Split Nail WJ Build Thread - Page 55 - JeepForum.com
post #811 of 2220 Old 02-13-2011, 07:38 PM
tsconver
2003 WJ
Originally Posted by snobrdrkid07 View Post
Ah did not know that there was less space between each cylinder. Something that I did not know.
allpar is a great source, they claim the limit is around 330 inches compared to the standard 273 inches. but you would probably need a perfect block to do that.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #812 of 2220 Old 02-13-2011, 09:16 PM Thread Starter
SplitNail
So what you are saying is that you can't bore very much?
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #813 of 2220 Old 02-14-2011, 05:42 AM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
The difference is 0.934 liters...
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is online now
post #814 of 2220 Old 02-14-2011, 07:21 AM Thread Starter
SplitNail
Hmmm just what I thought. Not much.
post #815 of 2220 Old 02-14-2011, 08:59 AM
tsconver
2003 WJ
standard bore is 3.660 inches, you can get 3.701 in pistons for it. So that is 40 thou over. Would not have much material left between the cylinders though and I bet the water jackets would be pretty thin. Probably would take a perfect block to go that big.
A few goodies
2006 Red Liberty
tsconver is offline
post #816 of 2220 Old 02-14-2011, 09:31 AM Thread Starter
SplitNail
Can I get any stroke out if it?
post #817 of 2220 Old 02-14-2011, 09:54 AM
tsconver
2003 WJ
no clue, i just googled summit and looked at what they had in pistons, not sure about cranks, they have none for the 4.7
A few goodies
2006 Red Liberty
tsconver is offline
post #818 of 2220 Old 02-14-2011, 10:01 AM Thread Starter
SplitNail
Wouldn't I be losing power if my piston rings were bad due to low compression?
post #819 of 2220 Old 02-14-2011, 10:30 AM
1stblack97ZJ
If your piston rings were bad, and oil was getting in the combustion chamber, yes you would be loosing power.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #820 of 2220 Old 02-14-2011, 10:35 AM Thread Starter
SplitNail
That's what I thought.. If the rings are bad does that mean complete engine rebuild?
post #821 of 2220 Old 02-14-2011, 11:53 AM
1stblack97ZJ
No, but If you are going to go through all the trouble, you might as well rebuild it so you can have the bore size checked etc, because you might get the same issue again if your cylinders aren't round.
Lets just say that if my piston rings needed replacing, I would just go ahead and rebuild the engine.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #822 of 2220 Old 02-14-2011, 12:08 PM Thread Starter
SplitNail
Yea, I would most likely do the same. Would I need new pistons? Just rings, main bearings, rid bearings, and have the block true'd. Right? I'm just thinking out loud.
post #823 of 2220 Old 02-14-2011, 12:18 PM
1stblack97ZJ
You wouldn't need new pistons unless you have the cylinders bored, then you would want to get oversized pistons to match the bore.
You would also need cam bearings, possibly a new camshaft, and some other stuff depending on what kind of condition the motor is in.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #824 of 2220 Old 02-14-2011, 12:33 PM Thread Starter
SplitNail
Okay sweet deal. Thanks for all the info. What is a good compression reading on the 4.7l?
post #825 of 2220 Old 02-14-2011, 12:37 PM
tsconver
2003 WJ
th 4.7 is an overhead cam motor so I doubt he will need new cams and bearings.
A few goodies
2006 Red Liberty
tsconver is offline
ANOTHER WJ lift thread...yes another WJV8QD WJ Grand Cherokee Forum 7 04-11-2013 05:33 PM
Another tire thread. EndGame WJ Grand Cherokee Forum 9 08-11-2010 03:16 PM
Another overheating thread narnwv WJ Grand Cherokee Forum 15 08-07-2010 09:35 PM
01 WJ brake thread safari2000 WJ Grand Cherokee Forum 7 07-16-2010 05:38 AM
$50 Budget boost build thread! Howiedooit WJ Grand Cherokee Forum 11 07-13-2010 11:56 PM
