Split Nail WJ Build Thread - Page 145 - JeepForum.com
post #2161 of 2220 Old 01-24-2012, 07:25 AM
Terminator2
Originally Posted by SplitNail View Post
Good, it's UV protected clear coat. This won't be a rattle can job. It's will be profess. I use VERY high quality clear coat for my drums which is car clear coat. It's very nice
I am purposely not clearing mine because if I scrape it against a tree I can just sand it smooth then respray it without having to worry about fixing the clear coat. Also when it fades it is easier to freshen up vs when clear starts to flake and peel. I also have no paint booth or painting supplies LOL. For a $40 rattle can job though I think it looks good so far. I am going to use my ICE paste wax as it protects flat paint (also black plastic) and adds a slight shine to it as well.
Terminator2 is offline
post #2162 of 2220 Old 01-24-2012, 07:35 AM Thread Starter
SplitNail
The clear coat I use is really easy to work with and I shouldn't have a problem touching up paint on the future. It will also hopefully last 15-20 years. But I have the space and gear to shoot it. With that said it will cost about $300 in paint, haha. But that looks REALLY good! I can't wait to do mine.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #2163 of 2220 Old 01-24-2012, 07:48 AM
lloyd877
That looks killer! I just don't know if I could do that kind of commitment to my jeep.
WJ 2001 4.0L
5.9 ZJ AKA Race Jeep 30" BFGoodrich ATs (Sold)
lloyd877 is offline
post #2164 of 2220 Old 01-24-2012, 07:58 AM
Terminator2
Thanks guys. My paint was a crappy single stage POS job that they just sprayed right over the factory paint with no prep at all they did not even clean it properly!!! They just sprayed right over the dirt, and bugs so it was peeling badly in spots. I ground down all the peeling paint then wet sanded and scotch brited it. I still have another coat on the hood as well as the passenger doors, front bumper, roof and grill to spray.
post #2165 of 2220 Old 01-24-2012, 08:03 AM Thread Starter
SplitNail
Hahah that's too funny. Seems to work well!
post #2166 of 2220 Old 01-24-2012, 08:16 AM Thread Starter
SplitNail
I'll be scotch brighting everything an cleaning and all that jazz try to make it last forever.
post #2167 of 2220 Old 01-29-2012, 06:38 PM Thread Starter
SplitNail
So my dome lights won't turn off when lock the jeep. But when I drive they are off. Any options?
post #2168 of 2220 Old 01-30-2012, 09:17 PM Thread Starter
SplitNail
Now my left blinker isnt working. I replaced the blinker/head light switch. Still doesnt work.... Anyone have any ideas?
post #2169 of 2220 Old 01-30-2012, 09:18 PM
volvite
signal relay
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #2170 of 2220 Old 01-30-2012, 09:24 PM Thread Starter
SplitNail
Originally Posted by volvite
signal relay
But my right one works? It doesn't make since. When I hit my steering column pretty hard too it will work.... Hahaha
post #2171 of 2220 Old 01-30-2012, 09:27 PM
volvite
Exactly. That's how mine was. Both would work half the time, and then the left wouldn't work at all. Swap the relay.
volvite is offline
post #2172 of 2220 Old 01-30-2012, 09:35 PM Thread Starter
SplitNail
okay, sounds good. where are they at?
post #2173 of 2220 Old 01-30-2012, 09:40 PM
volvite
Driver's side fuse panel. It's easier if you remove the lower covering below the steering wheel. The plastic above the steering wheel next to the guage just pulls off. Then it will show 2 of the screws to remove the lower panal. Then there should be a screw that is covered by the door when closed. Then there are two screws at the bottom of the panel. The plastic around the steering wheel can stay on. Let me know if that makes sense.
volvite is offline
post #2174 of 2220 Old 01-30-2012, 10:01 PM Thread Starter
SplitNail
Yea, I can figure it out. Thanks for the help! I'll try tomorrow!
post #2175 of 2220 Old 01-30-2012, 10:03 PM
volvite
No problem. If you know somebody else that has the relay it's worth a shot to just try their relay. I think the only place to buy is from the dealer and it's not cheap.
volvite is offline
ANOTHER WJ lift thread...yes another WJV8QD WJ Grand Cherokee Forum 7 04-11-2013 05:33 PM
Another tire thread. EndGame WJ Grand Cherokee Forum 9 08-11-2010 03:16 PM
Another overheating thread narnwv WJ Grand Cherokee Forum 15 08-07-2010 09:35 PM
01 WJ brake thread safari2000 WJ Grand Cherokee Forum 7 07-16-2010 05:38 AM
$50 Budget boost build thread! Howiedooit WJ Grand Cherokee Forum 11 07-13-2010 11:56 PM
