Split Nail WJ Build Thread - Page 137 - JeepForum.com
post #2041 of 2220 Old 01-16-2012, 01:43 PM
mrJ
2002 KJ Liberty
It just looks....goopy? I would tell them its not kosher. Bring up why (not supposed to use seam welds, etc) and that it looks spotty. Hell, offer to do it yourself with his rig. Go check the welds on the trucks they build and see if its spotty. If they do this for a living, they should already know about heat displacement, etc. Was he in a hurry with yours or what?
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #2042 of 2220 Old 01-16-2012, 01:52 PM Thread Starter
SplitNail
Okay, I called him back and they are going to take a look at it and "touch it up". I'm going to make sure they grind those off and stitch them together.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #2043 of 2220 Old 01-16-2012, 02:35 PM Thread Starter
SplitNail
I'm thinking about grinding them off and doing them with my 110 flux core.
post #2044 of 2220 Old 01-16-2012, 03:30 PM
AgitatedPancake
Originally Posted by SplitNail View Post
What would you do?
And yes this was a shop.
Honestly at this point there's not much to do. The job isn't actually the worst I've seen, I just would have done a few things differently. I would recommend against grinding off (atleast the good looking ones) and rewelding, because your just going to be adding more heat into everything. The worst looking welds in your pics (the ones with holes) are on something 1/32" thick or so, so not only is it hard to weld it isn't adding a ton of strength even with a solid weld.
What you have would probably hold up fine for a good while, but if you want to be preventative about the potential cracking in the long run I'd add some plates to the sides of the unibody right where your main LCA plate is. Turning your current flat plate into a U channel that wraps around the unibody. I'd stitch weld those new plates to the unibody, and run a nice solid continuous bead where your welding the new plates to your current one (where your connecting thick material to thick material). It'll help disperse the loading throughout more of the unibody and keep things happy
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #2045 of 2220 Old 01-16-2012, 03:45 PM Thread Starter
SplitNail
So dont take it back to them? Haha
post #2046 of 2220 Old 01-17-2012, 05:41 PM
JerzeyBoyWJ
2003 WJ
hows your clearance with the 33s in the rear?
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #2047 of 2220 Old 01-17-2012, 05:53 PM Thread Starter
SplitNail
Freaking great man! I love them!
But I need to trim my rear fenders and get my rear long arms. The axle is WAY to close to the body. But with my long arms on my passenger side tire rubs at full turn.
post #2048 of 2220 Old 01-17-2012, 08:24 PM
JerzeyBoyWJ
2003 WJ
im looking at a set of 33X12.50 mud grapplers tomorrow..how close are the tires to the rear fenders by the door? have any pictures?
post #2049 of 2220 Old 01-17-2012, 09:10 PM Thread Starter
SplitNail
It's close! Haha.
post #2050 of 2220 Old 01-17-2012, 10:05 PM
JerzeyBoyWJ
2003 WJ
It's close! Haha.
yeah it is but i like what im seeing because the tires im looking at have 50% tread so they wont be a full 33" tire...thanks for the picture it helped a bunch!
post #2051 of 2220 Old 01-17-2012, 11:02 PM Thread Starter
SplitNail
No problem man! That will look good.
post #2052 of 2220 Old 01-17-2012, 11:21 PM
JerzeyBoyWJ
2003 WJ
yeah its just gonna be weird once i get my new lift and put the BFG A/Ts on
post #2053 of 2220 Old 01-17-2012, 11:32 PM Thread Starter
SplitNail
Haha. Yea. It will be good.
post #2054 of 2220 Old 01-18-2012, 10:37 AM
Terminator2
Yes lots of space! And you kinda have too. If you start to cut more behind the tire you end up cutting off the mount that holds the fender on. It's bigger tire time!!
I still have my fender mounts and I cut about 3" more than that.
The plastic cladding needs to be centered though. I have to put molding tape back on it.
Terminator2 is offline
post #2055 of 2220 Old 01-18-2012, 10:44 AM
Terminator2
It's close! Haha.
Cut it. Then you can run 35s if you want or just make a lot more room for the 33s.
ANOTHER WJ lift thread...yes another WJV8QD WJ Grand Cherokee Forum 7 04-11-2013 06:33 PM
Another tire thread. EndGame WJ Grand Cherokee Forum 9 08-11-2010 04:16 PM
Another overheating thread narnwv WJ Grand Cherokee Forum 15 08-07-2010 10:35 PM
01 WJ brake thread safari2000 WJ Grand Cherokee Forum 7 07-16-2010 06:38 AM
$50 Budget boost build thread! Howiedooit WJ Grand Cherokee Forum 11 07-14-2010 12:56 AM
