Split Nail WJ Build Thread - Page 42 - JeepForum.com
post #616 of 2220 Old 01-23-2011, 07:41 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
The extended bumpstops with the rc-x kit not enough?
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #617 of 2220 Old 01-23-2011, 07:51 PM Thread Starter
SplitNail
Apparently not... It's bothers me. I'm just gunna cut the fenders and wait for my bumper.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #618 of 2220 Old 01-23-2011, 07:56 PM
snobrdrkid07
WJ for Life
yea I guess so. That is a better plan anyway!!!!
-Michael-
post #619 of 2220 Old 01-23-2011, 08:14 PM Thread Starter
SplitNail
Yea, also noticed today that I'm burning oil.... Should I run a thicker oil?
post #620 of 2220 Old 01-23-2011, 08:15 PM
theksmith
2003 WJ
trimming the fenders is the best long-term solution, will help if you ever go bigger tires... you may find you still need bump-stop exts then. Iron Rock Offroad offers custom length aluminum ones.
theksmith is offline
post #621 of 2220 Old 01-23-2011, 08:41 PM Thread Starter
SplitNail
Yea, how long with long arms should I need?
post #622 of 2220 Old 01-23-2011, 10:58 PM Thread Starter
SplitNail
I noticed today that I'm burning oil..... What should I do? Run a thicker oil?
post #623 of 2220 Old 01-23-2011, 11:03 PM
GraKee99
Rapist Wit
GraKee99's Avatar
With bumpstops, you need to measure at full compression. It all depends on tire size. It is usually around lift height but trimming the fenders does change a lot. I would think if you trimmed your fenders, then your bumpstops would be mainly used to stop the shock from bottoming out.
As for the burning oil, I don't know. Mine does it to every now and then when it sits of camber for more than a couple minutes.. Something I have accepted with 190K on the clock. Just bring extra oil.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #624 of 2220 Old 01-23-2011, 11:08 PM Thread Starter
SplitNail
Yea, I'm going to wait on the bump stops until I get the fenders all trimmed up, then I'll see if I still need them.
And for the oil. Should I plan on doing a motor rebuild and replace the piston rings?
post #625 of 2220 Old 01-23-2011, 11:10 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Does it seem to be burning oil any other time?
I am waiting until I HAVE to pull mine and rebuild it or will swap something else in. If it isn't burning anything during normal driving, I wouldn't worry about it to much unless you want to rebuild it. Mine has done it for about 30K now.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #626 of 2220 Old 01-23-2011, 11:15 PM Thread Starter
SplitNail
Yea, I burns just on normal driving. I think the odometer has been tampered with, or replaced. Its a salvage title... I dont know how to feel. It says 100K so to me thats WAY to early to be burning oil. I saw it today, but I was wheeling. But the guys said even on the way to the trail it was burning oil. Maybe I have it over filled.
1st step - Compression check
post #627 of 2220 Old 01-23-2011, 11:26 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Ya, I would start there. Just see what happens. No point in pulling it yet. Good luck.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #628 of 2220 Old 01-23-2011, 11:27 PM Thread Starter
SplitNail
Yea, I might try tossing a 10-40 weight in it to see what happens.
post #629 of 2220 Old 01-24-2011, 12:01 AM
801DubJay
I noticed I burned some oil the other day too... I was sitting at idle for a few minutes, then blipped the throttle and some blue smoke flew by It wasn't consistent and that was the first time I've seen it. Hopefully the last!
Perhaps we should have a V8 Dub rebuild-a-thon?
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline
post #630 of 2220 Old 01-24-2011, 12:03 AM Thread Starter
SplitNail
HAHAHA, NO! I dont want to do that. Sounds expensive and terrible!
ANOTHER WJ lift thread...yes another WJV8QD WJ Grand Cherokee Forum 7 04-11-2013 05:33 PM
Another tire thread. EndGame WJ Grand Cherokee Forum 9 08-11-2010 03:16 PM
Another overheating thread narnwv WJ Grand Cherokee Forum 15 08-07-2010 09:35 PM
01 WJ brake thread safari2000 WJ Grand Cherokee Forum 7 07-16-2010 05:38 AM
$50 Budget boost build thread! Howiedooit WJ Grand Cherokee Forum 11 07-13-2010 11:56 PM
