02-14-2011, 07:23 PM
sherker55
did you do the compression test yourself? you should put those plugs in the order of the cylinders with bad compression and see if there is any correlation ( i don't know if it matters) only two looked f'd up though, such as discolored, scorched etc...
hopefully that restore **** will work out for you, good luck man
oh, and the platnium plugs are mandatory for the 4.7 HO, but not the 4.7...
sherker55 is offline
post #843 of 2220 Old 02-14-2011, 07:34 PM Thread Starter
SplitNail
I tossed the plugs. I also did the comp test myself with the help of my mechanic neighbor.
post #844 of 2220 Old 02-15-2011, 11:06 AM Thread Starter
SplitNail
So could this problem be in the heads? I don't have time/money to put a new motor in.
post #845 of 2220 Old 02-15-2011, 11:24 AM
tsconver
2003 WJ
you should put a table spoon of motor oil into the plug holes of the cylinders that are low and repeat the test. If the compression comes up to the level of the others then you have worn rings, if not then it is a head gasket or valves or a crack.
When you did the compression check did you have all the plugs out and the throttle wide open?
A leak down check would also help to diagnose. If the oil in the cylinder has no effect then pressurize the cylinder to 150 psi with the piton at TDC and see if it hold pressure. If it doesn't listen/look for where it is loosing it at. If you have air coming out the oil filler or dipstick then it is rings or a crack that goes into a oil passage, if you hear it out the exhaust it is a bad exhaust valve, out the air cleaner it is a bad intake valve, if you see bubbles or fluid is pushed out the radiator fill cap then it is a bad head gasket or a cracked head.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #846 of 2220 Old 02-15-2011, 11:30 AM Thread Starter
SplitNail
Yes all plugs out, but I did not have the throttle wide open. I just turned it over as let it idle for a few seconds.
Okay, I'll try that test Saturday as see if it is in the heads. I really hope it's a gasket/cracked head/ or valves.
post #847 of 2220 Old 02-15-2011, 11:37 AM
tsconver
2003 WJ
you normally want to open the throttle and then crank it until the gauge stabilizes. Repeat it three times and take the average. Try the oil in the cylinder trick too, to see if the rings are worn really bad.
A few goodies
2006 Red Liberty
tsconver is offline
post #848 of 2220 Old 02-15-2011, 11:48 AM Thread Starter
SplitNail
Okay, I'm debating about wether I should just pay a mechanic to figure it out then I'll decide what to do. It would only be $75 to have them figure it out.
post #849 of 2220 Old 02-15-2011, 11:07 PM
85IrocZ-28
Or one hour of your time. Pay yourself $75 an hour by doing the test yourself.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #850 of 2220 Old 02-15-2011, 11:18 PM Thread Starter
SplitNail
Okay, sounds good. I just dont have time. And these things don't take an hour.
post #851 of 2220 Old 02-17-2011, 08:56 AM Thread Starter
SplitNail
So... If my problems are in the heads what is the most cost efficient way of fixing it? Remanned heads, new heads, machine the heads? Any ideas?
post #852 of 2220 Old 02-17-2011, 09:02 AM
TOW_HOOK
1957 CJ3B
I have always heard use the champion copper cores...
i would stay away from those on a 4.7.
57 3b classic krawler /93 xj r.i.p. / 95 yj daily driver / 02 wj wife's ride / 98 xj wanta be rock krawler
TOW_HOOK is offline
post #853 of 2220 Old 02-17-2011, 09:05 AM Thread Starter
SplitNail
That's odd. That's what it came with.
post #854 of 2220 Old 02-17-2011, 09:09 AM
TOW_HOOK
1957 CJ3B
Do a leak down test, and listen to the valves, might need to remove the valve covers. the valves could need a valve job? have fun with that. it took me 3 months to do my wife's head gaskets... working full time and, have 3 others can be time consuming....
TOW_HOOK is offline
post #855 of 2220 Old 02-17-2011, 09:09 AM
sherker55
ANOTHER WJ lift thread...yes another WJV8QD WJ Grand Cherokee Forum 7 04-11-2013 06:33 PM
Another tire thread. EndGame WJ Grand Cherokee Forum 9 08-11-2010 04:16 PM
Another overheating thread narnwv WJ Grand Cherokee Forum 15 08-07-2010 10:35 PM
01 WJ brake thread safari2000 WJ Grand Cherokee Forum 7 07-16-2010 06:38 AM
$50 Budget boost build thread! Howiedooit WJ Grand Cherokee Forum 11 07-14-2010 12:56 AM
