Solomon8718's build thread - "Muddy Gorilla" - JeepForum.com
post #1 of 37 Old 05-21-2010, 03:07 PM Thread Starter
solomon8718
Hey guys. This is me starting my first ever build thread. I haven't really done anything yet, except for creating a rudimentary custom quick disconnect for my front swaybar links. So here it goes!
Here's what I got
1997 Grand Cherokee Limited with sunroof and the full Up Country package. The package included taller shocks and springs to give an extra inch of lift, as well as gas, TC, and radiator skid plates, and front tow hooks. I've also been very impressed with what my Firestone Destination A/T tires have been able to do. They've lived up to my expectations and more.
Installed
Custom quick discos
IRO 2" budget boost
IRO over-the-knuckle steering upgrade
IRO double sheer trackbar conversion
IRO extended rear swaybar links
Swapped out the 249 Quadra-Trac for a 242 Selec-Trac and external slip yolk
My planned upgrade path - Suggestions appreciated!
Custom front swaybar links - DONE
Crager soft 8 wheels w/ 31-32" tires
E-fan conversion
Full 3" exhaust upgrade - IN PROGRESS
249 -> 242 swap - DONE
Lockers + truss + maybe regear
3.5" - 4.5" lift (replacing spacers)
Long arm upgrade
Note: list will be actively updated
Photos
Latest pic with 2" BB
Mudding pics from late 2009
Last edited by solomon8718; 08-06-2010 at 12:20 PM. Reason: Updating current jeep stuff
solomon8718 is offline
post #2 of 37 Old 05-21-2010, 03:11 PM Thread Starter
solomon8718
Here is an pic of my custom quick disconnects. It consists of a simple pin and some washers. Both my links were shot so I decided to do this when I replaced them.
post #3 of 37 Old 05-21-2010, 03:27 PM Thread Starter
solomon8718
Oh, I forgot to mention that along with my new goodies I ordered, I plan on making my own adjustable, quick disconnecting, swaybar links. The basic design will utilize two rod ends on each side of a threaded rod. This means that as I add lift height down the road, all I need to do is get longer threaded rods.
I'm basing my design off of scotch740's design: http://www.jeepforum.com/forum/f37/b...nnects-538245/
So far I've purchased my rod ends from QA1, along with all 7/16's hardware: grade 8 bolts/nuts/washers/lock washers/lock nuts. Here is a link to the rod ends I purchased. Part Number HFR7T, HF-T Rod Ends on QA1 Precision Products, Inc.
I also purchased the IRON ROCK OFF ROAD: Sway Bar Link U-Bracket to convert the ball joint attachment.
: All my hardware and rod ends :
post #4 of 37 Old 05-21-2010, 10:08 PM
BlackDaddyZJ
1994 ZJ
i like what your doing so far its pretty good. i like the uc package, wish mine had the full uc setup, only have the springs from one with the uc package on mine. keep this goin and keep the pics comin
Bob
'94 ZJ
5.2L
IRO 4.5" Lift
35x12.5 Mickey Thompson Baja MTZ's
98 5.9
Restored and daily driven
BlackDaddyZJ is offline
post #5 of 37 Old 05-24-2010, 09:29 AM Thread Starter
solomon8718
Thanks BlackDaddyZJ. I've got so many plans/ideas jumbling around in my head. Its pretty sweet.
post #6 of 37 Old 05-24-2010, 09:34 AM Thread Starter
solomon8718
Alright, so I hit a rut with the custom discos. I realized that 7/16-20 threaded rods are impossible to come across locally where I am, so thats something else I'll have to order online. Do you guys think a Grade 2 rod is going to be strong enough for this application? I'm not really seeing anything stronger... The other options are 304 stainless, low carbon steel, and b7 alloy. I'm not an expert in metals so your opinions would be appreciated. Thanks!
post #7 of 37 Old 05-25-2010, 07:51 AM Thread Starter
solomon8718
Alright, since I wasn't getting any answers in this thread, I re-posted the question in the technical forum. So far my internet searches haven't been too fruitful, but there is a local company called fastenal in town who was referred to me by the guy I talked to at ACE hardware. Ill give them a call today.
Oh, I almost forgot, I'm looking specifically for a 7/16-20 grade 8 threaded rod.
post #8 of 37 Old 05-25-2010, 12:42 PM Thread Starter
solomon8718
Yes! Just got the invoice for my IRO group buy purchase!
Here's what I ordered:
XJ /ZJ Adjustable Double Shear Track Bar Conversion Kit
Heavy Duty Over the Knuckle Steering TJ/ZJ/XJ
ZJ budget boost
XJ / ZJ Coil Spring Isolator, pair
ZJ Rear Coil Spring Isolator, Pair
ZJ Rear Sway Bar Links
"www.ironrockoffroad.com" Decals
Iron Rock Off Road 4" Tire Logo Decals
post #9 of 37 Old 05-25-2010, 01:02 PM
MoonyJohn
Nice! Why not splurge for the 3.5" front springs and use your old ones for the rear?
MoonyJohn is offline
post #10 of 37 Old 05-25-2010, 01:05 PM Thread Starter
solomon8718
haha, budget. Besides with my Up country springs and shocks ill have 3", only a 1/2" difference.
post #11 of 37 Old 05-26-2010, 01:35 PM Thread Starter
solomon8718
Well, I got a hold of fastenal. They can order the 7/16-20 threaded rod, but the best they can do is a B7 alloy. This seems to be the trend wherever I've looked, so I might just go with that. I'm not seeing that Grade 8 threaded rods even exist.
post #12 of 37 Old 06-23-2010, 12:22 PM Thread Starter
solomon8718
Well, Its been awhile since I've posted anything new, but it also took a couple weeks to receive my IRO group buy order. But I just received the parts yesterday and I'm stoked to put them on this weekend!
I am however still looking for some grade 8 7/16-20 all-thread. This stuff basically doesn't exist from what I can tell.
post #13 of 37 Old 06-24-2010, 03:14 PM Thread Starter
solomon8718
Some pics of my semi-unboxed parts
post #14 of 37 Old 06-24-2010, 03:15 PM Thread Starter
solomon8718
At first I was a little worried about not having instructions to install by bb, but I realized with my haynes manual handy it shouldn't be too difficult.
I plan on getting things started after work tomorrow. Ill be sure to document with pictures as I go.
post #15 of 37 Old 06-24-2010, 10:48 PM
dynasty_v6
1994 XJ Cherokee
This will be fricken Awesome!!!!!!!!!!!! I am hopefully building a roof rack with lights, and maybe getting a front bumber soon!
dynasty_v6 is offline
Ricochet's build thread project "WOODY!!" Ricochet88 Grand Cherokee General Discussion 897 03-14-2016 11:39 PM
Project "Grow A Set" Redhatman's long lost build thread redhatman Grand Cherokee General Discussion 1007 01-17-2013 10:57 AM
my 97 GC build thread "family hauler" framanda Grand Cherokee General Discussion 31 07-28-2010 09:24 PM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
