speed bleeders - JeepForum.com
post #1 of 10 Old 02-13-2013, 03:39 PM Thread Starter
coralman
USER OF PARTS CATALOGS
coralman's Avatar
speed bleeders
Anyone ever used them?
http://www.ebay.com/itm/390533997965
Originally Posted by HighLonesome
coralman is offline
post #2 of 10 Old 02-13-2013, 03:52 PM
TheRealOldjeep
Originally Posted by coralman View Post
I tried out a set years ago - worked fine as long as you had sealer on the threads and kept caps on them so dirt didn't migrate into the valve. For bleeding brakes by yourself, nothing beats a Motive pressure bleeder.
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #3 of 10 Old 02-13-2013, 04:06 PM Thread Starter
coralman
coralman's Avatar
Yep, just found those. Looking at a deal on one if it holds at the price. That looks pretty cool.
coralman is offline
post #4 of 10 Old 02-13-2013, 04:21 PM
TheRealOldjeep
Works well, had mine for about 5 years. I've got attachments to fit every vehicle we own and one that fits the master cylinder on the boat trailer.
Chuck P
My site
post #5 of 10 Old 02-14-2013, 04:55 PM
Winger67
Used them on other cars that I take to the track. Really helps out doing solo bleeding when I'm racing often. Just got a Motive pressure bleeder and will have to agree the thing kicks ***.
Winger67 is offline
post #6 of 10 Old 02-14-2013, 05:34 PM
ZeeJay1997
A pressure bleeder is easy to make with a small garden sprayer, a pressure gauge, and a JY brake reservoir cap at cost of not over 15 bucks.
You can even get fancy and use a Schrader valve instead of a hand pump.
Plus, it's more fun than just buying one.
ZeeJay1997 is offline
post #7 of 10 Old 02-14-2013, 06:20 PM Thread Starter
coralman
coralman's Avatar
Well, I don't see anything wrong with that plan. hardest part would be finding the fitting.
coralman is offline
post #8 of 10 Old 02-14-2013, 07:50 PM
TheRealOldjeep
As long as you never want to use it on a regular flat top MC then that should work OK, but I don't think I'd go to the trouble since the motive bleeder costs $45.
Chuck P
My site
post #9 of 10 Old 02-15-2013, 05:33 PM Thread Starter
coralman
coralman's Avatar
I thought of something that may be a tripping point but I'm not sure. Some of the sprayers I have used in the past had a silicon grease or at least looked like it in the pump slide. Isn't silicone a bad thing in hydraulics?
coralman is offline
post #10 of 10 Old 02-15-2013, 06:10 PM
ZeeJay1997
You would need to remove any contaminants. The one I bought was dry. The brake fluid will act on the rubber seals in the pump and ruin it after a while anyhow.
During my short stint as a heavy equipment mechanic, we used a metal tank with a sealed lid with scrhader valve, a pressure gauge, a ring and hook on top. Pour in a quart of fluid, put the lid on, Hang it up, put 10-15 psi head pressure on it with compressed air.
One guy who did brakes all the time used regulated air into it and had a cutoff valve.
So you can go as simple or elaborate as you want. As they say, necessity is the mother of invention.
