Split Nail WJ Build Thread - Page 34 - JeepForum.com
post #496 of 2220 Old 01-13-2011, 01:11 AM
nlynd1978
2006 XK Commander
Originally Posted by SplitNail View Post
Does anyone know of my alignmtent is good? I feel like I'm driving crooked. Someone please take a look at it.
Your thrust angle is way out, almost .20 degrees from spec and .40 or so from completely straight. Anything over spec -.25 to +.25 will create a push. The pull to the left you feel is actualy the rear end pushing the rear to the right.
Also your front end is specs says the front end pulls right as well (very slighty so you wont notice this casue of the thrust angle being out so far). So thats whats giving you the crooked felling. Your dog tracking basicly. Your rear wheels, to go straight, sit to the right of your front wheels, but you have to turn the steering wheel right to go straight. Soon as you turn the wheel back to the center position your rear wheels push the rear end out making the vehicle go left.
Have your axle in the rear aligned. Mind you its expensive but going to be well worth it unless tires lasting or having the vehicle not pull/push is not a concern. Not to mention you will never get an alignment perfect in the front till you do. then have them re-align the front as it will need it. You just changed how the vehicle travels down the road, your front end will be messed up again.
06 Commander Limited,4.7,130k
01 GC Limited,QD-II,4.0,236k-sold
99 GC Laredo,QT-II,4.7,96k-Sold
nlynd1978 is offline
post #497 of 2220 Old 01-13-2011, 01:16 AM Thread Starter
SplitNail
Would replacing bushings be best for the rear? And how the hell can you have the rear adjusted? There is no adjustment...
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #498 of 2220 Old 01-13-2011, 01:21 AM Thread Starter
SplitNail
Here it is so everyone can see.
post #499 of 2220 Old 01-13-2011, 01:25 AM
nlynd1978
2006 XK Commander
Deleted cause i over thought the problem, and sleep can be good.
post #500 of 2220 Old 01-13-2011, 01:27 AM Thread Starter
SplitNail
Are you thinking about leaf springs??
post #501 of 2220 Old 01-13-2011, 01:36 AM
nlynd1978
2006 XK Commander
Whoops, yeah im thinking leafs since there more common. Forgot WJ's dont have leafs in the rear. And we had just done this to a truck at school which is why its fresh in my mind. So yeah back to the bushings, start there and replace them. That should help.
post #502 of 2220 Old 01-13-2011, 01:37 AM Thread Starter
SplitNail
Okay, Ill prolly just wait till I get adjustables I'll get long arms for the front and move my front ADJ CA's to the rear. That should help.
post #503 of 2220 Old 01-13-2011, 01:45 AM
nlynd1978
2006 XK Commander
Have a 4x4 shop that does alignments do the final alignment when you get it all in there. And sorry on the confusion. We pull so many cars in at school while we learn all this stuff its hard to remember sometimes what has what on it with out seeing it.
post #504 of 2220 Old 01-13-2011, 01:50 AM Thread Starter
SplitNail
Its all good. I have a lifetime alignment from firestone. Between their numbers and you guys I'm sure I can get it aligned good. Thanks for your help. I'll get some rear control arms so I can mess with it. Thanks man!
post #505 of 2220 Old 01-13-2011, 10:01 AM
WillMcD
Can you move front adj to the rear?
04 WJ Limited Black, 5.5" LA hybrid (IRO Trackbar, Teraflex Springs, Bilstein 5100/5125 Shocks, IRO Critical Path High Clearance LA's + KOR 3/4" spacers, JKS Disconnects) 32" Firestone Destination M/T's, JCR Stage 3 Sliders, Black Moabs, Muffler Delete, Hella 700ff's, Yakima Load Warrior
Phil:4:13: I can do all things through Christ which strengtheneth me.
Originally Posted by billzcat View Post
a lot of people waste their life playing FB games all day like Farmville, Cityville, Gangsterville, Hookersnblowville, Idonteffingcareville
August 2011 GCOTM Winner
Build Thread:
WillMcD is offline
post #506 of 2220 Old 01-13-2011, 10:04 AM Thread Starter
SplitNail
Should be able to. I have heard you can.
post #507 of 2220 Old 01-13-2011, 10:23 AM
patrick983
the bolts are the same size bolt, only longer. would probably have to use washers but no big deal. also usually rear specified arms are longer, but they should work if theyre adjustable.
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn SOLD and missed very badly
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline
post #508 of 2220 Old 01-13-2011, 10:42 AM Thread Starter
SplitNail
Yea, when I get my long arms I'll move my RC Front LCA's to the rear so I can adjust the thrush angle.
post #509 of 2220 Old 01-13-2011, 10:53 PM Thread Starter
SplitNail
Okay so, I went to go check my oil. I noticed the dipstick wasnt all the way in the tube. So I have a little bit of oil on my intake manifold. No big deal. I go to add some more oil and this is what I find in my fill tube.
This nasty yellow green stuff. I thought at first it was maybe a blown head gasket but I have no other signs of that. Its like a jell. It just smells like oil. Maybe its oxidized oil? Its normally orange/brown right there. So I added some oil. I dont know what to think of that. Any ideas?
post #510 of 2220 Old 01-13-2011, 11:38 PM
801DubJay
I saw your thread in the main forum and responded there but, it looks like gunk from condensation mixing with oil in the crank... generally due to not letting the motor reach operating temperature, like driving real quick to a store or something.
Very nice looking rig, btw
'00 WJ Laredo V8 aka Katie
My Build Thread: http://www.jeepforum.com/forum/f197/801dubjay-build-thread-1114628/
801DubJay is offline
ANOTHER WJ lift thread...yes another WJV8QD WJ Grand Cherokee Forum 7 04-11-2013 06:33 PM
Another tire thread. EndGame WJ Grand Cherokee Forum 9 08-11-2010 04:16 PM
Another overheating thread narnwv WJ Grand Cherokee Forum 15 08-07-2010 10:35 PM
01 WJ brake thread safari2000 WJ Grand Cherokee Forum 7 07-16-2010 06:38 AM
$50 Budget boost build thread! Howiedooit WJ Grand Cherokee Forum 11 07-14-2010 12:56 AM
