Snow - Page 2 - JeepForum.com
post #16 of 67 Old 02-13-2014, 11:22 AM
D0dgeRam1500
Originally Posted by wjjeep19 View Post
Im interested in a 2nd one. If it has the Selec-Trac , under 130k miles and has the 4.0.
It's a 2004 Quadra-Drive with the HD Selec-Trac transfer case swapped in. She has the 4.7L HO and 101,600 miles.
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #17 of 67 Old 02-13-2014, 11:29 AM Thread Starter
wjjeep19
Hmmmmm, I like the fact you swapped the 242 in. The miles seems great. I like V8s but not fond of the 4.7. Avg MPG? Any mods?
2002 4.Slow
2.5" lift
Software Engineer
wjjeep19 is offline
post #18 of 67 Old 02-13-2014, 11:38 AM
D0dgeRam1500
Here is the link to the Jeep and all of it's information: http://www.jeepforum.com/forum/f153/...ifted-1850498/
post #19 of 67 Old 02-13-2014, 12:07 PM
BAZ-MKE
I live in Wisconsin so we get plenty of snow... I've gotta say, my wj is pretty worthless in the slippery stuff. By comparison my girlfriends 230000 mile 97 Explorer absolutely schools my jeep. Kind of embarrassing.
BAZ-MKE is offline
post #20 of 67 Old 02-13-2014, 12:58 PM
rdkendrick
2003 WJ
Either you need newer tires, or you need to check your transfer case. You should be running circles around the Exploder.
Sent from my iPad using electrons
rdkendrick is offline
post #21 of 67 Old 02-13-2014, 01:08 PM
dcorn
No problems here in about 12" of wet snow. Went out searching for unplowed roads this morning.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #22 of 67 Old 02-13-2014, 01:09 PM
BAZ-MKE
Sent from my iPad using elect picked irons
My tires are good. Played around with air pressure too... No difference. If there's snow on the ground and I gas it going straight, the *** end kicks out and I get sideways. I will change the transfer case fluid next week with mopar stuff. Would this be the reason for a constant humming noise from 30 Mph up to freeway speeds?
BAZ-MKE is offline
post #23 of 67 Old 02-13-2014, 01:33 PM
KayCeeJeep
Agreed. Sounds like your 4wd is not kicking in right or not at all. Your Jeep should (and will) literally eat the grocery getter Explorer for lunch if it is working right.
On days of deep snow I feel like a genius for owning a Jeep! Love that part, I don't feel like a genius very often.
STOCK WJ WARRIOR
2004 4.0 Laredo Selec-Trac at 140k
General Grabber AT2's
KayCeeJeep is offline
post #24 of 67 Old 02-13-2014, 01:35 PM
rdkendrick
2003 WJ
Last year, I was able to spin, in a circle, in one place, in the parking lot. I haven't tried this year. My ankles are getting worse and I cannot walk as far as I used to, because of my 2004 accident.
post #25 of 67 Old 02-13-2014, 02:29 PM
D0dgeRam1500
242HD + Vari-Lok axles + mud tires and a WJ is unstoppable in the snow.
post #26 of 67 Old 02-13-2014, 03:01 PM
BAZ-MKE
Mud tires are generally not the best in the snow, a good set of all terrains will do better in my experience. I have quadra drive 2 and it is currently not working all that well haha
BAZ-MKE is offline
post #27 of 67 Old 02-13-2014, 03:07 PM
wj4play
I had blizzacs on my wj long ago - driving on ice was like driving on pavement start/stop was awesome
U need new tires
Better mouse traps result in smarter mice
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #28 of 67 Old 02-13-2014, 03:12 PM
KoolAidMan888
Just got the same storm. 2 wheel drive all day.... But then again don't drive like most of the ppl in ct.. I use my head and "drive"
KoolAidMan888 is offline
post #29 of 67 Old 02-13-2014, 03:23 PM
CSIROC
2003 WJ
No you don't. Quadrtrac II or Quadradrive. Unless you've done some serious hacking and installed the WK independent front suspension (and replaced the rear axle along with).
But yes, all terrains are going to be better on packed snow than mud terrains - MTs have little to no siping. In deep snow, the muds should churn through just fine.
Still, definitely sounds like your Jeep has issues. My Quadradrive system is beyond impressive in snow - deep or packed.
CSIROC is offline
post #30 of 67 Old 02-13-2014, 03:28 PM
BAZ-MKE
Yeah, my bad... I meant quadra trac
BAZ-MKE is offline
