Split Nail WJ Build Thread - Page 2 - JeepForum.com
post #16 of 2220 Old 08-15-2010, 06:59 PM
JesseOR
looks very good! time to update the avy!
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #17 of 2220 Old 08-15-2010, 07:20 PM Thread Starter
SplitNail
Just did How are you guys finding my build thread? I can't find it!
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #18 of 2220 Old 08-15-2010, 07:26 PM
JesseOR
it's right at the top of GC General Discussion
-Jesse-
GO DUCKS!
JesseOR is offline
post #19 of 2220 Old 08-15-2010, 07:56 PM Thread Starter
SplitNail
Awesome thanks. I cant seem to get my jeep to start. It cranks for a long time then finally starts and has a rough idle and I'll give it some gas and it will be fine....... Fuel pump? I installed a new fuel filter and I got under there while it was running and I heard the fuel filter WHISTLING. I started moving the fuel lines and the noise was changing. I couldnt get it to go away... Is this normal?
post #20 of 2220 Old 08-16-2010, 06:49 AM
JTM1
1988 XJ Cherokee
Sweet I did a good job of staying out of the pictures.
Justin
88 XJ-Lifted, Locked, and on Jackstands
69 CJ5-In peices
JTM1 is offline
post #21 of 2220 Old 08-16-2010, 12:29 PM Thread Starter
SplitNail
Fuel problem fixed. The CRAPPY autozone filter that I got was defective. I got one from the dealer its and PERFECT. So happy right now.
post #22 of 2220 Old 08-16-2010, 12:47 PM
lipripper
How does it ride, both on road and off road? I've been contemplating the lift you have and the Clayton 4.5 long arm. HUGE price difference. I've just heard the the RC x lift has a rough ride from a few people.
lipripper is offline
post #23 of 2220 Old 08-16-2010, 12:56 PM Thread Starter
SplitNail
Not saying this because Im excited and all but I really do like the ride. I want long arms but for the money I'm REALLY impressed. I havent gone offroad due to massive amount of fender trimming that will need to happen first, but Im sure after a couple weeks the shocks will "break in" if you will and it will get softer.
post #24 of 2220 Old 08-16-2010, 02:49 PM
lipripper
How much stiffer is the ride? My 01 has stock springs and its too mushy for my taste. Does it not "roll" as much in the turns with the RC lift. No death wobble at highway speeds? Sorry about all the questions. Did you have to adjust the pinion angle?
post #25 of 2220 Old 08-16-2010, 03:11 PM Thread Starter
SplitNail
Personally I think it rides like a jeep should, a little stiff. I like it. I am gunna get the rear Adco sway bar. There is quite a bit of body roll in the rear. No I don't get drive line vibes. I adjusted the pinion angle as much as I could I need upper adjustables to do it properly. I would totally recommend getting the lift. It's really beefy. I love the lower control arms. They freaking stout.
post #26 of 2220 Old 08-16-2010, 03:19 PM
lipripper
Good stuff. One more question. Does it sit level with the new springs, or would it need a spacer up front to level it out? And if so, what size spacer would it take to make sit level?
post #27 of 2220 Old 08-16-2010, 03:30 PM Thread Starter
SplitNail
It's pretty close to level. I'll prolly toss a 3/4 inch spacer up front for more tire clearance. Good questions! Keep them coming!
post #28 of 2220 Old 08-16-2010, 03:37 PM
ScrewSound
i got a question..well firstly i love the lift and tires and whatnot...my question is how much lower does ur mileage go with the upgrades?
Dave
2002 WJ Laredo- addco 1" sway bar...thats it...
Have big plans, but I'm still learning so all help is greatly appreciated
ScrewSound is offline
post #29 of 2220 Old 08-16-2010, 03:49 PM Thread Starter
SplitNail
It's about 17 on the highway going 65. The speed is off due to larger tires so maybe after I get that fixed it will be more accurate.
post #30 of 2220 Old 08-16-2010, 06:25 PM Thread Starter
SplitNail
Got my alignment a few days wanted to see what you guys think about these numbers!
Let me know if you see something that sticks out.
ANOTHER WJ lift thread...yes another WJV8QD WJ Grand Cherokee Forum 7 04-11-2013 05:33 PM
Another tire thread. EndGame WJ Grand Cherokee Forum 9 08-11-2010 03:16 PM
Another overheating thread narnwv WJ Grand Cherokee Forum 15 08-07-2010 09:35 PM
01 WJ brake thread safari2000 WJ Grand Cherokee Forum 7 07-16-2010 05:38 AM
$50 Budget boost build thread! Howiedooit WJ Grand Cherokee Forum 11 07-13-2010 11:56 PM
