spidermonkey's 98 ZJ build - Page 7 - JeepForum.com
post #91 of 137 Old 06-18-2011, 10:42 PM Thread Starter
spidermonkey
If I know your coming it would be good to meet ya. It's my old beagles 12th B-day. Otherwise I should be available.
98ZJ, 4.0,242, 8.8 Detroit, hp30, 3.5" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here:
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers
spidermonkey is offline
post #92 of 137 Old 06-19-2011, 12:47 PM
aircruiser
aircruiser's Avatar
yeah man its all good..you should try to make it to the IRO customer appreciation event in gilbert this september i will be there
aircruiser is offline
post #93 of 137 Old 06-19-2011, 01:39 PM Thread Starter
spidermonkey
I want to one of these years. I'm usually working.
post #94 of 137 Old 06-19-2011, 04:37 PM Thread Starter
spidermonkey
I am leaning towards doing the AX15 swap. Why? I want need more towing power and could always use more MPGs.
I have the following:
92or3 (internal slave) AX15 in good shape with newer clutch in great shape
dust cover
shifter
XJ peddles, ALL FREE!
from what I know I need:
new master with lines
new slave to be safe, since it is internal
any advice please speak up here, I was wondering if my 4.56's will work ok with that combo?
post #95 of 137 Old 06-19-2011, 05:27 PM
aircruiser
aircruiser's Avatar
i might be parting out the xj and it has the AX-15. im selling the engine and tranny plus the shell to a guy in eveleth but im not sure if he will be needing the master slave..but im not sure. 4.56s would be awesome and you will probably be able to use 5th gear haha. i never was able to after 33s.
post #96 of 137 Old 07-25-2011, 11:31 AM
jforse
dust cover
shifter
318 SWAP!
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #97 of 137 Old 08-04-2011, 05:27 AM
Rberry19
what kind of paint did you use for the rims? and is it holding up?
Rberry19 is offline
post #98 of 137 Old 08-04-2011, 10:48 AM
AgitatedPancake
You/re also gunna need a flywheel, might need crossmember work and driveshafts if the AX is shorter
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #99 of 137 Old 09-11-2011, 06:03 PM Thread Starter
spidermonkey
Hammered Black, sanded wheels, painted 3 lighter coats, holding up gread exept for the riggors of rock rash lately.
No 318, my 4.0 is running perfect and I'm getting 17-18mpg at 65 and 19-20 at 55-60 lately.
The AX swap is on hold until the transmision is dead, if that happens.
post #100 of 137 Old 09-11-2011, 07:21 PM
jforse
The AX swap is on hold until the transmission is dead, if that happens.
That trans will keep going. Why because you do regular maintenance!
jforse is offline
post #101 of 137 Old 09-11-2011, 08:17 PM
aircruiser
aircruiser's Avatar
nice meeting ya in gilbert man, never saw you on the trails what did you take? we did teds revenge and red valley i think its called. turned out to be an atv trail but it was alot of fun. then did skull road, both loops, the playground, and were doing those obstacles on the core trails when my buddies fan died in his 07 jk and overheated. it was fun, were thinking about going back up in october.
post #102 of 137 Old 09-12-2011, 08:47 PM Thread Starter
spidermonkey
We were in the middle group, did Teds, The Gourge, Gumby's Crater Crawl, and some more rocky stuff, We did High Voltage, Low Voltage, Tailpipe Lane, backwards and forwards, and Sidewall on Sunday morning.
http://http://s300.photobucket.com/a...cpZZ1QQtppZZ20
post #103 of 137 Old 09-12-2011, 10:07 PM
aircruiser
aircruiser's Avatar
ah nice yeah we did ted's, some atv trail on accident, lots of those core trail crawls, did gumbys, rocks crawl, over the edge and spent alot of time on the playground until the jk with us overheated. it was still fun and i bashed in my rocker so its kicked my *** in gear to get armor..were thinking of going back up in october
post #104 of 137 Old 09-13-2011, 03:46 PM Thread Starter
spidermonkey
get on our forum at www.nsw4x4.com to find out when the North Shore Wheelers get up there to play.
post #105 of 137 Old 09-13-2011, 05:22 PM
aircruiser
aircruiser's Avatar
will do man ill check it my sliders are 2 weeks out so idk if ill have time
How to build up? trout_champ Wrangler General Discussion 3 10-03-2009 02:00 AM
Build up zj or xj? zjBRYCE ZJ Grand Cherokee Forum 11 03-17-2009 01:13 PM
where to buy 4.7 re-build kit??? kik_start ZJ Grand Cherokee Forum 5 04-29-2008 09:16 AM
Build? devilfish ZJ Grand Cherokee Forum 13 09-15-2006 09:36 AM
THIS is how u build a ZJ! grandman97 ZJ Grand Cherokee Forum 32 08-31-2006 05:05 PM
